Question about SanDisk 2GB microSD Memory Card
Using a SanDisk Micro in a SanDisk adapter in a USB Card Reader. My system keeps reporting the card is write protected, no matter the position of the lock switch. I formatted the SD in my phone, no change. How can I turn off the write protection?
  • SanDisk Master
  • 32,281 Answers
Most SD memory cards have a tiny slide switch on the edge of the card. Move this slide switch from Read to Write to turn off the write protection.
Posted on Nov 12, 2010
  • rodger_young Nov 12, 2010
    You didn't read my message. "My system keeps reporting the card is write protected, no matter the position of the lock switch."
  • Chris Hingee
    Chris Hingee Nov 13, 2010
    Sorry about that.
    Try removing the SD card and connect it to an USB card reader and then plug it into a working computer's USB port. Then format the SD card using the computer.
How to reset the password memory card
Transcend??
Mini SD cards, or MicroSD cards, are used in digital cameras and portable media players to house digital media files.
MicroSD cards can house anything from 2GB to 32GB of information.
A write-protection feature gives the owner the ability to lock the MicroSD card to keep their files secure.
If you have a MicroSD card that is write-protected, you can un-write-protect it with a flip of a switch.
Insert your MicroSD card into the adapter that came with it.
Put the data side of the MicroSD card into the data side of the adapter.
Look for the write-protection switch on the left side of the SD adapter.
Flip the switch to the side that reads "Off."
Remove the MicroSD card from the adapter and replace it in the device you were using it with.
or you might
Feel along the lower right and left sides of the Micro SD card to find out if it has a built in write protection switch.
Move the switch over to the "On" position to turn on the write protection feature.
Check the front ports on your computer and see if it already has a built in card reading unit.
Purchase an external card reader that plugs into a USB port if your computer does not already have an internal card reader (see below).
http://www.newegg.com/Product/ProductList.aspx?Submit=ENE&DEPA=0&Order=BESTMATCH&Description=card+reader&x=0&y=0
Plug the card reader into any open USB port on the computer.
Power on the computer and let the operating system finish loading.
Insert the card into the Micro SD slot on the card reader.
Wait for a new window to appear that will ask what action you want to take with the Micro SD card.
Click on the link that says "Open a folder to view files."
Right-click on a file if there is just one specific file you want to enable write protection for.
Click on the "Properties" link from the menu that will pop up.
Navigate to the "General" tab.
Click on the box marked as "Read Only" and then close the Properties window.
Close the window and then double-click on the "My Computer" icon on your desktop if you want to enable write protection for every file on the Micro SD card.
Right-click on the name of your Micro SD card in the list of computer drives.
Click on "OK" and then close the window.
Click on "Properties" and then navigate to the "Security" tab.
Scroll down to the heading labeled as "Permissions."
Click on "Deny" under the "Write" section.
or
Slide the switch on the left-hand side of the SD card. If the switch is broken, proceed to Step 2.
Affix a small piece of tape or paper to the top half of the gap where the slider should be. Do not permanently affix the paper as of yet. 3
Try the card in your computer, using the USB converter stick.
If the items on the SD card are available, copy them to your computer as a precaution.
If that did not solve the problem, proceed to Step 4. 4
Remove the tape or paper and reattach it to the other side of the gap if you mistakenly attached it to the wrong side.
If you are actually trying to unlock a micro or mini SD card, proceed to Step 5. 5
Toggle the switch on the left side of your SD Adapter if you are trying to unlock a micro or mini SD card.
Micro and mini cards do not have switches.
Instead, insert a micro or mini card into an unlocked SD Adapter to work with stored data.
SD Adapters look very much like SD cards and the switch works the same way.
Nov 26, 2013 | PNY 1GB microSD Memory Card
Pny sdhc card protected
or you might
Click on "Properties" and then navigate to the "Security" tab. Scroll down to the heading labeled as "Permissions."
Nov 23, 2013 | PNY 4GB Secure Digital High Capacity...
I am trying to sync music to my memory card but windows media keeps telling me that my memory card was write protected. How do I fix this?
If ou're using a Micro SD Adapter then there's a little tab on the side that when slid down write protects the Card thats inserted.
Jul 09, 2011 | SanDisk 2GB microSD Memory Card
Plz help me to remove write protection from my micro sd card.
