What is usb legacy support - Computers & Internet
  • 6,826 Answers
Usb is universal serial bus.
legacy is obsolete or vintage aged computer product.
support is any helpful information or downloads available for the product in question.
I hope that helps.
Posted on Nov 12, 2010
My screen shows ' keyboard error or no keyboard present'.... I reset CMOS to default... no help... if I buy a USB keyboard, will USB Legacy still be enabled after defaulting???? THANKS!!!!!!!! ...
Buying a USB keyboard will be the same as using the PS/2 (the round one with the 6 pins), and USB legacy should be enabled by default.
If not, you could still enable it in the BIOS.
Oct 28, 2010 | IBM PS/2 Enhanced Keyboard/Mouse 71G5791
I have toshiba dyna notebook ss 2000m. My windows xp corupted by a virus. all .dll files became .exe files. now i want to install a fresh copy of win-xp. but when i can't be able to boot from a usb...
There are two possible reasons why, First, maybe the legacy onboard usb is not enable from the BIOS. I believe that you know how to check it, just look for the legacy USB or legacy onboard.
Second, it is possible that your windows XP disc is not a bottable version, meaning the disc will be read as a data cd only and not an installer.
But try to check for the first, that is closer to resolve your problem.
-Theory of a Bum-
Oct 19, 2010 | Computers & Internet
Please can you give steps to disable the onboard usb controllers to use the CPI USB Card. I've installed the PCI Card after the onboard stop working
2.4.2 USB Configuration
The items in this menu allows you to change the USB-related features.
Select an item then press <Enter> to display the configuration options
USB Function [Enabled]
Allows you to enable or disable the USB function.
Configuration options: [Disabled] [Enabled]
Legacy USB Support [Auto]
Allows you to enable or disable support for USB devices on legacy
operating systems (OS). Setting to Auto allows the system to detect the
presence of USB devices at startup. If detected, the USB controller legacy
mode is enabled. If no USB device is detected, the legacy USB support is
disabled. Configuration options: [Disabled] [Enabled] [Auto]
USB 2.0 Controller [Enabled]
Allows you to enable or disable the USB 2.0 controller.
USB 2.0 Controller Mode [HiSpeed]
Allows you to configure the USB 2.0 controller in HiSpeed (480 Mbps) or
Full Speed (12 Mbps). Configuration options: [HiSpeed] [Full Speed]
BIOS EHCI Hand-off [Disabled]
Allows you to enable support for operating systems without an EHCI
hand-off feature. Configuration options: [Enabled] [Disabled]
NOTE!!!
Do not disable the BIOS EHCI Hand-Off option if you are running a
Windows® operating system with USB device
hope above given details with give you a detailed description as you desired.
good luck
Feb 04, 2010 | ASUS P5LD2-VM Motherboard
My amd athlon 64 windows vista computor will not reconize player
First, try connecting the player into another computer just to make sure that there's no problem with the player.
Now, if the problem is isolated with Windows Vista, all you have to do is to update the USB driver of your computer or enable the USB Legacy Support and the problem should be resolved.
By the way, you need to contact the computer manufacturer to assist you in enabling the USB Legacy Support.
Have a great day!
Jan 10, 2010 | Audio Players & Recorders
USB keyboard problems.
Since you have tried using another USB keyboard but you got the same problem, then the issue has something to do with the USB.
Contact the manufacturer and have them enable the USB Legacy Support of your computer. This should resolve the issue. If they say that the USB Legacy Support is already enabled, then have them do something on your PC. It's obvious that your PC is not working correctly with any USB keyboards.
Thank you!
Dec 29, 2009 | Dell Computers & Internet
Not recognized by any computer
no it is supported on high speed or usb legacy 2.0
Go to bios setup and setr usb legacy 2.0 high speed
then save settigns
May 25, 2009 | Dane-Elec DaneElec 4GB USB Drive Copper...
Western Digital My Book freezes computer on boot up.
Mine boots fine if I unplug (better yet, hold the flat button down on the back for about 5 seconds, and it will turn off).
Aug 31, 2008 | Western Digital My Book Essential Edition...
My System Windows Xp Cannot read Usb thumb drive
If you insert it on a USB located on motherboard there usually should not be problems, only if you forget to enable in BIOS, USB 2.0 or USB legacy support. If you have a card reader installed, please verify the pin connection required. You can find it in your motherboard manul. USB Legacy is generally required if you want to boot from some USB device and not all motherboards require that to be enabled to recognize and boot from USB devices.
Bye.
Jul 27, 2008 | Microsoft Computers & Internet
Dell optiplex wont boot up
If you are using a USB keyboard, then check in the bios that USB keyboard is enabled, and also Legacy support as well.
Legacy support will allow a USB keyboard to operate under the DOS environment.
This should allow you to press the any key to start booting from CD.
Hope that helps =)
Apr 13, 2008 | Computers & Internet
Problem
That particular board has PS2 ports on it. I would suggest a couple of things. If you have a PS2 keyboard, plug it in and use it since legacy USB support might not be turned on in BIOS.
If that works, go into BIOS and turn on legacy USB support and then try the USB KB again.
Secondly, if you don't have a PS2 keyboard, get your manual out and clear the CMOS. It might be that the legacy USB is turned off and clearing the CMOS will re-enable that (assuming it is done at the factory).
Good luch.
Mar 19, 2008 | Biostar P4M890-M7 Motherboard
Computers & Internet Logo
75 people viewed this question
David Payne
David Payne
