Question about Sony STR-DE598 Receiver
Fus burnt cannot find a fuse. checked with radio shack. where can i find it. i live in N.J.. thanks in advance
The Fuse is internal and you must remove the top cover.  It is a 6.5 Amp, 5mm Euro size, mounted in a circuit board fuse-clip on the inside left rear corner of the chassis.  This is not a "user serviceable" part because if it blows you are usually in deep weeds concerning the power supply circuits.  If you a a "techy" this is not usually a huge problem.  If you find that the unit is "unrepairable" you can sell it on eBAY for parts.  There are lots of techies out there that will buy it.
Jim
Posted on Jul 30, 2008
Where in the fuse box is the fus for the radio
There also is a small 10 amp fuse on back of radio
May 10, 2016 | 2006 Chrysler Town & Country
HI, I BOUGHT A RADIO SHACK BASE CB IT'S A 495, VINTAGE,AND A OLD ATTENNA BUT IT WAS STILL WRAPPED, @ A TAG SALE, I NEVER SOLDER THE GROUND I THOUGHT I HAD A GOOD STRONG CONNECTION, WHEN I TURNED ON T
Hi Jack , little pun. the radio should come on no matter what. Take the radio ( no coax ) plug it into the wall ,now see if it comes on. Look in the back to see if its on AC or DC. Which ever way it is turn it the other way. If the radio doesn't come on you should open the radio and look to where the power cord come in for DC. there is a diode there called a reverse polarity diode. It is probably a 1n4003 but check it anyway to see if its burnt. If it is replace it and the radio should come on . Also check the fuse .
Nov 30, 2014 | Radio Shack Radio Communications
My radio want worek i checked the fus
there will be a second fuse behind the radio its self , remove the radio and check that one , also be able to check wire connectors if the fuse blows again when renewed
Jul 20, 2014 | 1996 Jaguar Vanden Plas
How can I get power in the radio of my Audi a6 2005 4.2?
check the fuse box for the radio fus ethe lid/cover will list the fuses
Jul 01, 2014 | 2005 Audi A6
Power supply connected wrong way
go to www.cbtricks.com they have a service manual for this radio. Check all the 1n4801 diodes for one that is or looks burnt. especially one near the power connector.If you find a burnt one replace it.
Feb 16, 2014 | Radio Shack TRC-447 CB Radio
No sound from car radio
replace the radio it blew the internal amplifier
Dec 15, 2017 | Cars & Trucks
I have a trc447cb radio, it kept blowing fuses, please help thanks...
This radio has been hooked up backwards. CB radios cannot be hooked up backwards or it will destroy it. However this is hope.
Because they can be damaged this way, there are polarity protection diodes in the radio that will blow if the radio is hooked up backwards, before it can hurt anything in the radio.
They are usually N1004 diodes. Is a big black diode that has a white stripe. And if it is blown, it will most likely be Black and burnt.
Open the radio, and look near the power section of the radio. It will be in the back near where the power cord plugs into it.
Look for a burnt black diode. That is the protection diode.
Get an N1004 or better from radio shack, and remove the burnt one, and put the new one in, making sure to put it in with the white strip on the same side as the original.
Once you have finished. Make sure the polarity is correct. Then hook up the radio, and turn it on. Should work fine.
If you want to validate that it is the correct diode, if you pull on leg out of the board, and turn on the radio, it will turn on. When the diode blows, it prevent the power from getting to the board, if you take it out, it will let it through. CAUTION. The radio will work again if you just remove the burn diode without replacing it. But if you hook it backwards again, it will be toast, and as good a door stop.
Sep 05, 2010 | Radio Shack TRC-447 CB Radio
I have a 2001 saturn sl2 - car was not starting but had full power to windows, lights, fuel, radio... just replaced starter and it's spinning but not turning over. Store bought starter.
Fuse box inside car front of console.Burnt terminal in front 68way connector,you will most likey need a used fus box,terminal will be o.k.hope this helps
May 16, 2009 | 2001 Saturn SL
No brake lights blows fuse every time
there is most likely a short in the wires have you put a tow package on it if so did you splice in to the lines check all wires and see if they are burnt any were most likely short
Jan 05, 2009 | 1995 GMC Jimmy
Kenmore electric dryer model# 66702692 66702 runs but no heat
Hi soccerref209
This could be caused by a number of things. The first thing to check is that you have 240 v
, the dryer will run with 120v but the element need 240v to heat. It could be the element its self or a thermal fuse. hope this helps.
brent
Sep 30, 2008 | Dryers
Sony STR-DE598 Receiver Logo
62 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
