Question about Sony DW-U18A DVD±RW Burner
DVD WILL NOT EJECT.DISK MAY BE JAMED INSIDE. - Sony DW-U18A DVD±RW Burner
  • Sony Master
  • 32,281 Answers
There is a tiny hole just below the CD tray. Straighten a paper clip and insert it into this hole and push it in gently and the tray will pop out. then you can pull the tray out fully to access your CD.
Posted on Nov 12, 2010
My dvd player is stuck on one dvd and wont let me eject, change disc, or even stop the current dvd. display reads "locked" whenever i press any buttons. can only turn on and off the device.
Hi, For some reason the disk will not play. You push the eject button over and over again, but the disk slot will not open. Here's one solution...
* 1 Turn off the DVD player. Wait a few minutes, turn the DVD player back on, and
then press the "eject" button. If this does not work, turn it off and unplug
the DVD player...while you keep pushing EJECT button plug the DVD and turn it on (your hand still on the eject..) is should come out..
* 2 ..if it does not eject , unplug the DVD player again, Remove the screws off DVD on the sides and take off the DVD casing.
* 3 Look for the DVD holder inside the DVD player. This device holds the DVD in
place while the DVD player reads the disk.
* 4 Push the stuck DVD disk toward the front of the DVD player until the DVD
ejects. Remember the DVD player is not on and some force ( gentle ! ) must be applied.
* 5 While it is open,plug it on and place a DVD disc just to see if mechanism works properly..
* 6 Replace the casing and the screws. Plug the player in and turn it on. Put
another DVD in to test whether the player is finally working ..
Hope this helps!..
Take care and please
Remember to rate/vote and give us 4 Thumbs Up
to continue f
or Helping out the Community :)
Jul 09, 2011 | Televison & Video
Tip
DVD player in my home theater system won't eject the disk inside.
When a disk is stuck inside the player , try following the procedure below:
Unplug power cord.
Plug back power.
Turn on the unit and press repeatedly the eject button at the same time. If you successeed in ejecting the disk before the player starts reading TOC(disk initial track), then the disk will eject.
If that does not work, then there is an internal fault, in that case the unit must be disassembled to remove the disk.
on May 04, 2009 | Philips HTS3450 System
Rosen g10 disk error and dvd will not play
something is jamed inside dvd player or its dirty need disc cleaner.
Feb 17, 2011 | Rosen G10 Car DVD Player
Dvd will not eject and noisy
To eject, put a staple on small orifice on the front.
Or, by the Explorer window, go to letter of DVD, and with right mouse button, click on "eject".
Have any disk inside? Maybe the disk have some problem to do the noise.
Sep 18, 2010 | Acer (91.42R37.001) CD-RW/DVD-ROM (Combo)...
DVD stuck inside sony dav-sc5. Pressed the eject button and nothing happened. Did the usual turn it off and on again and it started to read the disk but then nothing happened. Tried to eject it and nothing...
Have you tried to unplug the unit for 1 or 2 minutes to see if it can reset the computer chip inside of the DVD player?
I have had great sucess with this trick.
I hope that this helps you out of this situation.
asnowman
Feb 08, 2010 | Sony DAV-SC5 System
Disk holder does come out to accept a new DVD
Your disk holder has stuck up inside if you want to eject it out the go to the my computer and right click on the cd/dvd drive icon and then click eject it will automatically come out. Thanks and please rate.. :)
Jan 04, 2010 | Gateway SX2800-01 PC Desktop
Dvd writer/cd writer will not eject the cd
Look at the drive where you normally eject the disk you will see a pinhole near the button now get a needle or a pin and insert it inside the hole and push slightly and this will eject your disk. You can also open My Computer and right click your dvd drive and select eject.
Dec 30, 2009 | HP Pavilion a620n (PC028A) PC Desktop
Cd jamed will not eject
Force disk eject. Press and hold down the Eject button on the front of the PS3 for about 10 seconds to force the system's drive to eject. ...
hope this helps ^_^
Sep 13, 2009 | Sony Playstation 3 (PS3) Console
Toshiba Regza 32 inch with DVD player - won't eject
Disconnect cable from DVD to TV, press play, and then press stop, try to push eject button to get the disk out. If all could not have, you have to open the DVD cover then get the disk out.
Aug 18, 2009 | Toshiba Regza 32LV67U 32 in. LCD HDTV
Wii console
Im not familiar with the Wii but i will try to help.
Is it just not opening or is it actually physically Jamed?
If its jamed, try turning it upside down and then back to right side up, then try ejecting it.
There may be a pin hole on the front of the drive, just like a computer cd drive, get a thick paper clip and insert it, push hard till the drive pops slightly open, then pull it the rest of the way and remove the disk.
Last resort is to open her up and remove the disk drive altogether and then take apart the case, then you can use your finger to move the disk back onto the carasel and then eject it once its plugged back in.
Mar 25, 2008 | Nintendo Wii Console
Sony DW-U18A DVD±RW Burner Logo
71 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
