I need an audiologic dvd 108 home theater system manual. I cannot get surround sound thru the amplifier
SOURCE: Sony DVD Home Theater System remote control code
sony dvd surround sound remote codes
Posted on Oct 25, 2008
SOURCE: Sound Problems with HD TV
I have spent the last few days trying to get this set-up properly. Getting closer.
Connect 2 phono plugs (red and white i think they are) from your tv, should be "audio out" then connect the other end of these cables to "audio in" on the samsung. If you choose "AUX" on the "source" on the samsung, you can get anything thats on your TV to play through the surround sound. I'm still having problems with the DVD side of things. I connected them using the HDMI cable and the sound from the samsung plays only through the surround sound, not the TV. You CAN selct HDMI Audio "ON" but then you get no sound through the surround speakers.
Basically connected phono plugs from TV AUDIO OUT to SAMSUNG AUDIO in and you the AUX on the source menu on the samsung. This will play anything on your tv through the speakers.
Posted on Nov 05, 2008
SOURCE: can a durabrand dvd home theater system,model
I have a sts92 system and run the tv sound through it for surround sound. My Tv has an AV out option, so I ran component cable from the AV out on the TV to the AV in on the sts92. When watching TV, turn on the theater system and set the function to AV in.
Posted on Mar 22, 2009
ginko
  • 19396 Answers
SOURCE: sony home theater system started blinking protect
Protect mode will kicking whenever a fault is detected.
Causes that can start protect mode are:
Electrostatic harges on internal circuits.
Leave the unit unplugged for power for one hour or so, this will allow discharge.
Bad speaker wiring.
Check speaker wiring, try unplugging and plugging back, or start after removing one speaker at the time.
Internal fault.
Internal fault is the natural cause for protect mode. If all the above did not work, then the problem is a blown component or an internal fault. In this case the unit must be taken apart , tested and repaired by an experienced person.
If the unit is less than one year old, or if you want to get service, call Sony at the phone number listed on the product documentation.
Regards.
Posted on May 04, 2009
Hook up new blueray thru old home theater system
Yes you can. If you have more than 1 HDMI sources and your old system only has 1 HDMI in, you may want to invest in an HDMI switch. They are inexpensive (under $20 on Amazon) and let you choose 4 HDMI sources to feed your system. The audio is embedded in HDMI and you may have to select the choices (surround versus stereo) when you play the disc.
Dec 25, 2012 | Sony DAV-DZ175 DVD Home Theater System
Needthe remote code to operate Audiologic unit DVD-108 audio system.
The instructions are included with these universal remote
OR
simply go to the REMOTE manufacturer web sitelook up your model of remote and the codes will also be listed
You neglected to even mention the brand of remote so thats all I can give you
Nov 28, 2011 | Televison & Video
Need replacement remote control for "Audiologic 108 DVD" player.
You should be able to use most generic remote controls ad just program it to your dvd player.
Aug 01, 2009 | Audio Players & Recorders
Audiologic DVD-108, music plays, cannot hear regular conversation
This sounds like a setting on your DVD player in its menu settings. You could try a couple of things, first being to unplug it for a couple of moments (5-10 minutes) or going through your menu on the DVD player with the remote or the front of the player. I assume that all of your DVDs have this problem.
Jun 09, 2009 | Audiologic DVCR-251
JVC TH-M45
no, u cant use the speakers with other normal DVD player because it wont have amplification for the speakers... u can use the sub to other dvd player because its inbuilt 120 watt woofer. ur dvd player is 5-disc player as wel as 120 X 2 and 80 X 3 watts amplifier (AV receiver ).... so just the JVC better sound thru the sub and speakers... ENJOY
kanny_amancha@yahoo.com
www.kanny-sounds.blogspot.com
Jan 24, 2009 | Pioneer 1000 Watt 5.1 Surround Sound...
How do I hook the tv up to the speakers?
we had to hook sound cables from DVD player into digital cable box, not tv and now surround works in tv mode as well as dvd.
Dec 26, 2008 | Curtis DVD5091 Theater System
Sl-dv290 i want to plug my surround sound into tv!!
hello only if your tv is the same brand as you dvd home......i think in this case you can not...this is why the output on the rear tv deliver only the signal to be amplified by any other device example a dvd.amplifier..etc saludos
Nov 19, 2008 | Technics SC-DV290 System
AudioLogic DVD-108 - help setting up component cables (no picture)
This may not be a solution, but is a good start. I recently bought a house with the theater system installed, but no remote. Had similiar problems with some functions on Universal remote. Did a google search and got the remote for my system and presto! I did a google on the DVD-108 and saw a AudioLogic remote(similiar, Originals are no longer available), and saw that there is a "setup" button as well as others that may select inputs. This may not be a solution, but would be a good start. Worked for me!
Jun 26, 2008 | Audiologic DVCR-251
Audiologic dvd 108
with in the Speaker from the setup play with those settings,
this system is terrible!
Jan 02, 2008 | Audiologic DVCR-251
217 people viewed this question
 Grubhead
Grubhead
