Question about Audiofonics ADF-243 Car Audio Amplifier
I am trying to put my amp in my new car, but it is on a protected mode. I had it in my ol car, I don't remember setting anything like this. How can I bypass this and get it to work? L
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Audiofonics Master
  • 2,226 Answers
Check your speakers and speaker wires for shorts and/or grounds.
Posted on Nov 12, 2010
Kenwood amp red light
Red triangle is kenwood power light. Check rcas
Sep 24, 2017 | Car Audio & Video
Protection mode is on and I don't know why... Red light on the amp
Protection mode normally actives due to too much current being drawn by the output amplifiers. This can be caused by improper loading ( impedance too low for amp to drive) or one or all of your output transistors are blown. The protection mode monitors the power supply current and thermal properties of the power amp. Since your problem happens when it turns on I would have to say the supply is drawing too much current because of a bad output transistor. Without troubleshooting the amp this is the best answer I can give you. Good luck!
Jul 19, 2011 | Sony XMGTX1852 Car Amp
I have phase linear uv8, need to know how to get subs 2 work! Amp goes into protect mode when rca's r plugged in, there r 3 sets of preamp out puts 1 front left and front right, 2nd is rear left rear...
try testing the amp without speakers plugged in. Run the sub preamp out to the amp that you will drive the subs with, but don't wire up the subs yet. Test for protect mode kicking in.
Yes - unplug the rca ins from the amp. retest.
No - Problem lies within the sub wiring. What is the load on the amp (measure with an ohm meter)? If it is below 4ohms, chances are the amp can't dip that low. Give it more resistance by wiring it differently (series vs. parallel)
Bruce
May 05, 2011 | Kicker Car Audio & Video
Good afternoon: I have a sony STR K740P amplifier that keeps going nto Protecdt mode about every five minutes. I turn it off for a while then back on and it runs fine for another 5-10 minutes that back...
u have an amp that is going into thermal protection mode. the reason maybe an overloaded amp. make sure the right ohms speakers are connected to ur amp. most amps will work with 4ohms with bridge mode, then there are amps that work with 4 or 8 ohms. if all conections are ok, the ouput circuitry is overheated. u need to get it checked by a qualified tech
Jun 05, 2010 | Audio Players & Recorders
My 450 watt fusion amp is now in ''protect mode''. how can i fix this?
Start by completely turning off the power to it and anything connected to it. Turn all levels down to there lowest volume settings. Check to be sure your speakers are not shorted. Be sure the power voltage is correct. Turn on each of the items, the amp being last. That probably will resolve the problem but I am not that familiar with the unit just trying to help. Most units have stay in protect mode until I cycle the power. Typically they monitor the speaker current hence a short would cause almost an instant protect fault.
Good Luck,
Gilshultz
Dec 01, 2009 | Car Audio & Video
Protection mode?
Disconnect all speaker connections and rca cables. Leave power, ground and remote wires intact. Try turning on again. If you still have a protection light your amp is faulty. Hopefully you have warranty. Double check your connections. .A thumbs up would be greatly appreciated if this answer is helpful to you. protection-mode-shonxoarcym4awy4zl1imx4o-2-0.jpg Lanzar
May 25, 2008 | Lanzar Car Audio & Video
ABLE TO VIEW PHOTOS, CAN'T TAKE THEM
Check that the memory card hasn't been put into write protect mode. Should be a small switch on the side, one way for writeable, the other for write protect.
Hope it helps =)
Jan 22, 2008 | Casio Exilim EX-S600 Digital Camera
Onkyo Tx-v940 Receiver/Amplifier Protection Mode
Audio amplifier IC's damaged you need to change it.Good luck
Dec 31, 2006 | Onkyo TX-V940 Receiver
Amp shutting off going into protection mode
Check this out: http://www.techlore.com/article/14696/
Aug 14, 2006 | Legacy Audio American Legacy II LA690 Car...
My amp keeps going into protective mode.
try to lower the SLA option on ur deck maybe the amp is pulling to much current from the battery try putting a battery with more AMPS
Jan 06, 2006 | Jensen LXA400 Car Audio Amplifier
Audiofonics ADF-243 Car Audio Amplifier Logo
87 people viewed this question
Top Audiofonics Car Audio & Video Experts
Mark Skinner
Billy McCain
Billy McCain
Level 1 Expert
Bill Boyd
Are you an Audiofonics Car Audio and Video Expert? Answer questions, earn points and help others