Hi, slide up the Write protection switch which is white in color for the Memory Card Adapter to remove Write protection and Slide down to enable write protection of the Memory Card.
Please click on the link below to view the Write protection switch:
http://kb.sandisk.com/euf/assets/images/faqs/id1102_e3sdhc.gif
If you are using a microSD/microSDHC card or a miniSD/miniSDHC card, insert the card into the standard SD adapter.
Apr 16, 2011 | SanDisk 2GB microSD Memory Card
I have a sandisk 2gb micro sd card. I put it into my computer's card reader and it keeps saying it needs to be formatted. When I try to format it it says windows was unable to complete the format. I am...
The FORMAT process is trying to write data to the card, but that writing is NOT successful,
i.e., the memory on the card is damaged/defective, and so it "fails".
Responsibly recycle the card, and purchase a replacement memory-card.
Jan 30, 2011 | SanDisk 2GB microSD Memory Card
I have a SanDisk UltraII and the card is write protected (not locked). I tried to erase using the disk utility on my MAC but it wont let me. How can I get rid of the write protection? Thanks in advance...
1.Look for a switch or button on the side of the micro SD card or adapter. It might have a lock/unlock symbol on it. 2.Move the switch to the "Unlocked" position to remove write protection. This position may also be labeled "R/W" for read/write. If you have no switch, continue to Step 3. 3.Download and install Sony EzRecover and attempt to use it to format the card (this will erase all content). If this doesn't work, try Step 4. 4.Delete and repartition the micro SD card using Windows XP. Select "Control Panel" > "Administrative Tools" > "Disk Management." Select the micro SD drive and click "Delete." Right-click on empty drive and select "New Partition."
Dec 14, 2010 | SanDisk 2GB microSD Memory Card
Where do i put it in my lap top
It depends on whether your laptop supports SDHC, microSDHC, or neither.
1. Supports MicroSDHC: check on the manual the position of the MicroSDHC slot.
2. Only supports SDHC: you need to purchase an adapter - essentially a full-size SDHC with a slot where the MicroSDHC goes. Plug the micro card in the adapter, plug the adapter+card into the SDHC slot.
3. Neither: you need to purchase both a micro-to-SDHC adapter and a SDHC-to-USB reader (usually SDHC in supported in most "XYZ-in-1 readers", like Quanta 32-in-1 USB reader - check out "SDHC USB reader" in eBay, for example).
Feb 11, 2010 | SanDisk 4GB microSDHC Memory Card
Memory card write protect?
i had same problem..couldn't solve it with tape over the lock switch and many other ways.. so i purchased a usb card reader (about $5 max) and now it works fine!...just make sure the lock is off!
Jun 02, 2009 | SanDisk 1GB microSD Memory Card
My SD memory card says its "unwriteable"
There is usually a switch on the adapter you are using that is there for write protection. The Micro sd card does not have one. Make sure it is not in the lock "position". See this website for more on memory cards and common problems. http://www.retire-asia.com/microsd.shtml I cut a little piece from the site that might help you
"There is no switch on the Micro SD card itself, but a standard-size-SD adapter (which the MicroSD needs to be plugged into for use with a card reader) and SD cards such as the SanDisk 4/8GB have a sliding write-protect switch similar to a 3.5 inch floppy disk. Data cannot be written if the slider tab is in the 'lock' position. The tab could be damaged or missing altogether. This is probably the first thing to check if you have an SD card write error problem. Using sticky tape (Scotch tape etc) to cover the switch slot might solve this problem, but it may need two or more layers before it works. Some SD adapters need the tab to be placed somewhere between the lock and open positions before data can be written to the card."
Mar 03, 2009 | SanDisk 2GB microSD Memory Card
Pc not recognizing sandisk micro sd
The Card Reader you are using is probably not compatible with SDHC Memory Cards (High Capacity SD). You may need to get an SCHC compatible reader or check the website for your product to see if the is a driver update. You can get a new reader for about $20 bones if needed. I had the same issue.
Dec 30, 2008 | SanDisk 4GB microSD High Capacity Memory...
SanDisk 2GB microSD Memory Card Logo
116 people viewed this question
Top SanDisk Electronics - Others Experts
Piyal Perera
Piyal Perera
Are you a SanDisk Electronics - Other Expert? Answer questions, earn points and help others
