I have some problem on my PC which is running window XP pro. When I switch on my pc. It will prompt me the message below: ''Overclocking failed. Please enter setup to re-configure your system. Press F1 to run setup. Press F2 to load default values and continue.'' Please tell me solution for that
  • 11,800 Answers
The BIOS settings are wrong. Press F1 when the pc starts to enter in the BIOS then on there you will see the Load default settings option: select it, Save and Exit. If the problem isn't fixed then you have some jumpers on the motherboard that are switched wrongly - take them all out and try again.
Posted on Nov 12, 2010
PC HANGS ON BOOT
Try running the Check Disk Utility.
To run the check disk utility you will need a repair disc ora operating system disc. Put the disc in the cd drive and boot fromit. You want to get to the Dos Command Prompt (Black screen with whiteletters) and type the following command: chkdsk /r
Check disk will run well over an hour or two and you will notice thepercentages going from high to low, this is normal. Let it run tocompletion. Then reboot machine.
If check disk fails to solve your problem you might have to reinstall windows.Try doing a Repair Install that way you don't loose your data, documents,music, pictures, videos or programs.
In windows xp you get to the dos command prompt by selecting R for repair whenthe options appear.
In Vista and Windows 7 you want to get to the recoveryconsole and look down at the bottom of the window for the Dos Command.
Feb 18, 2012 | Computers & Internet
Error message at start up. Running windows xp. HP Pavilion a700N PC desktop. The message is: This application has failed to start because hpzjrd01.dllwas not found. re-installing the applicationmay fix...
To fix hpzjrd01.dll errors occurring due to corrupt or incomplete installation of HP printer software, uninstall your printer driver and reinstall it again.
To ensure the HP printer software is completely uninstalled from your system, we recommend you either use the built-in Add or Remove Programs utility or use the help of a third-party uninstaller, such as Perfect Uninstaller.
for more information and help click here hope this helps you.
Thanks
Michel
Dec 18, 2010 | HP Pavilion A700N (PJ516AA) PC Desktop
I have a Dell laptop - Inspiron 9300 - running Windows XP. When turning off the computer I get a message that RpinstallerFinder.exe failed to initialize correctly. How do I fix this problem?
Download, install and run Malwarebytes (link below) and remove anything it finds ( just follow the prompts)
http://download.cnet.com/Malwarebytes-Anti-Malware/3000-8022_4-10804572.html
Jul 22, 2010 | Dell Inspiron 9300 PC Notebook
Cannot install business plan pro version 11.0
Windows XP Service Pack 3 (SP3) The latest version of Business Plan Pro 11.0 will install and run in Windows XP with Service Pack 3 (SP3).
If you're installing the software from a CD, you may not have the latest version and could encounter a message during the installation that indicates you need Windows XP with Service Pack 2 installed. Downloading the latest installer from our website will resolve that problem.
Resolution
Take the following steps to download the latest installer and use it to install our software:
  1. Click the link below to go to the Software Download page of our website:
    http://www.paloalto.com/download_software
  2. Enter your Business Plan Pro 11.0 serial number and the email address you use for registrations, then click Go
  3. Accept the License Agreement and click the "Continue to Downloads" button.
  4. Once you reach the downloads page, you should be prompted to either Open or Save the installer file. Choose to Save this file to the Desktop of the computer.
  5. Once the download completes, choose to Open or Run the file to install the latest version of the software on your computer.
May 06, 2010 | Palo Alto 8042249 for PC (756087001880)
I get a weird message when I try to boot up my computer. it is
Sounds like a failed windows update crashed the operating system. If Vista, boot to the Vista DVD, select the option to repair your computer and see if that will resolve, repeat running the repair process until it reports no errors.
If windows XP, boot to XP CD, press R at 1st prompt, run CHKDSK /R and see if that fixes the boot process.
If those fail, then you might have some luck with a repair of your Windows Installation from the Windows CD
Jan 11, 2010 | Dell Inspiron 1525 Notebook
Win 32
seems there is a infection in your system.
Run this command from command prompt and paste the putput here.
1) to start command prompt .
start => run => cmd.exe
2) type below command the copy the output.
cd \
dir /a auto*
3) paste the output here.
Jul 12, 2009 | Microsoft Windows XP Home Edition English...
OverClocking Problem when startup my system
Most motherboards have settings that allow the board to try and overclock itself upon bootup. Take a look in your manual and it should lead you to the correct setting in the bios that will allow you to have the computer boot up in normal mode. Failing that, you may have to force the motherboard back to the default setup. There is a jumper you would have to move, then you would remove the battery from the motherboard. Check your manual for how to clear the CMOS settings if you need to do that step.
Jul 10, 2009 | Computers & Internet
Internet explorer will not allow to go to secure settings
Cause:
  1. Keyboard issue
  2. Miscellaneous corruption
  3. Corrupt boot.ini file.
  4. Missing boot.ini file.
  5. Missing or corrupt ntoskrnl.exe file.
  6. Windows NT installed on a partition bigger then 7.8GB
  7. Corrupted hard disk drive or severely corrupted Windows
Solutions
Before trying any of the below recommendations it's recommend that you attempt to load the last known good configuration.(this can be done by tapping the F8 key while booting and selecting last known good configuration)
  1. Insert the Microsoft Windows XP CD into the computer. Note: If you have a system recovery CD or restore CD (not a Microsoft CD) these steps will likely not work for your computer.
