Question about Daltile Bathroom Accessories Resin Soap Dish Ceramic Tile & Stone
Does a resin tub soap dish needs to be sealed? If so, what is the best sealant to use.
2 Suggested Answers
  • 19 Answers
SOURCE: Installing a resin shower soap dish,
liquid nails will do the job but you can also use clear silicone provided both surfaces are dry.
Posted on Feb 03, 2009
I am having trouble with the sealant cracking on my American standard saver acrylic tub/ surround.
If you have movement on the tub it will not seal . you will have to solve the movement first . General sealant which does not mould will normally work .
Oct 08, 2017 | Plumbing
We had corner soap dishes installed in our newly remodeled shower stall. But the water does not drain off just sits. The soap dish does have a small dip in the outside rim. The contractor says it is...
I have the same problem with my stone corner soap dish. It used to drain ok but recently water just sits on the dish and mold grows. Unless we get a good solution, I plan to drill holes into the dish to let it drain.
Feb 12, 2011 | Daltile Bathroom Accessories Resin Soap...
How install the soap dish
There are a couple of designs, one is surface mount and the other is recessed. Surface mount mounts with silicone (hard to imagine it would last) and the other installed similar to a tile, but using grout. The grout install gets a hole cut in the tiles, goop everything up with grout, and goosh it into the wall, clean same as you would when working with grout.
Both designs need support until the adhesive dries.
Dec 12, 2010 | Daltile Bathroom Accessories Resin Soap...
Listello resin 3 by 12 : tile;white grout stuck on the tile
yes, you should seal all tile with a 3-5 year sealer. there are many brands to choose from. excess grout should be removed with a sponge and water before it dries. clean food splatters with any safe kitchen cleaner.
Jul 31, 2009 | Daltile Bathroom Accessories Resin Soap...
Cannot find 2 tile soap dish-back wall that measure 4"hx8"wide.
contact Daltile to see if they have a replacement. If they do you will have to have contractor purchase for you as Daltile does not sell to general public
May 31, 2009 | Daltile Bathroom Accessories Resin Soap...
Cutting resin tile
You need a tile saw that uses water to prevent sparking. Home Depot, Lowes..........<$100
Apr 24, 2009 | Daltile Bathroom Accessories Resin Soap...
Feb 02, 2009 | Daltile Bathroom Accessories Resin Soap...
Water leaking from the door
Could be a number of things. If you are in an area with hard water you could be using too much soap or the wrong soap. The dishwasher could be out of level, or the door seal could need replacing. Dishwashers also need to be cleaned. Soap residue builds over time. Try running the d/w with no dishes or soap, pour 5-6 cups of white vinegar directly into the tub and run a whole cycle. And again watch the soap usage.
Apr 08, 2008 | Frigidaire 24 in. FDB1050REC Stainless...
Have a tub main bearing needing replaced on Amana LWA40AW2
Generally, if you need sealant, you can use any kind of automotive sealant. The best ones are the rubber-based gasket sealants. Be sure the surfaces are clean before applying and use only enough to make a thin bead. About the bearing: If you have no access to a press, you can often use a piece of pipe (either plastic or steel) which is just large enough to slip over the shaft and pound the bearing into place with a mallet. The pipe should contact only the inner (shaft contacting) race. Be sure it is square. You should lightly lubricate the area where the bearing will seat and also the inside lip and bore of the seal. .
Jan 14, 2008 | LG WM2077CW Laundry XL Front Load...
Daltile Bathroom Accessories Resin Soap Dish Ceramic Tile & Stone Logo
62 people viewed this question
Top Daltile Home Experts
Mike
Sal De
woodzowl307
Are you a Daltile Home Expert? Answer questions, earn points and help others
