Question about Welding Tools
Need manual for uni tig 150 jn thanks - Welding Tools
The settings for welding aluminium using a Tig200P AC/DC inverter
If you are using a remote then you would set the machine in standard for controlling output and also to AC output, HF tig, contactor and control in remote position. I don't know if this helps or not but I pulled it from an owners manual.
1/16" (.062) - pre-flow .1 sec., hot start 20, amperage 70, Hz 100, balance 20%, post-flow 6.0 sec.
For pulse settings - set pulse width 60%, peak current 100, background current 30, Hz 1.0
1/8" (.125) - pre-flow .1 sec., hot start 20, amperage 150, Hz 80, balance 20%, post-flow 6.0 sec.
For pulse settings - set pulse width 60%, peak current 150, background current 50, Hz 1.0
3/16"-1/4" - pre-flow .1 sec., hot start 20, amperage 185, Hz 60, balance 20%, post-flow 8.0 sec.
For pulse settings - set pulse width 60%, peak current 185, Background current 125, Hz 1.0
Mar 14, 2014 | ARC Thermadyne Inverter Stick/TIG Welder...
No Hf start on messer grieshiem ac/dc tig 150
never heard of this as i always strike a arc ,its comes with experiance and you do not even know your doing it .But this could be a new idea that i havent come across on my old machine
Dec 10, 2011 | Welding Tools
Parts manual Radnor 17FV
Hi:
Radnor is a registered brand by the gas company Airgas, but any schematics of a 17V F tig torch will do here it is: check Page two, part numbers are standard for all torches.
http://www.ckworldwide.com/form105/p2_3.pdf
Have a great day.
Jul 14, 2011 | Head Radnor Model 17FV-12-R 150 Amp Air...
Hello, Where can I get a users/owners manual for Linde UCC 305
Jessie email the owner of this site and see if he can't hook you up. He worked for Linde for 25 years.
http://weldingweb.com
Mar 12, 2010 | Welding Tools
Linde welding machine when welding in tig mode foot pedal will not control amphere output it goes from 0- 100 no in between
Check to see if the remote switch has been set, or if you have broken wire in your pedal lead. You might even want to open the pedal housing and take a look see. I've had more than my fair share that the contacts inside the pedal housing were worn or cooked. Good luck, hope it helps
Sep 03, 2009 | Welding Tools
Arc start board
At your nearest Miller distributor (almost all gaz reseller)
Jun 03, 2009 | Hobart Welders Champion 500433A Factory...
Thermal Arc Welder 150 GTSW went ''pop''
You badly need a service manual, you might be able to get one at the Thermal Arc home page.
Since it blew the input power breaker and let off a bit of smoke we'll take as given that something in there shorted. Inverter welders like this have a rectifier section, then an inverter section, then another rectifier section before the torch. I'd bet a little money that what went pop was one or more of the SCRs in the rectifier section. You really need the manual to do anything useful to this machine, pay particular attention to the repair sections where they talk about cold checks before powering the machine on again, it'll save you hours of replacing parts.
Please rate my answer,
Carl
Nov 15, 2008 | Welding Tools
Welding Tools Logo
87 people viewed this question
Top Welding Tools Experts
Bill Boyd
Are you a Welding Tool Expert? Answer questions, earn points and help others
