Question about Canon imageRUNNER 400S Copier
Canon IR400 reading E677 and instruct me to switch on/off.
  • Canon Expert
  • 242 Answers
Product : imageRUNNER 330 / 400 Title : Error E677 on the imageRUNNER 330 / 400 Series Control Panel Error :
E677 on the imageRUNNER control panel
There are two possible instances of this error message:
1. When the board boots up, the board experiences a wait and then reports an E677 (with either sub code 0001, 0002, or 0003).
2. While printing, the board fails and reports an E677 (sub code 0004).
Workaround :
When the printer board is installed on the imageRUNNER 330 / 400, it communicates with the image processor board via its connection to the System Motherboard PCB. The copier low voltage power supply provides power to the printer board via its connector J8201. When the copier is powered up, communication takes place between the copier IP and the printer board.
Communication Failure at this point will most likely cause the copier Error code E677 with a subcode of 0001,0002 or 0003.
This lack of communication can be caused by a bad cable, a non seated card, or corrupted installation of System Software.
In this case, try to format the Hard Drive and reload System Software. If the problem continues, try replacing the printer board. The printer board H1/K1 can be sent to Nationwide or Hytec for repair.
An error code E677 with a subcode of 0004 however, may be caused by either an overheating CPU or low voltage being supplied to the printer board. Follow the procedure indicated in Technical Publication CIB-T052 for those printer boards which continue to exhibit error codes of E677 with a subcode of 0004.
Note: Since error codes E677 were reported frequently with different subcodes, Canon decided that all boards be screened. After the screening a colored dot was placed on the board near the AUI port. As of now, a Yellow dot means that it has passed screening and should work. Eventually the board will be modified and the dot will be Red showing the board has modification and has passed screening.
Posted on Nov 12, 2010
Ir 400 error e677
Posted on Mar 31, 2011
2 Suggested Answers
SOURCE: E677 Error in canon IR400
switch main power off and on E677
Posted on Jul 16, 2009
What to do Error E677
hello i will tell you what error means and how to fix the problem but you will need the service manual to help you
1. E677 error means that "The communication between the printer board and the machine has a fault."
2. Check the connection between the
printer board and the PDL I/F
board and the system motherboard.
Is any of the pins bent or otherwise
not normal?
3. If this not helped you must replace the printer board
You can download the service manual for ir400 from the below link it will save u $$$:
http://goo.gl/bFmfmN
good luck
Sep 11, 2013 | Canon imageRUNNER 400 Printer
Ihave problem with canon ir 600 .Error show E677
E677 communication error between machine & pc.
Thanks, i am waiting for your feed back & if you satisfied then thumps me please.
Feb 01, 2010 | Canon imageRUNNER 600 Printer
Eror E677
roblem :
The machine displays an E674 code. This may be followed by an E677 code when the Fax pcb is removed. The imageRunner also has a Print Board installed.
Solution :
With the Fax Board and Print Board installed an E674 code occurred. When the Fax Board was removed an E677 code then occurred.
Try removing the PDL Interface pcb for the Print Board from the copier. Reinstall the Fax Board, if the E674 code does not occur and the copier is capable of sending and receiving faxes, then replace the PDL Interface pcb because it may be faulty and causing the two E codes; E674 for faxing and E677 for printing.
Jun 01, 2009 | Canon imageRUNNER 400S Copier
Feb 24, 2009 | Canon imageRUNNER 400S Copier
Ir400 e677 error
E677 on iR400 is the otional printer board assembly was trouble. It must be change. Try this : replace your optional printer board assembly, the problem was correct? The other day you must bought optional printer board assembly. God Bless You....?!
Feb 06, 2009 | Canon imageRUNNER 400S Copier
E677
press the additional * 2+8 additional *
select the copier on the screen
select function
select clear
select ERR
press OK
restart the Copier
Oct 02, 2008 | Canon imageRUNNER 400S Copier
Canon imageRUNNER 400S Copier Logo
886 people viewed this question
old marine
old marine
