Question about Pioneer FH-P800BT Car CD/ MP3 Player
My pioneer won't turn on in my car. I have the wiring harness and all thst plugged together but it won't turn on
    Scholar:
  • 143 Answers
What car? make? model? what year?
check feeds at terminals and then fuses if no voltage.
if it is a modern car and has MOST connectors and not ISOs, then it may not have an ignition on/off
as modern cars use a CAN-CODE on/off.
Posted on Nov 12, 2010
I don't have a wire harness for my Pioneer car radio DEH 780 MP and it's a 14 pin iso connector I need the diagram so I'll know what color wire to put in the right place for it
Walmart and some auto parts stores have installation kits that have the plugs already wired for your radio and vehicle harness. You simply connect them together.....no cutting or splicing.
Mar 16, 2016 | Pioneer Car Audio & Video
Pioneer DEH-3300 UB
Apparently, you have no power at the 12 volt battery/memory wire at the radio harness of the vehicle. This wire is white with blue in color.
Also, based upon your description, you have connected the battery/memory wire and the accessory wire of the radio to the 12 volt accessory (switched) wire of the vehicle. This wire is white with red in color.
Check the radio/ stereo fuse of the car. You may have blown the fuse during your installation.
You have no memory at the radio because when you turn off the key, you lose all power to the radio.
Also, I mentioned the wire colors just in case you used an aftermarket radio wiring harness. Make sure that the yellow from the Pioneer unit is going to the battery power source and, the red of the Pioneer is going to the switched power source.
Sep 12, 2012 | Pioneer Car Audio & Video
Installed Pioneer DEH-1200MP, won't turn on.
sounds like yours acc (red wire) is not connected
Aug 23, 2011 | Pioneer Deh-1200mp Car CD/ MP3 Player
I dont know how too hook up a remote wire for a amp for subs
there is a blue wire on back of deck with white stripe thst is the remote hook a wire to that and run to amp plug in to remote on amp and there you go i hope this helps you
Jul 10, 2011 | Pioneer DEH-P700BT Car CD Player
Replacing car radio (JBL) with a Pioneer (DVD) Toyota Sequoia
I have used what is called a toyota car harness to iso adapter for this sort of thing .
aerpro APP0141 check at your local auto shop
https://automotivesuperstore.com.au/aerpro-app0141?gclid=Cj0KCQiAtJbTBRDkARIsAIA0a5MqtkIR92nbYhY-M6qqHBjfuaEZVlBE7lJuD_VMtvlU3MCtIRUgNpEaAnfREALw_wcB
it converts your toyota to a international standard ISO and then you buy a Pioneer {whatever model number } to ISO and then you can plug them together and get the radio and car talking to one another.
Jan 22, 2018 | Pioneer Car Audio & Video
I want to change my original cd player for a pioneer
This is because you need to purchase the aftermarket-oem harness plug.This harness plugs into your original equipment radio harness and allows you to plug any aftermarket radio into the stock deck wires.After you plug the harness in you can then connect the radio wires together.Your local autoparts store or circuit city or best buy or audio express will have these radio conversion plugs.I hope I could help
Dec 24, 2009 | 2003 Ford Explorer
Pioneer DEH-P3300 and 94 Mazda
Hello ryan_jaime,
It's good that you have an aftermarket Mazda wiring harness. It will allow you to make all of the connections in a well-lighted and comfortable location rather than fumbling around behind the dash.
If you are somewhat skilled at soldering, the most secure, electrically conductive, and positively insulated splices are made with solder and heat-shrink tubing. You can get the needed equipment from any Radio Shack, Lowe's or even WalMart. Be sure to put the heat-shrink tubing on the wires BEFORE you solder them together. I had to say that! Because I've forgotten many times! But if the soldering route is not for you, get properly sized insulated inline crimp splices and the appropriate crimping tool. Match up each wire by function on the Pioneer harness with the corresponding wire on your aftermarket harness. Most of the time, the wires will be color-for-color matched. But make sure, sometimes wires for things like "illumination", "dimmer", "mute", etc may not be the same colors.
Disconnect the negative battery terminal while you are working behind the dash. After you have the harnesses spliced together, plug the radio end into your Pioneer, remove the old radio from the dash opening, unplug the antenna and wiring harness plug and plug the other end of your spliced harnesses into the vehicle plug and the antenna plug into your Pioneer's antenna connector. Slide the Pioneer loosely into the opening, but don't secure it yet. Reconnect the negative battery cable and test the receiver. If everything works, slide it into the dash opening and secure it. Use the rear support stud and rubber bumper if needed. Install the trim ring or separately purchased dash kit as required. Put the "face-fixing" screws in to prevent removal of the faceplate if desired. Reinstall any dash trim removed and you're finished.
Hope this helps.
Jul 08, 2009 | Pioneer DEH-P3000 CD Player
Conection
to install this unit in your car........as a beginner i would strongly recommend buying a aftermarket radio harness (this harness will attach to the wire plug in your factory deck simply unhook the factory player and attach this harness to the plug you just pulled out of the factory unit) once this harness is installed on the factory plug it will be a simple colour match (just attach wires to pioneer wires IE. red - red, white - white........once all the wires are attached install in dash recommend buying a mounting unit for this net part it will hold the deck in place in your dash...........after that is done install your pioneer unit push it in place apply power by turning car on..........pioneer deck should turn on and work if it does not turn right on look for a source button on the pioneer unit and hold it down till the unit turns on
good luck
hope i was able to help
Mar 05, 2009 | Pioneer KEH-P6600 Cassette Player
Got a new deh-6000ub and wire harness for honda accord dont know how to install the harness
You need an installation harness. You can get them at most anyplace that installs car stereos. Once you have the installation harness for your car, you just match up the colros of the wires on it to the same colors of the harness for the Pioneer. Make sure that each wire is insulated from anything by using some electrical tape and make sure they all have good connections. Strip away close to about an inch on each wire and then twist them together and then tape them good. After all the wires have been connected, all you need to do is plug the Pioneer harness into the Pioneer radio and then plug the installation harness into the factory wire harnees connector in the car. If you have any wires that do not match up in color, you can normally leave then not connected to anything, but make sure they are insulalted with electrical tape. Most all the wires should say what they are for. Matching the colors is the easiest way to do this.
Let me know if you need more help. I can always give you a detailed wiring of the Pioneer. I do not have the wiring diagrams for the car though.
Jul 20, 2008 | Pioneer Car Audio & Video
Wiring/Installation of Pioneer CD Player
You need to get an installation kit that also has the universal wiring harness to connect to the factory harness in the car. That way you only need to match the wire colors of the Pioneer harness to the wire colors of the universal harness and made good connections and insulate those connections. Then the Pioneer harness plugs into the Pioneer radio and the universal harness plugs into the factory harness in the car.
Let me know if this helps, or if you need more help.
Dave
Jul 06, 2008 | Car Audio & Video
Pioneer FH-P800BT Car CD/ MP3 Player Logo
90 people viewed this question
Top Pioneer Car Audio & Video Experts
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
