Question about Ovens
Jennair flashing f7
My Jennair SVE47600C stove is flashing f7 and the stove won't turn on. I heard that it could either be the touch pad membrane or the clock assembly. How do I know which one for sure? Tryagnostics costs more than diagnostics - double in this case. He tried the suggest of using a pencil eraser to try and free the stuck switch?
    President:
  • 1,314 Answers
By he tried the eraser for freeing the stuck button you mean he cleaned the mylar ribbion then my best advice from my experence is replace them both that way youve got it on one teardown its almost impossable to nail it to just one part
Posted on Jun 20, 2008
Continuous beeping with F7 fault code. What do i need to replace, the touch pad or controller?
Hello, Thank You for using FixYa. I will be helping you today.Turn off power unplug ribbon cable from touch pad to control turn power back on and if after an hour no error code replace touch membrane if you get a fault replace control (clock Erc)
Thank You and please rate my answer if it was helpful..
Jun 21, 2011 | Jenn-Air Ovens
Tip
Fault Codes for Admiral Range/Stove/Oven
There are many fault codes for different ranges, ovens and stoves. These also are different for each manufacturer or brand. To see what the fault codes are and what they mean for the Admiral brand you can check this chart. It also will give you a short explanation and repair for each code.
Some of the repairs are simple and some of them are much more difficult.
Most parts are easily bought online. Check the link below to another tip I wrote about how to buy parts online.
Fault code What is wrong What to check or repair
F1 Defective touch pad or Replace touch pad or clock assembly
Membrane this also can be called the ERC
F1 Watchdog on board Replace the touch pad or ERC
F2 Oven too hot Replace the relay board or oven temp
sensor
F3 or 4 Open or shorted oven Replace oven temperature sensor
Temperature sensor
F5 Hardware and watchdog Replace clock assembly or ERC
circuits disagree
F6 Missing AC signal Check for proper voltage
F7 Function key shorted or Un-stick button or replace touch pad
stuck button /ERC
F8 Analog/digital trouble Replace clock assembly/ERC
F9 Door latch trouble Check door lock circuit or ERC
F0 Function key stuck Replace touch pad or ERC
http://www.fixya.com/support/r3907570-buy_appliance_parts_online
http://www.fixya.com/support/r3969401-self_cleaning_oven_problem
http://www.fixya.com/support/r3663023-oven_not_working_or_oven_not_heating
on Feb 18, 2010 | Ovens
Model CRE9600CCM Serial 24625851SK. When we turned on the oven, we got an error message "F-5". What does this mean? What do we need to do?
Here is a list of codes for Maytag-- Does this help:
Maytag / MAYCOR / Magic Chef / Jennair / Admiral
Oven Fault Codes
Display Condition Remedy
F0 Function key shorted or stuck button Clean and unstick button or replace Touch Pad or Clock
F1 Defective Touch Pad or Membrane Replace Touch Pad or Membrane
F2 Oven over heat defective Relay Board or (if present) or defective Sensor
F3 Oven Sensor Open Replace Sensor
F4 Shorted wire or Sensor locate short and correct it or replace Sensor
F5 Hardware, safety circuits disagree Replace Clock
F6 Missing AC (power) signal Check for proper voltage (plug, breaker, etc.)
F7 Function key shorted or stuck button Clean and unstick button or replace Touch Pad or Clock
F8 A/D Warning Replace Clock
F9 Door Lock Warning Check door lock circuit or Replace Clock
Let us know if we canhelp further,
Mack B
Jan 23, 2011 | Maytag Ovens
What does F- mean on my jenn air expressions electric wall oven? If it means what I think, then this is the 4th failure in 10 years. This just can't be right!
Common fault codes:
Oven Fault Codes
May 22, 2010 | Jenn-Air 27 in. Electric Single Wall Oven...
The oven isn't working and it says FO in red letters
GE / Hotpoint / RCA
Oven Fault Codes
F0 & F1 Failed Thermistor Control Replace ERC
F2 Oven Temp Exceeds 590 with unlocked door High resistance in Sensor, likely a bad sensor
F3 Open Sensor circuit Open (blown) sensor fuse or bad Sensor
F7-A Function pad button stuck Clean and unstick
F7-B Bad Clock Replace Clock
F8 Electrical component failure Replace ERC
F9 Program with door circuit Check wiring
Frigidaire / Westinghouse / Tappan / Gibson
Oven Fault Codes
F0 & F1 EOC failure Replace EOC
F2 Oven over heat Defective Sensor or EOC
F5 EOC failure Replace EOC
F6 EOC failure Replace EOC
F7 EOC failure Replace EOC
Oven Fault Codes
Amana / Caloric
Oven Fault Codes
Type with display - glass link ERC
F0 No Safety Signal Replace adapter board
F1 No Safety Signal Replace ERC
F2 Oven over heat Replace defective Sensor
F7 Shorted Touch Panel Replace Glass Panel
F9 Door Latch Error Check latch
FF Lock Error Check switch and motor
ERC III - Relay board with separate board/push buttons
F0 Shorted Push Pad Replace Push Pad
F1 Defective ERC Replace ERC
F3 Oven Sensor Open Check/Replace Sensor
F5 Defective ERC Replace ERC
F6 Defective ERC Replace ERC
F7 Shorted or sticking button Clean button or replace touch pad
F8 Defective ERC Replace ERC
The following diagnostic chart Does not apply to Whirlpool 'Y' line products. If the model number contains a Y near the end of the number, DO NOT use this chart.
