How can I make my router undiscoverable? Bluetooth has this option, what about routers? I have a Linksys WRT120N, Vista 32 on all laptops.
  • hklotus Nov 12, 2010
    Thanks! It works, although my user name isn't blank, it's 'admin' while the password is something that I set when I installed the router.
  • 6,487 Answers
If you want your router wireless signal not being seen by any wireless device that is possible to do on any wireless router where you can disable the broadcasting of the wireless name of it.
To do that you need to access the router setup page, by typing its IP address on a address bar of your web browser. For this router the default IP address of it is 192.168.1.1 and once you put it on the address bar and hit enter that should bring you to a log in page just leave the user name blank and password is admin.
Then once you're on the Linksys router setup page , you can go to the Wireless tab and from there look for SSID broadcast just disable that option and save the settings and that's it no wireless device can detect the sign from it making it hidden.
Posted on Nov 12, 2010
Factory restore
According to Linksys support, you should not reset your WRT120n wireless router unless you are having difficulties with the unit. The WRT120n user guide also recommends applying other troubleshooting options before attempting to reset the device. Resetting the WRT120n restores the router back to factory defaults. After resetting the Linksys 120n, you''ll have to reconfigure the router back to your preferred settings.
Locate the Reset button on the back panel of the WRT120n. The button is labeled "Reset" and situated between the power port and the "1" Ethernet port. Press and hold down the "Reset" button for five seconds. The device resets. Open a Web browser on your computer. Type "192.168.1.1" into the browser's address field, then press "Enter" on your keyboard. A login prompt opens. Enter "admin" as the password. Leave the User Name field blank, then click "OK" to log in to your router and access your network settings.
Apr 02, 2013 | Linksys WRT120N Router
Forgot my password for wrt120n
Looking for the Linksys WRT120N default password? You probably have little reason to access your router on a regular basis so don't feel too bad if you've forgotten the WRT120N default password.
However, when you're troubleshooting a network problem and need to get in to the device, the WRT120N default password suddenly becomes very important.
For most versions of the Linksys WRT120N, the default password is admin. As with most passwords, the WRT120N default password is case sensitive.
In addition to the WRT120N default password, you can also see the WRT120N default username and WRT120N default IP address in the table below.
Note: The Linksys WRT120N default password may be different for certain hardware orfirmware versions.
If I have that information, I'll include the exact WRT120N version number along with the correct default password. You can usually find your Linksys WRT120N version number on the bottom of the router.
Be sure to change the default router password on your WRT120N to something more secure as soon as you're in. Then use a free password manager so you'll never forget your new WRT120N password.
Help! The WRT120N Default Password Doesn't Work!
At some point during the life of your particular Cisco Linksys WRT120N, the default password, username, and/or IP address might have been changed.
In most cases, if the Linksys WRT120N default IP address has been changed, the new IP address for the WRT120N will be the same as the default gateway IP address configured for your network connection.
See How To Find the Default Gateway IP Address for help.
In situations where the WRT120N default password or WRT120N default username has changed, you'll need to reset the Linksys WRT120N to factory defaults. You can usually do that via a special button or sequence of actions.
The WRT120N manual will have specific directions for performing a factory default reset. You can download the manual for the WRT120N from Linksys Support.
Please let me know if any of the WRT120N default login data below needs updated. For other questions about the WRT120N default information on this page, see my Default Password FAQ.
WRT120N Default Password & Other Default Login DataVersionDefault UsernameDefault PasswordDefault IPPrivilegesAll[none]admin192.168.1.1Administrator
Jan 13, 2012 | D-Link 802.11g Wireless Router WBR-1310...
Where can i download a free installer for linksys wifi router with model # wrt120n
Are you trying to install WRT120N router?
You can do it manually without CD.
Connect the computer to the router. open the setup page and change the settings manually.
See how to setup Linksys WRT120N router
Oct 13, 2011 | Linksys WRT120N Router
Can not access the browse button for firmware upgrade for Linksys wrt120n router
When connected only with WAN,
Enable the remote update option under managment.
Sep 03, 2010 | Linksys WRT120N Router
WRT120N how to enable wireless option
Wireless should be enabled by default on the router. Check whether you have switched on wireless on your laptop.
Please rate if helpful.
Thanks
Apr 13, 2010 | Linksys WRT120N Router
Computers & Internet Logo
574 people viewed this question
David Payne
David Payne
