Question about GE DCVH515EFWW Electric Dryer
Dryer runs but will not dry
Ge dcvh515efoww. 14 months old. runs but will not dry.
  • alemag Dec 08, 2008
    ge wsm27s00dawww dryer runs but doesn't dry.
    It is approximately 14 months old.
    An expert whose answer gotĀ voted for 100 times.
    Champion:
  • 210 Answers
It may be a thermostat that has gone, thus preventing the heater from going on. Check your power source as well, maybe you have lost a line.
SGt 48
Posted on Jun 18, 2008
Ge dryer dcvh515efoww runs on air dry, but when set on any heating cycle, it runs for a few minutes and then it turns off on 00
it is over heating you might have unplugged a wire to the thermostat when you had it apart or the thermostat has went out.
Mar 21, 2014 | GE Dryers
Take to much time to dry
Dear Ms.B.
I'd start by unfastening the vent hose off the back of the dryer and running the hot air into the room or with a large pipe out a window, to see if the vent pipe is plugged to the outside. If that does not speed up drying, check to make sure the washer is not at fault, by the wetness of the clothes. A loose belt can let the clothes be too wet from the washer. Then, I'd take the whole dryer apart and clean the inside. In the past 3 months, I have had 3 different dryers that were full of lint, over a two shoe-boxes of lint inside each one. The reason for the buildup is poor design, and each dryer was many years old.
Be blessed.
Jan 08, 2014 | GE 3.6 cu. ft. Electric Dryer - DSKS433EB
What do the "T" error codes mean in regards to GE electric dryer model # DCVH515EFOWW
YOU must see you instruction manual section troubleshooting and Fix it.
if you do not have download the instruction manual from www. fitness.manualsonline.com or www. retrevo.com
God bless you
Jun 19, 2012 | GE Dryers
My GE Profile Dryer is only 14 months old. A couple months ago a soft squeal began whenever I use the dryer. I only average 2 loads a week at the most and sometimes less than that. Of course, the...
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you fortaking the time to educate me. " - teresa241964
Aug 07, 2011 | GE Profile DPSB620GCWW Gas Dryer
I have a GE dryer Mod. # DCVH515EFOWW Ser. VH783057A I plug it in and only the internal light of the drum turns on nothing else does.
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Oct 26, 2010 | GE Dryers
Dryer gets hot and drum is turning clothes are not drying. cleaned lint tray and removed tubing venting outside and the dryer is making a whining noise. the dryer is only 14 months old
If the drum is turning and the dryer is getting hot, then this is good news, as it means that the dryer is mechanically sound.
First check to see if the internal workings of the dryer are not blocked by running the dryer with the vent tube detached. If there is lots of warm moist air coming out the hole in the back of the dryer where the tube should be, then your dryer is fine.
Next, if you've checked the tube that connects the dryer to the wall or floor and it is clear, then on to step 3.
Probably you have a blocked or severely restricted vent tube from the wall or floor to the outside. Over time, these always become clogged with wet lint that builds up into a crust on the walls of the tubing.
Find the exhaust exit on the outside of the house and run a sewer snake up into it to see if you can open a hole in the blockage. If that works to help the air flow, then you need to replace the tubing from your laundry room to the outside, as it is probably a solid crust of lint that has built up over years.
Again, the good news here is that your expensive new dryer is probably fine.
Jun 10, 2009 | GE Dryers
GE dry is making a noise like loose change is rolling around
There may be change rolling around in it.
Remove the top. Take the screws out of the drum baffles and remove the coins from inside the dryer drum baffles.
When replacing them, tighten them well to help prevent coins from getting in there.
Mar 23, 2009 | GE Dryers
Buttons won't work on GE Profile PDW7980N10SS
You have the control lock activated. Press and hold the heated dry pad for 5 seconds and it should unlock it
Nov 15, 2008 | GE Profile PDW8400J Built-in Dishwasher
GE DCVH515EFWW Electric Dryer Logo
203 people viewed this question
Top GE Dryers Experts
Dave Harrison
John Tripp
John Tripp
vince
Are you a GE Dryer Expert? Answer questions, earn points and help others
