Question about GPS
I have fitted a autometer procycle electronic speedo to fj holden it works o/k till you slow down to stop then the needle flicks up and till it settles down then works o/k what do you think.
  • 2,299 Answers
Where the cable goes down to the wheel, make sure that the sensor is clean. Dirt can cause the signal to jump.
Posted on Nov 12, 2010
I have a LS1 gen3 in a wh holden statesman, the cluster works but the speedo doesntwhen tested on tech 2 i had speedo to the cluster but not to speedo on cluster.please help
More than likely the tiny electric motor that moves the speedo needle has failed, very common issue on GM cars and trucks.
Jul 06, 2016 | Holden Cars & Trucks
Hi have a 92 nissan pulsar n14 gli and the odomiter works and then stops everything else in the das works spedo temp fuel, any ideas it's not the cogs, and where is the relay for these ? checked all...
a comon problem with nissans is speedo &rev counter pointer needles warp and get stuck on the instrument face.if this is happening with yours u need 2 remove the clear plastic face heat the needle with a hair dryer and very gently bend the needle tip out from the speedo face hold it out till needle cools ps.dont over do the heat it wont need much
Sep 11, 2011 | 1990 Nissan Pulsar
Ford fiesta registered yr 2000. speedometer stopped working, it flicked up and down then no movement at all. how can I repair it?
hi this is a common fault on the focus its usally a faulty speedo sensor that is fitted in the gearbox
if you open the bonnet and look bettween the engine and gearbox and towards the firewall/bulkhead
you will see the speedo sensor held in with a small steel roll pin remove the roll pin and pull the sensor out and dissconnect the wires to it and peplace it with a new sensor ,a healthy dose of wd40 penetrating spray will help to get the sensor out
Feb 22, 2011 | 2000 Ford Focus
My 1992 Saturn SI speedometer has stopped working , what is the problem ?
if I remember right, this is a regular mechanical speedo. have a shop check to see if your speedo cable has broken, either at the speedo needle in the instruments, or on the transmission. if there are any electronics tied to the instrument cluster, check for blown fuses and other electronic damage.
Jun 11, 2009 | 1992 Saturn SL2
Bandit 600 speedo
probably your speed sensor gone down its a common problem, its held in with a 5 mil allen key and is located on the front sprocket cover if i rember correctly its a little black box just un bolt it and un plug it ,and fit the new one , hope this helps regards bert.
May 12, 2009 | 2000 Suzuki GSF 600 N Bandit
1996 ford taurus odometer stopped working
the Speedo in your car is electronic, the problem is the tiny motor that moves the needle is most likely defective, there are no parts for the Speedo available to the consumer from Ford, you must remove the Speedo and have it repaired by a authorized Speedo repair shop. here is a link to a good one I know about.
http://dnaspeedometers.com/
Apr 01, 2009 | 1996 Ford Taurus
Speedometer - 40MPH
the speedo is electronic, not cable, this problem is caused by a sticking stepper motor that moves the needle, a stepper motor is a miniature electric motor that can move and hold one position, this was a common problem at the dealer I worked at, u will need to pull the speedo and send it out for repair, I use the following link for this service.
http://www.dnaspeedometers.com/
Mar 23, 2009 | 1999 Ford Super Duty F 450
Speedometer stopped working
it has no cable, it is an electronic speedo, you will need to pull the speedo out and send it out for repair, here is a place that can do the work much cheaper than the dealer. call them.1-888-495-2777
Mar 19, 2009 | 2001 Dodge Caravan
Ford focus mk1 speedo not working after install. of glow gauges
PUT THE NEEDLE BACK ON WITH THE KEY OFF AT OOOOOO
Jan 17, 2009 | 2003 Ford Focus
GPS Logo
Top GPS Experts
Are you a GPS Expert? Answer questions, earn points and help others
