How to activate task manager on my pc - Computers & Internet
  • 1,719 Answers
It can be done easily by editing the registry. I will try to explain in detail. Follow these steps
1. Check that your PC is virus free. Install Antivirus program if required.
2. Regisry is enabled. Goto run command from start menu OR Press Win key+R and type 'regedit'. It would show up registry.
3. If registry is enabled you can edit it.
4. Open notepad and paste the following four lines
Windows Registry Editor Version 5.00
[HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Policies\System]
"DisableTaskMgr"=dword:00000000
"DisableRegistryTools"=dword:00000000
5. TYPE the file name ENABLETASKMANAGER.REG
6. Choose 'all files' option from 'Save as type'
7. Now you should have a registry editing patch. Please note that its extension is .reg
8. Double click the patch to add it to registry and task manager would be enabled.
9. Alternatively, you can download PROCESS EXPLORER, whichis a replacement of task manager from internet. It works even if the taskmanager is disabled.
Hope this helps. Let me know if you need any further clarification/ help
CreativeTECH
Posted on Nov 12, 2010
Testimonial: "thanks bravo"
Is my McAfee active?
if you click on the icon on your PC what happens .it either starts or it doesn't and if not then I would think it is not active
Dec 11, 2015 | Dell Computers & Internet
Why thers always prompting in my screen of low memory disk?
open the task manager to see the ram-usage. This series do not have alot of memory, therefore several tasks running at the same time can make this message pop up. You might have to many startup programs activated, change settings to start programs manually.
Oct 08, 2013 | ASUS Eee PC 1000H Laptop
How do I recover from a bad power down?
to start task manager right click in bottom toolbar select start task manager applications you will see whats running also processes you will see whats ticking over
hope it helps
May 10, 2012 | Toshiba Computers & Internet
Sound is not
1) Check the task bar sound icon mute active or not (Tick mark view on mute box)
2) Sound icon not in task bar check device settings.
3) Go control panel > System > Hardware > Device manager
4) Sound, Video, game controllers view problems.
5) Re-install Sound card driver.
Mar 26, 2011 | Computers & Internet
I reduced the volume of my laptop.the next day i turned on my laptop and i could not find the icon volume in my system tray.it desappear and the volume box is gray .how can activated.thanks
Hi micochereami,
You can fix this issue by restarting the "explorer.exe" services. To restart the explorer.exe service, please perform the steps given below.
  1. Right click on the Taskbar and click the "Task Manager" to open it. (You can also press "Alt+Ctrl+Del" or "Ctrl+Shift+Esc" to open the Task Manager.)
  2. In the Task Manager window, please click the "Process" tab.
  3. In the Process tab, locate the "explorer.exe" process.
  4. Once you have located the "explorer.exe" process, please right click and select the "End Process" option.
  5. Then, please click the "File" option in the Task Manager window and select the "New task (Run..)" option.
  6. Then, in the Create New Task window, please type "explorer.exe" and press the Enter Key.
  7. This should fix the issue.
Good Luck!
Please post if you have any questions or require further assistance.
Thanks for using FixYa.
Nov 08, 2010 | Sony VAIO VGN-CS215J/W Notebook
How do you close a streaming video application?
alt+f4 when the application is active in the foreground. or goto "task manager" (ctrl+alt+delete) -> task manager select the program, right click on it, select "switch to process/goto process" and press the "end process" button
Sep 26, 2010 | Computers & Internet
How to get rid of uninstallWizard ,to stop error432, when installing Symantec Win Fax Pro.
Make sure you are installing WinFax PRO with a user account that has administrator privledges.
If you still have problems, reboot the system and make sure that no applications are active while attempting the installation (close Outlook, email, Web browsers, etc) , also look for any _INSXXXX processes that may be active.
  1. Press Ctrl + Alt + Delete.
  2. Select Task Manager.
  3. Select the Processes tab.
  4. Look for _INSXXXX._MP. Where XXXX are numbers. If there are two similar (they do not have to be the same) processes running, select one and click End Process.
  5. Select Yes to the Task Manager Warning dialog.
http://www.getfaxing.com/winfax
Mar 22, 2010 | Symantec WinFax Pro for PC
My cat walked on my keyboard and now I can't stop the voice. Everything I type gets spoken out loud
Looks like your cat has activated the windows narrator feature on your PC.
To turn it off, click on Start, then click on all programs, then click Accessories,then open Accessiblity, then open Narrator. It will be shown as running, click on stop and close the window.
Also, you can turn it off from the Task Manager. To open task manager, right -click on the taskbar, select Task Manager, under Processes Tab you will find utilman.exe. Right-click on utilman.exe, then select End Process, select Yes from the next announcement window, then close the Task Manager.
Hope this solves your problem. Thanks.
Jul 22, 2009 | Apple Computers & Internet
Windows task scheduler and Active Directory
M31.imaut enter my computer.Please how i remove it.
Jun 19, 2009 | Computers & Internet
Minimised
You can Alt+Tab to bring back up a minimized application, or use Task manager to switch to that application (right click on the task bar and select task manager to start it)
I hope this helped...
Feb 28, 2008 | Computers & Internet
Computers & Internet Logo
75 people viewed this question
David Payne
David Payne