Whirlpool / KitchenAid / Roper
Oven Fault Codes
Ovens with 4 digit displays
F0-E0 Analog to Digital failure Disconnect panel for 30 seconds. if error re-appears then replace control
F1-E1 Defective ERC Replace ERC
F2-E0 Shorted Keypad Replace Keypad
F3-E0 Sensor or Sensor Fuse Open Replace Sensor or Fuse
F3-E1 Shorted wire or Sensor locate short and correct it or replace Sensor
F3-E2 Oven over heat Replace Sensor
F3-E3 Cleaning Temp over heat Replace Sensor
F5-E0 Door Error Check Door
F5-E1 Door Latch Check Latch
F5-E2 Door Switch Check Switch
Ovens with 2 Digit Displays
F0 Defective ERC Replace ERC
F6 Problem with time keeping circuit Reset Time or cooking operation and check for proper ground
F7 Shorted or sticking button Clean button or replace ERC
F9 Door Latch Error Check latch and latch circuit
Dec 18, 2009 | Ovens
GE double oven is flashing F7 and beeping
F7 means a stuck button on the membrane pad. You may have to replace the membrane switch pad
Aug 06, 2009 | GE Profile JT955 Electric Double Oven
What does an F1 fault indicate
MAYTAG
Range/Stove/Oven Fault Codes Failure
Code
Condition Check/Repair F1 Defective touch pad or membrane Replace touch pad or membrane (usually the touch pad)* F1 Watchdog on board Replace touch pad or clock assembly (also called the ERC) F2 Oven too hot Replace relay board (if present) or bad oven temperature sensor F3 or F4 Open or shorted oven temperature sensor Replace oven temperature sensor F5 Hardware and watchdog circuits disagree Replace clock assembly (also called the ERC) F6 Missing AC signal Check for proper voltage F7 Function key shorted or stuck button Replace touch pad or clock assembly (also called the ERC) or un-stick button F8 Analog/Digital supervisory Replace clock assembly (also called the ERC) F9 Door latch supervisory Check door lock circuit or replace clock assembly (also called the ERC) F0 Function key stuck Replace touch pad or clock assembly (also called the ERC) * Here is a simple test that you can do to determine whether the clock or the touchpad are defective when the display reads F1:
- Disconnect power to the range.
- Gain access to the back of the ERC (electronic range control, or "clock").
- Unplug the touch pad ribbon connector from the ERC. This will be a flat wire about 1 ½" to 2" wide.
- Make sure everything is clear and will not short out when power is turned back on. Replace any covers removed to gain access to the ERC.
- Turn the power back on to the range.
- Watch for the F-1 and listen for the beep.
- If you get the F-1 and beep, replace the ERC.
- If after approximately 60 Minutes you do not get the F-1 fault, replace the touch pad.
NOTE: Some models incorporate the touch pad and the clock control as one part so F1 = bad clock control.
Warning: If you do not feel comfortable doing this test or making this repair please contact a qualified appliance repair technician.
Jun 01, 2009 | Whirlpool 30" Self-Cleaning Freestanding...
F2,F5,F7 message
MAYTAG
Code
Feb 07, 2009 | Maytag MEW5527B Electric Single Oven
Jenn aire
Maytag-Maycop-Magic Chef-Jennair-Admiral
Oven Fault Codes:
May 10, 2008 | Jenn-Air WW30430P Stainless Steel Electric...
Jenn-Air WW30430W double oven flashing F7 and beeping
It seems you have a stuck button. Here is a list of fault codes:
JENN AIR
Failure
Code
Condition Check/Repair F1 Defective touch pad or membrane Replace touch pad or membrane (this problem is usually the touch pad) F1 Watchdog on board Replace touch pad or clock assembly (also called the ERC) F2 Oven too hot Replace relay board (if present) or oven temperature sensor F3 or F4 Open or shorted oven temperature sensor Replace oven temperature sensor F5 Hardware and watchdog circuits disagree Replace clock assembly (also called the ERC) F6 Missing AC signal Check for proper voltage F7 Function key shorted or stuck button Replace touch pad or clock assembly (also called the ERC) or attempt to un-stick button F8 Analog/Digital supervisory Replace clock assembly (also called the ERC) F9 Door latch supervisory Check door lock circuit or replace clock assembly (also called the ERC) F0 Function key stuck Replace touch pad or clock assembly (also called the ERC)
Dec 09, 2007 | Jenn-Air JJW8530C Expressions Collection...
Ovens Logo
191 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
