Question about Toshiba gigabeat MES60VK Digital Media Player
MES60V suddenly stopped charging.
I didn't use it much, but one day before a trip, I plugged in the factory charger and it showed the deep blue "Gigabeat" screen for about ten seconds and then a yellow triangle with number 5 in it came up and it said to "Contact manufacturer for repair" message. I've tried contacting Toshiba and they don't even list the model any more on the Gigabeat site. I don't know what the Error 5 is for. I have managed to get a blank screen and the battery symbol on it by putting charger on it and hitting the top button ( I forgot what it does now) on the side after resetting it with the battery on/off switch with a paper clip. It showed about 60% charge when the symbol showed. It looks like it's charging, but I can't tell.
If it charges, I'll let you know, otherwise, what is error 5 and why return it to manufacturer?
    Problem Solver:
  • 5 Answers
Download, and install the firmware. It should work after that. It might of formatted the storage partition of the device, but you can resync it after you update the firmware on the device. You can get the firmware here: Gigabeat S Firmware.
Posted on Apr 04, 2009
I cannot charge both my dysons. Working perfectly yesterday but not today. I think it maybe the battery charger
The manual for the DC27 can be found here (
https://www.dyson.co.uk/medialibrary/Files/Dyson/Support/downloads/UK/floorcare/Manuals/dc27_uk_manual_alf_120710%20pdf.pdf ) but is not so helpful in deep troubleshooting outside of looking for blockages.
I'm a little confused since you're talking about battery chargers, but this is posting under Dyson DC27/DC28 assemblies, which are both plug into the wall uprights. Are you possibly in the not-quite-right section? If so, reply with your model numbers and that may make things go a bit easier.
In general though, if you have dyson rechargables that both suddenly stop working, the charger is likely the issue. Look at the electrical contacts for both the batteries and the charger, and make sure they are clean (unplug cherger before touching anything, start, if possible, with compressed air to blow lint and such out). Check that the cord for the charger is not damaged, and that your wall outlet hasn't tripped a breaker or a GFI reset.
Good Luck!
Nov 13, 2015 | Dyson DC27 & DC28 Internal Hose Assembly,...
Red blinking light
Hi, Ephraim. The flashing red light indicates that the device is showing "low battery". It could be that the LG phone charger fits the charging port on your bluetooth headset but it is not compatible with your device. In order for you to know that it is charging, the device should show a steady red light(means charging).
Please take a look at the table reference below.
•With the Charger Plugged In
______________________________________________________________________
•Headset Indicator Headset Status
Red-----------------------------------------------Charging (battery level less than 50% charge)
Yellow-------------------------------------------Charging (battery level more than 50% charge)
Green--------------------------------------------Charging complete
With No Charger Plugged In
Off ---------------------------------------------Power off
Three blue flashes------------------------Powering on/off
Steady blue --------------------------------Pairing/connect mode
Rapid blue/purple flashes -------------Connection successful
Quick blue flash --------------------------Incoming/outgoing call
Slow blue pulse --------------------------Connected (on a call)
Slow blue flash ---------------------------Standby (not on a call)
Slow red flash ----------------------------Idle (not connected to phone)
Slow purple pulse -----------------------Connected call muted
Steady red ---------------------------------Attempting to connect
Quick red flash ----------------------------Low battery
Note: After 20 minutes on a call or of inactivity, the light stops flashing to conserve power, but the headset remains on
Hope that'll help you in some way.
**Please rate my post and/or leave a comment** ...Thanks...
Sep 25, 2013 | Motorola Mobility H560 Bluetooth Headset
Camera won't charge
sometimes the charger can become loose in either the camera or the plug so try buying a new plug and if it still doesn't work then it is a problem with the camera and you will have to ask the people you bought it from
Jun 18, 2013 | Kodak EasyShare M853 Digital Camera
My iPhone 4 is a few months old and last night it suddenly stopped charging. Of course i didn't realize it until my phone died during the day today and i tried plugging it in and wouldn't ch
The charge adapter maybe faulty.
If your cell phone is a few months old, then it would be still under warranty. Take it back to the place where you purchased it and have it repaired or replaced under warranty.
Jul 26, 2012 | Apple iPhone Smartphone
Low hour, RASCAL 600 has been in clean safe storage with new batteries won't charge, no amp meter reading, no fuel gauge reading, yet charger itself has red and green light showing. If and when the...
The green light on your charger indicates a full charge but you know thats not right since you didn't charge the batteries when they were in storage they have dropped so low the charger cannot detect them and provide a charge. The batteries will need to be replaced with new ones. Charge before use and charge for at least 20 days to get them operating at 100% now you will have to use it for those 20 days to get the batteries used to charging charge every night when you go to bed and unplug when you get up in the morning. If you do have to leave the chair for a week or so put up fully charged and charge once a week overnight. If you put the chair in storage again disconnect the batteries from the chair and store with a full charge. Hope this helps you
May 08, 2011 | Health & Beauty
I have a hp g60, i have a really weird issue. Some times my laptop stops charging suddenly and the small led next to my charging input slot does not show any light. I checked my charger its showing...
Kind of vague. It could be the port on your laptop where the charger plugs into. It could be bad, or could have a bad connection to the motherboard due to use or manufacturing defect. When the charger stops charging then it has to use the battery power. This morning the battery may have had a low charge causing the laptop to shut down. Did you notice the battery's power level before it shut down? If you are wiggling the end of the charger that is plugged into your laptop to get it to start charging again, then that is most likely your problem. Do not wiggle it , for it could fry your motherboard. If that is the case then that port needs to be re-soldered.
Jan 24, 2011 | HP G60-230US Notebook
Ive had the same problem with my laptop, one day it just stopped charging. I would put in the charger and the blue light on the side would either be very dim or not show the blue light. I had to either...
If you have multimeter then check the output voltage of the charger, if charger is not working then replace it, if charger is working then there must be a problem with mother board, try to contact some reliable repairing engineer.
Regards;
Hasan
Dec 30, 2009 | HP Pavilion dv6000z Notebook
Ds lite suddenly stopped working
The orange light goes off when the battery has been charged to its highest capacity. After every charge, the batteries capacity is decreased. Get a new battery, that should do it.
Feb 28, 2009 | Nintendo DS Lite Console
Toshiba gigabeat MES60VK Digital Media Player Logo
202 people viewed this question
Top Toshiba Audio Players & Recorders Experts
James DuPont Jr
James DuPont Jr
 Grubhead
Grubhead
Are you a Toshiba Audio Player and Recorder Expert? Answer questions, earn points and help others
