Question about Singer 20U73
Is there a way to unlock the singer 20u73 sewing machine? (hand wheel or the pressure foot not moving)
    New Friend:
Please can some body tell me how to unlock singer 20U?
Posted on Jan 09, 2015
  • Singer Master
  • 1,133 Answers
Try this link http://wiki.techshoprdu.com/index.php?title=Singer_20u
for user manual, service manual and parts diagrams.
Posted on May 26, 2011
Belt not gripping on singer 237 and needle doesn't go up and down
1. The motor has a bolt that you have to loosen and move up and down for adjustment.
2. Take the needle out first before adjusting.
3. You will slowly apply pressure to the foot control pedal until the motor is moving. Pull up on the motor to a point where the motor moves the fastest.
4. Tighten motor. Check again afterwards.
5. It is essential that the center of the hand wheel is tightened before you begin.
Nov 02, 2016 | Singer Sewing Machines
My singer ingenuity 7436 will not sew when i press the pressure foot the motor sounds but no movement
have you checked the knob inside the wheel on the right . If not tightened (hand tight) needle will not move.
Dec 11, 2014 | Singer 7436 - INGENUITY
Hand wheel rotates but stop motion screw doesn't rotate and it is not moving the needle up or down
Robin. Take off the hand wheel. Look for the funny looking washer with ears. The center fingers should be angled outward when you fit it into place (counter intuitive, I know) Fit everything back together and try it again.
Oct 25, 2012 | Singer 20U73
The needle does not move when the foot pedal is used.
Make sure that you pushed the bobbin winder all the way to the left.
Jimmy
Apr 01, 2012 | Singer 7444 Mechanical Sewing Machine
I have a singer cxl electronic sewing machine and i have a problem with the needle either not moving or stopping when stitching the larger motifs or the zigzag stitch, somtimes the needle jut moves too...
The needle either not moving or stopping is a sign that the machine is jamming. Here's the answer for the question "My machine is jammed" from the FAQs on Singer's web site at http://www.singerco.com/support/faqs.html
A jammed machine is caused by thread being caught in the hook. Remove the upper thread and the bobbin case, turn the hand wheel towards you (counterclockwise) by hand and remove any thread in the bobbin case area. *Always turn the hand wheel towards you. Turning the hand wheel away from you (clockwise) can cause the machines timing to become unaligned and jam your machine. Also, always make sure the presser foot is in the down position before you start sewing. Sewing with the presser foot in the up position will jam your machine in the bobbin case.
Your description of the needle hitting the plate or foot is an indication that the machine's timing has become unaligned which can be caused as indicated above by turning the hand wheel away from you - the correct way is to *Always turn the hand wheel towards you.
Mar 03, 2011 | Singer Sewing Machines
The hand wheel spins but the needle doesn't move on my singer 20U73
try this link http://wiki.techshoprdu.com/index.php?title=Singer_20u
for user manual, service manual and parts digagrams for this model
Dec 07, 2010 | Singer 20U73
Singer 2259 - The machine has stopped moving, the foot pedal is making some noise and the hand wheel will turn OK but nothing moves when I push the foot pedal.
Check to see if you have your bobbin winder on. That's usually the problem. Just push it to the left and you should be ok.
Sep 09, 2010 | Singer 2259 Sewing Machine
Sewing Machines blues
Almost all home sewing machines are a fixed presser foot type - the cloth is fed by the serrated ratchets on the bed under it. Expensive walking-foot sewing machines do have a walking foot in addition to the lower serrations. Those usually start at $1000and up.
Jul 10, 2008 | Singer Featherweight 140Q
Singer 20U73 Logo
236 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
