Question about Frigidaire GL30LKEC (LP) Grill
My grill is falling apart.
I was cleaning my grill today and saw that in the inside where all the gas comes out (The tubes with all the little holes in it) is all crumbling and falling apart. Is there a way I can replace that?
  • 2 more comments
  • Anonymous Oct 22, 2008
    two of my burner tubing are cracked. how do I replace?
  • Anonymous Jan 21, 2009
  • Anonymous Apr 12, 2009
    burners rotted out in 3 years only used weekends in summer always covered
  • Minnmom Apr 24, 2009
    This seems to be a common problem with this grill. If I can't fix it, because they won't sell me the parts, what do I do?
  • Frigidaire Master
  • 5,568 Answers
I don't know in which country you reside so maybe you can or can't.
I have seen replacement burners in both Home Depot and Lowes 'home improvement centers.'
Your grill was probably not made by Frigidaire but one of the major grill manufacturers so you may need to do some research to determine what you need.
Posted on Jun 17, 2008
Husqvarna 55 rancher-just put new piston ring and cylinder.saw start right up and idles.when i try to acellerate it bogs and try to stall.when I let off gas it idles fine again.I tried turning mixture...
The plastic carb mount has a hole and a slot, this is the pulse channel from the cylinder to work the pump diaphram in the carb, if you look behind the plastic plate there is a tube that fits into the cylinder under the black induction rubber, this feeds a positive and negative pressure to the carb as the piston rises and falls, make sure you have re fitted the small seal in the cylinder that seals this tube or you will have big running problems.
Let me know if you need more help.
Mar 02, 2011 | Husqvarna , No.455 Rancher, 20" Gas -...
Yellow flame
You may have a rusted, clogged or damaged burner or venturi tube. With a flashlight, check for spider webs, wasp nests or dirt (mud) dauber nests in the opening of the venturi tube where it connects at each gas valve orifice. Clean it out manually or blow it out with air compressor. Make sure the air adjustment opening (on the end of the burner's venturi tube) has not been changed. If it's closed too much, it will be difficult to light and cause lazy yellow flames. If it's not clogged, the burner may just be old and rusted and the burner holes are not allowing very much gas through anymore. It's also possible the burner has rusted so bad, the burner holes have been enlarged, it is falling apart or has cracks along the burner seams. If so, replace the burner(s) immediately. It is unsafe to use. Your local propane co can usually order the parts you need and some will even do the work, if you are uncomfortable doing it yourself. Bring with you the Make, Model and Serial number of the grill, so they can order the correct parts for your specific grill. Also specify whether it's natural gas2_bing.gif or propane.
Jun 06, 2010 | Char-Broil CharBroil Master Flame Gas...
Gas grill, yellow flame how do we adjust this
I've got the same grill and was having the same problem - yellow flames coming out the front vents above the knobs. I removed the four burner tubes and they were full of soot and ash. The tubes were still in good condition so I simply knocked them with a screwdriver and a ton of black soot/ash came out. All the screws that hold them in place were so corroded they were falling apart so I had to drill them out. I cleaned everything up, put it back together with new screws and it works perfectly - nice blue flames!
Apr 14, 2010 | Char-Broil Commercial Stainless Steel...
My kenmore elite dryer is not heating enough
1st of all , is it gas or electric ? The 2 main reasons for poor drying are: the vent line is too long or is clogged and not allowing good air flow. This assumes you cleaned the filter and that there are no obstructions of lint in the dryer discharge air tube. Also, check the inside rear air grill that the 100 little holes are not clogged. This takes patience to unclog each little hole if they are clogged.
2nd reason : many times a dryer is blamed for poor drying , but the problem is the washer machine that is not spinningvery well to spindry the clothes and they come from the washer too damp and therefore cause the dryer to work much longer. Goodluck, Macgivor
Jan 16, 2010 | Kenmore Dryers
Unit is 3 yrs old and used weekly. Starts and
Inspect the fuel line in the tank, it should be long enough to fall to the bottom of the tank whatever the operating position. It sounds like it may not be picking up fuel in a certain position.
Nov 09, 2009 | Homelite Leaf Vac Attack
Main burners on blue ember work fine but the crossover tube at back doesn't. the flame pops and only comes out the top, not the port holes
Grease buildup or food particles in end(s) of carryover tube(s).
Clean carry-over tube(s) with wire brush.
May 09, 2009 | Fiesta Blue Ember Gas Grill
Some holes are plugged on burners and i need to clean
I know on some grills you can use a tooth pick to clean out the tiny holes that are plugged.
Mar 15, 2009 | Weber Summit Silver B Grill
Grill will not light / jenn-air
blow out all the gas tubes, sounds like you have spider webs in them.
Jul 27, 2017 | Jenn-Air JLG7130A
The gas is coming through, but does not light.
I have the same grill,and sometimes the same problem.First,with the gas off or completely disconnected,remove the grill grates and the flavor bars from the grill.Now you can see the heating element.A small wire brush will do the trick.Gently clean all the little holes in the element where the gas comes out.Then,with compressed air or even canned air(like what you use to clean a computer with)blow out the holes you just cleaned.Reassemble the grill and light.Should work fine after that.
Dec 28, 2008 | Weber Genesis Silver B Grill
Cant get the burners to stay lite.
Spiders like to create little hidey webs in the tubes of propane grills and stoves.
Take it apart as much as you can and blow compressed air through all of the holes and apertures. You can either take it to the gas station and us the $.25 air machine or buy a can of compressed air at your computer store.
Apr 13, 2008 | Grilling
Frigidaire GL30LKEC (LP) Grill Logo
215 people viewed this question
Top Frigidaire Grilling Experts
Paul Carew
Gary Kenady
Gary Kenady
Dan Webster
Dan Webster
Are you a Frigidaire Grilling Expert? Answer questions, earn points and help others
