Question about Sansui HDLCD3210 32 in. LCD TV
How do I connect my asus laptop to my sansui hdtv hdmi? what cords do I need and do i need to do something special with my computer?
  • Sansui Master
  • 8,457 Answers
No,try websites like Ebay.com or Amazon.com to buy a HDMI cable.Plug the HDMI cable in ur computer USB hub and the other side of the HDMI cable to the tv HDMI hub.Go into tv menu goto the tv find the wright input of the HDMI cable is in ur tv input there it is ur LCD Tv as a computer monitor.
Posted on Nov 12, 2010
Tip
How to connect pc to tv
I’m writing this post on how to connect your PC or computer to a TV because last week I returned from a trip in India and wanted to show all of my pictures and videos to my family from my laptop onto our HDTV, but unfortunately I did not have the correct cords and so after fumbling around for 30 minutes trying to connect my computer to the TV, I had to tell everyone that they would have to wait till the next weekend! Pretty annoying considering the times we live in, it should be quite easy to connect the two together!
So here’s a quick walk-through of all the methods that I know (if you know any more, please comment) to connect a laptop or PC to your TV:
1. S-Video – This is probably the most common method out there currently because an S-Video cable is cheap as heck and just about every TV under the sun has a S-Video port. You’ll have to make sure you laptop is equipped with this port. Remember, there are two types of S-Video cables: 4-pin and 7-pin. Most laptops and PC’s are equipped with a 7-pin port, so if your TV only has a 4-pin S-Video port, then this method will not work.
2. VGA – If you have a HDTV, then you will be better off connecting using a VGA cable. It gives much better quality than S-Video and as with S-Video, the cable is very cheap. You usually won’t find a VGA port on regular TV’s though, so this option is if you have an HDTV.
3. DVI - DVI stands for Digital Visual Interface with “digital” being the key word there. The digital signal will give a higher quality picture than either S-Video or VGA. Of course, your computer will need to have a DVI connection and your TV will need to be an HDTV. This cord is definitely not cheap, it ranges anywhere from $40 to $80.
4. HDMI – Using HDMI will give you the best quality by far. No computers that I know of yet have HDMI ports, but you can get a DVI to HDMI cable to connect it to your HDTV. HDMI is compatible with DVI.
5. Scan Converter Box – This is the last method that I could think of and it involves using a scan converter box, which takes a VGA signal and converts it into S-Video or component video.
on Apr 10, 2010 | Computers & Internet
Problem with Dell W4201C 42 in. HDTV Plasma Television
Plug the HDMI into laptop and T.V first then turn the laptop on, I have the same problem sometimes just doesnt read it properly if the laptop is already turned on when plugging in to HDMI. Hope this helps
Sep 05, 2012 | Dell W4201C 42 in. Plasma HDTV
Asus and Sansui hookup "Not Supported"
You may have to study the operation manuals of both.
Aug 19, 2012 | Sansui HDLCD3210 32 in. LCD TV
Connecting my laptop to my sansui 42" lcd tv via the hdmi cable, i get clear picture but no sound
Does your laptop feed sound through the HDMI connection? You may have to use the HDMI 1 jack on the HDLCD3200. Change the HDMI setting in the audio menu on the tv to DVI and run a seperate audio cord from the laptop to tv. I hope this is helpful
May 17, 2011 | Sansui HDLCD3200 TV
I connect my laptop to a projector via hdmi but no display
i connecto laptop my projecto useing display cable but not display
May 22, 2010 | ASUS M50VC-AP012C Notebook
Sansui 42'' HDMI problem
howto get the hdmi signal thro hdmi to dvi cable in plasma pdp42 sansui tv in dvi input
May 03, 2009 | Sansui HDPDP4200 42 in. HD-Ready Plasma...
Watch movies from computer to tv
look on the back or sides of the unit. it should have a hdmi cable hookup, it will look like a monitor input, then you have to make sure you set the tv input to that. then you have to set your laptop to add another monitor to be able to use it.
Mar 20, 2009 | Philips 55PW9363 55" Rear Projection...
PC to TV can't seem to get to work.
okay buddy its esay just give me a good rate!
u select:
1. S-Video - This is probably the most common method out there currently because an S-Video cable is cheap as heck and just about every TV under the sun has a S-Video port. You’ll have to make sure you laptop is equipped with this port. Remember, there are two types of S-Video cables: 4-pin and 7-pin. Most laptops and PC’s are equipped with a 7-pin port, so if your TV only has a 4-pin S-Video port, then this method will not work.
2. VGA - If you have a HDTV, then you will be better off connecting using a VGA cable. It gives much better quality than S-Video and as with S-Video, the cable is very cheap. You usually won’t find a VGA port on regular TV’s though, so this option is if you have an HDTV.
4. HDMI - Using HDMI will give you the best quality by far. No computers that I know of yet have HDMI ports, but you can get a DVI to HDMI cable to connect it to your HDTV. HDMI is compatible with DVI.
5. Scan Converter Box - This is the last method that I could think of and it involves using a scan converter box, which takes a VGA signal and converts it into S-Video or component video.
Feb 06, 2009 | Samsung HLN617W 61" Rear Projection HDTV
Sansui HDLCD3210 32 in. LCD TV Logo
740 people viewed this question
Top Sansui Televison & Video Experts
matt martin
matt martin
Are you a Sansui Televison and Video Expert? Answer questions, earn points and help others
