Question about LG WM-2277HW Front Load Washer
My LG washing machine cannot hold water as the water drains continuously and draining does not stop
    Problem Solver:
  • 15 Answers
Remove drain hose from tub just to insure it is not syphoning itself
Posted on Feb 22, 2011
I have a LG WM0642HW it stopped draining, and sounds like pump is spinning but no water. I opened the filter plug and no obstuction and tried draining with small hose no water. but there is still water in...
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Apr 17, 2011 | LG WM0642H Front Load
Water doesnt stop fillinG in panasonic NA F60A6 WASHING MACHINE
Fyi. All new washing maching already tested on their functionality and features but not test run with water intake and drain function. I would like to share My experience last time with this model. The water outlet valve will release by motor when you set to drain mode.it suppose manage to retract back by spring when drain process finish or afte small you change to wash mode.
Take a look on the spring movement.normally it not properly hold valve switch hence the retracted spring not block the valve to stop water drain. Just rectify the alignment of the valve swich which directly connected to the retractable spring.
Dec 26, 2010 | Washing Machines
I have a lg front loader mod-wd-1025fb washer, i moved the other day & i have just connected the machine up to wash & it fills up with water but wont spin it out & just stands still has a OE...
The OE code appears because the machine is not fully drained after 10 minutes to start the spin cycle. The machine cannot spin with water still not drained due to clogged/kinked drain hose, blocked pump filter, or pump not working. Remove the drain hose from where it is installed and drain the water from the machine into a basin that is enough to hold the water. The drain hose or the pump filter is indeed clogged/blocked if the water does not drain/flow by gravity into the basin.
Check to make sure that the drain hose is clear and not kinked. Open the pump filter cover then remove and clean the filter. Reach in the pump impeller with your finger and turn it to check whether it is stuck or not.
Make sure the pump wire harness is snugly connected and intact. Replace the pump if no issue is found with the drain hose, pump filter, impeller, and the wire harness or after all issues are addressed and the fault code still appears.
You don't have to accept or reject and rate this post to add information or post comments and follow-up questions. Accepting a solution does not stop you from communicating with an expert. You may continue communicating with the expert as long as you need assistance regarding the issue stated herein.
Aug 29, 2010 | LG WM-2277HW Front Load Washer
LG Top Loader Fuzzy Logic 5.5. The water
No you just need to get the drain hose up higher...the water is siphoning out and is either caused by the end of the drain hose still in water and not having an air gap or the hose is not going up higher then the top of your washer...
Lifting the hose up should give you an air gap and get the hose high enough to stop the siphoning...
heatman101
Apr 27, 2010 | LG WFT1071TP Top Load Washer
LG TROMM washing machine can't open door
You need to unplug the machine, and drain the water from the drain hose, accessing the drain pump.
Once you access the drain pump also remove all obstructions in drain lines, this often fix teh problem.
If you do not have done anything similar before, then it is better to call the technician.
Jan 08, 2009 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
LG WT-R801 keeps draining
If the cycle does not stop draining that is usually because of a faulty membrane switch that controls the water level in your appliance.
The faulty sensor cause the machine to think that there is still water inside, even when water has drained completely.
May 16, 2008 | LG WM0642H Front Load
Problem in my washing Machine
If your timer is stopping at the drain cycler (before the rinse) check the LID SWITCH. Most washers will not drain or continue the cycle if this switch is not closed. Open the lid and look for an opening in the housing were the lid sits. try depressing it manually while the timer is at the drain cycle.
Jul 18, 2007 | LG WFT1071TP Top Load Washer
LG WM-2277HW Front Load Washer Logo
204 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
