Question about Sony XR-C210* CD Changer
The lcd display on my XR-C210 has broken can a fascia plate from an XR-6459be used instead?
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Sony Master
  • 2,226 Answers
Probably not.
Posted on Nov 12, 2010
Remove back bumper from 2004 jeep grand cherokee
  • Raise and support vehicle.
  • Remove wheels.
  • Remove plastic push pins attaching fascia to fuel tank skid plate.
  • Remove plastic rivets attaching fascia to wheel liner.
  • Remove nuts attaching upper edge of fascia to quarter panel and wheel liner
  • Remove plastic push pins attaching fascia to liftgate opening
  • Remove screws attaching fascia to liftgate opening.
  • Remove D pillar trim and scuff plate outboard screws.
  • Remove the rearward tie down screws and the aperture trim panel.
  • Carefully peel back the rubber body sealer patch to access the retainer clips.
  • Release the forward and rearward retainer clips on both sides of the fascia.
  • Grasp forward edges of fascia and pull outward to disengage retainers attaching fascia to quarter panel
  • Separate fascia from vehicle
  • Jul 06, 2017 | Jeep Cars & Trucks
    How do I replace rear parking sensor
    You have to take bumper cover off .
    Remove rear bumper fascia. Refer to Rear Bumper Fascia Replacement . Disconnect electrical from the rear object sensor. Lift the locking tabs on the housing and remove the rear object sensor.
    Preliminary Procedure
    1. Remove the compartment sill plate. Refer to Rear Compartment Sill Trim Plate Replacement .
    2. Remove rear wheel liners. Refer to Rear Wheelhouse Panel Liner Replacement .
    Rear Fascia Push Pin Retainers (Qty: 2)
    Rear Fascia Nuts (Qty: 4)
    Tighten
    10 N?·m (89 lb in)
    Rear Fascia Bolts (Qty: 2)
    Rear Fascia Bolts (Qty: 6)
    5
    Rear Fascia
    Tip
    Energy absorber and fascia are removed together. Cannot be separate on vehicle.
    Disconnect the electrical connectors.
    Dec 22, 2015 | 2006 Cadillac DTS
    How do I replace a rear license plate bulb in 2004 Jeep Liberty?
    1. Remove the screws that secure the license plate lamp assembly to the rear bumper fascia
    2. Pull the license plate lamp assembly down and out through the mounting hole in the rear bumper fascia far enough to access and disconnect the wire harness connector.
    3. Remove the license plate lamp assembly from the rear bumper fascia.
    Apr 16, 2011 | 2004 Jeep Liberty
    Where is the location for the fuel pump relay in a 2007 a3 2L tdi 170bhp
    The fuel lift pump relay is placed in the fuse box / relay plate fascia 2 for 2007 Audi A3 2.0 TDI. The fuse box / relay plate fascia 2 is placed above pedals behind a plastic cover. See pictures below:
    The fuel lift pump relay is placed in "2b" position in the above picture.
    Please do rate my response. Thanks!
    Jan 07, 2011 | Audi A3 Cars & Trucks
    How much would it cost roughly to replace the front bumper on a 2009 saturn aura xr?
    To replace just the fascia (soft painted part) around $500. If there is more damage, the cost will go up quickly. You may get lucky and find one the right color at an auto recycler (junk yard) for around $150 plus installation.
    Oct 04, 2010 | 2007 Saturn Aura XR Sedan
    Code for sony c450rds ?
    i have never heard of a sony unit that requires a code.
    Apr 20, 2010 | Car Audio & Video
    Wiring diagram for a Sony XR-C210 car stero
    SONY XR-C210, XR-C214
    1-GND
    10-+12 VOLT BATTERY WIRE
    16-Speaker RF-
    5-Speaker RR+
    11-+12 VOLT IGNITION WIRE
    17-Speaker LF+
    6-Speaker RR-
    12-Power Antenna Turn On
    18-Speaker LF-
    8-Speaker LR+
    13-TEL MUTE
    9-Speaker LR-
    15-Speaker RF+
    Sep 13, 2009 | Sony Car Audio & Video
    VIDEO DISPLAY PROBLEM FROM SHARP XR-1S LCD PROJECTOR
    make sure the resolutions match. change it on the projector.
    Mar 30, 2009 | Sharp Notevision XR-1S Slide Projector
    How do you work the Aux input?
    when something is plugged into the jack (mp3 player ect) there should work when you cycle through the options of the deck such as cd, radio, There should be an aux option when it is plugged in.
    Feb 09, 2009 | Sony XR-C210* CD Changer
    My Samsung LN-83251D is not working properly. Instead projecting a picture, it just displays bars and lines. Is my LCD TV broken?
    Jul 06, 2008 | Televison & Video
    Car Audio & Video Logo
    143 people viewed this question
    Top Sony Car Audio & Video Experts
    xxxxxx xxx
    Larry Stiles
    Larry Stiles
    Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