  2. Reboot the computer with the CD and press any key when prompted to press any key to boot from the CD.
  3. Once in the Microsoft Setup menu press R to open the recovery console.
  4. Select the operating system you wish to use; if you only have Windows XP on the computer you will only have one prompt.
  5. Once prompted for the password enter the Admin password and press enter.
  6. Once at the command prompt type bootcfg /rebuild to start the rebuild process.
  7. The rebuild process will step you through a number of steps depending upon how many operating systems you have on the computer and how the computer is setup. Below is a listing of the common steps you are likely going to encounter.
    * Prompt for the identified versions of Windows installed. When you receive this prompt press Y if the bootcfg command properly identified each of the Windows operating systems installed on the computer. It is important to realize this command will only detect Windows XP, Windows 2000, and Windows NT installations.
    * Prompt to enter the load identifier. This is the name of the operating system for the boot.ini. For example, Microsoft Windows XP Home users would enter "Microsoft Windows XP Home edition".
    * Prompt to Enter OS load options. When this prompt is received type /fastdetect to automatically detect the available options.
  8. Once you have completed all the available options in the rebuild and are back at the prompt type exit to reboot the computer.
If the ntoskrnl.exe file is corrupt or missing this can also generate the error. To restore this file follow the below steps.
  1. Insert the Microsoft Windows XP CD. Note: If you have a recovery CD or a restore CD and not a Microsoft Windows XP CD it is likely the below steps will not resolve your issue.
  2. Reboot the computer, as the computer is starting you should see a message to press any key to boot from the CD. When you see this message press any key.
  3. In the Microsoft Windows XP setup menu press the R key to enter the recovery console.
  4. Select the operating system you wish to fix, and then enter the administrator password.
  5. Type expand d:\i386\ntoskrnl.ex_ c:\windows\system32
  6. You will then be prompted if you wish to overwrite the file type Y and press enter to overwrite the file.
  7. Type exit to reboot the computer
Attempt to check the hard disk drive for any errors by running the chkdsk error. To do this follow the below steps.
  5. Once at the recovery console type chkdsk /r
  6. Once completed type exit and see if issue is resolved.
Jun 04, 2009 | Gateway GT5656 Desktop PC
Computer began to intermittentally give error message quit workin
A noisy hard drive is never a good sign. It sounds as if the drive is failing or has failed. You didn't say what operating system you have, but let's try....
You can try the following but it may not yield much. If, after these steps, the PC does start up, try to copy as much critical information as you can to either CDs, DVDs, flash drives or whatever you have.
Start the PC
During the boot, you should see a message to press the F2 key to enter setup - press the key when you see this. You key might be different, but press the one it says to press.
When you get into setup, find and change the boot sequence so that your CD-Rom looks first for an operating system
Insert your backup operating system disk - I hope you have that.
If you are not comfortable working with your PC at this level, it's usually best to take it to a repair shop. The advantage here is that even if they can't get the PC to run, many shops can still recover at least part of your data unless the drive is really destroyed.
The disadvantage is the cost - which can vary widely.
Now see the directions below:
Running Recovery Console without installing it If you cannot start your computer, you can run the Recovery Console from the Microsoft Windows XP/2000 startup disks or the Windows XP/2000 CD-ROM.
To run the Recovery Console from the Windows XP startup disks or the Windows XP CD-ROM, use the following steps:
  1. Insert the Windows XP startup disk into the floppy disk drive, or insert the Windows XP CD-ROM into the CD-ROM drive, and then restart the computer.
  2. Click to select any options that are required to start the computer from the CD-ROM drive if you are prompted to do so.
  3. When you're prompted to press F6 for mass storage devices - press F10 instead. This will automatically start the Recovery Console.
  4. Alternatively, when the "Welcome to Setup" screen appears, press R to start the Recovery Console.
  5. If you have a dual-boot or multiple-boot computer, choose the installation that you need to access from the Recovery Console.
  6. When you are prompted to do so, type the Administrator password. If the administrator password is blank, just press ENTER.
  7. At the command prompt, type the appropriate commands to diagnose and repair your Windows XP installation.
Apr 05, 2009 | Gateway Profile 4 All In One (MPN...
Oc failed
in this case i assume the 'OC' is refering to the overclocking facility in your bios, so firstly press F2 or Del when your pc is booting up and, unless you have changed any settings to cause the fault, look in the cmos settings for 'Load Default Settings', save settings and exit for a reboot and see if the same message pops up. If so you may need to check the memory is seated correctly and any other peripheral connected to your motherboard, assuming it is a desktop pc. Isf still no change try resetting the bios by way of a terminal called CLRCMOS or CLR CLK or JBAT1, but you will have to refer to yourmotherboard manula or post the board details back here.
Aug 14, 2007 | Microsoft Windows XP Professional With...
Computers & Internet Logo
73 people viewed this question
David Payne
David Payne
