Question about Reliance Controls 20-Amp Furnace Transfer Switch - TF201W
Clicking on furnace . wont ignite or start. - Reliance Controls 20-Amp Furnace Transfer Switch - TF201W
  • 6,826 Answers
Maybe the ignitor is not directly in the path of the flow of gas or fuel.
Posted on Nov 12, 2010
Burner shut off then there is a clicking sound, burner ignites again
this is normal the clicking sound you hear is the system starting another cycle for your furnace to ignite the burners, then turn on tbe fan blower.
Sep 27, 2017 | Heating & Cooling
Dependable 92 ignitor
check continuity on hot surface igniter. no measurable ohms reading = bad igniter. also insure 120v getting to the igniter
Jan 26, 2014 | Goodman GMS90703BXA Heater
Where is my flame sensor on a single burner coleman evcon high efficiency furnace
If this is a hot surface ignition system, the sensor may also be your igniter.
Dec 11, 2013 | Heating & Cooling
York diamond 90 furnace burners won't ignite ... igniter glows for a few seconds then clicks off, no burner ignition. Tried resetting the furnace by powering off and then setting thermostat to call for...
The thermocouple could be defective. If this is a high efficiency York furnace, the stack blower should start and run first. If it doesn't the blower controller may have failed.
Dec 06, 2013 | Heating & Cooling
Our coleman evcon furnace has started clicking over & over again before it starts up, we replaced the thermostat & the same thing happens.We are afraid that this is hard on the furnace & have resorted to...
Suspect that the igniter is causing the clicking (or could be a relay). Suggest having the furnace serviced. There is also a major recall for some models of the Coleman Evcon furnaces.
Oct 29, 2013 | Heating & Cooling
Goodman furnace Model GDS80703AXBB -fan comes on then igniter light comes on, then burners turn on but shut off right away and wont stay lit. Now igniter light wont come on so burners not coming on at...
Sounds like either the flame sensor is not working.
The sequence for starting the furnace is:
1. extraction fan on
2. pressure sensor (for fan)
3. ignitor (spark or glow plug) comes on
4. gas valve opens up
5. ignition of flame
6. flame sensor (or temperature sensor)
7. plenum temp. sensor
8. main fan starts
It is most likely that the flame sensor is dirty or gone,
or (and I hope not), the module is gone and needs to
be replaced.
Sep 10, 2017 | Heating & Cooling
Goodman furnace gmh95090cxac wont stay lit keeps clicking will lite then clicks back off what would be the problem
Hello, if the burners light but do not stay on for more than 10 seconds, I would clean the flame sensor. The flame sensor is a metal rod that is on the opposite side of the Igniter, sometimes it gets coated by oxidation and does not sense the burner flame and shuts the Furnace down. To clean to kill power to tje furnace, remove flame sensor and clean with a steel wool, then reinstall and start Furnce back up. If this does not work then most likely the Igniter is too weak to ignite the gas and will have ro be replaced.
Oct 29, 2012 | Heating & Cooling
Furnace clicks many times before igniting
sounds like it could use a new spark ignitor with new pilot assy. will probably die completely soon
Nov 26, 2008 | Goodman Heating & Cooling
Reliance Controls 20-Amp Furnace Transfer Switch - TF201W Logo
Top Reliance Electrical Supplies Experts
Craig Butler
Craig Butler
GFTALON
Are you a Reliance Electrical Supply Expert? Answer questions, earn points and help others
