Question about Toshiba Computers & Internet
I want to buy a low cost toshiba laptop. heard about the colour change the screen n all? is it better to buy?
Toshiba satellite L355d keyboards stops responding seconds after startup??
in that case you better go to a computer repair shop for a diagnostic. depending on repair cost it may be better to buy a new laptop.
Jan 30, 2015 | Toshiba Satellite Computers & Internet
Were in India (gurgaon)can i get my toshiba A Satellite Series screen repaired and what is the cost? The screen has cracked accidentally !
just fyi before you make any decision on laptop screen repairs.. we have found that the screen costs just as much a new laptop (that is if you have a cracked or broken screen). better off buying a new laptop.
this is only valid if the laptop is not under warranty. If it is under warranty best to check the Toshiba website for accredited repairers in your region/location.
good luck hope this helps'
Oct 08, 2010 | Toshiba Computers & Internet
3 purple coloured vertical lines on my Toshiba Laptop monitor
You have a bad screen and it will eventually burn out. This is due to running your screen in a higher res than what the comp was factory set at. Indefinite higher res times shorten screen life by half or better. You will need to replace your screen.
Aug 12, 2010 | Computers & Internet
Brand New Toshiba Laptop Screen won't come on
That state might called comatose, during the shut down the battery gone low, so the system is in a hang state, after recharging to its full, then you power it on and the system try to recall the last status,sometimes needs reset and the system will work, other trick is remove the battery and PSU then push power switch several times to drain residual power and attach the battery and turn power on.If this will not work, the bios might be need reset, in this case you must claim your warranty service.
Sep 02, 2009 | Toshiba Satellite A135 Notebook
Is it time to forklift this monster out?
I'm not completely an expert in projection televisions, but from what i do know about those, it might just be a question of the lenses on the projectors that need to be realigned, or the back mirror plate that has started to phase, warp or just unglue in some cases. So if it is just that then it will cost you a bit less to have it repaired then to buy a new one, but of course if you decide to invest a little more and buyt a new one, i would strongly suggest buying either an LCD TV or a Plasma TV model, as they will cost around the same as a new projection model, if you can find any cause i've heard they are disappearing from the market. Of course though, an LCD model will give a little less warmth and glow to the picture, but will usually cost heaps less for the same screen size, and still deliver something a bit better than the old school HD cathode ray flat screens that came out just before plasma and LCD went in vogue. So it's all a question of how much money you are willing to invest and wether you old TV has sentimental value to you or not, as some people cherish their posessions more than others.
Jul 12, 2009 | Toshiba Televison & Video
Problem with the Toshiba Satellite Pro L300-25L display
it sounds as if your screen resolution is set too high, or you have a low colour. right click on ur desktop and click properties then click settings, make sure your colour quality is "highest 32 bit" try sliding the resolution slider across to try the diffrent settinfs to see if it gets better.
Jul 02, 2009 | Computers & Internet
I have a line going down the middle of my toshiba laptop, any suggestions??
Usually indicates first signs of LCD going out. Must replace monitor or replace parts inside the lcd screen.. Both are costly and the best way is to replace the screen but depending on the age of the laptop you are better off investing in new low end model. Most laptop screens go from 150-250 and newer lower end laptop goes for 400 so tough call.
May 25, 2009 | Toshiba Satellite P105-S6147 Notebook
My toshiba lcd flat screen model 27w l56p has lost all red colour. The tv is not too old 3-4 years
i heard you can get red plasma refill at best buy, im having this same issue
Sep 06, 2008 | Televison & Video
Colour interestingly different!
Change posistor in the degausing circuit.
Dec 22, 2007 | Toshiba 28N33 28" TV
Computers & Internet Logo
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
