Question about Admiral AW22 Top Load Washer
Whenever the washer is filling up and you select hot water cold water appears instead, and the same happens when you select cold hot comes , I changed the valve and it is still happening
  • 417 Answers
reverse the hoses so they go to the other faucets? take your left hose and put it on your right faucet and vise versa. have you tried that?
just an idea
jm
Posted on Nov 12, 2010
Kenmore 44832 hot water won't stop.
If your washer is overfilling, check these:
Water-inlet valve
Water-level switch
Water-inlet valve Adefect in the water-inlet valve may mean that it's no longer able toshut off completely when the electricity has been turned off to it. Ifthis occurs, the valve may leak and drip water into the clothes tub. Intime, the water may accumulate substantially. If this happens, you needto replace the valve.
Water-level switch Adefect--or an obstruction--in the water-level switch may mean that itcan't tell the water to shut off. So the machine overflows. This switchsenses the water level in the clothes tub. It's usually a diaphragmdevice with a small, clear tube attached between the switch and thebottom of the washer's outer tub. As the water level in the tubincreases, the pressure on the air in the tube increases. When thepressure reaches a certain level, it activates the switch, shuts offthe water, and signals the timer to begin the agitate cycle. You caneither clear any obstruction in the tube or replace the water-levelswitch.
Aug 03, 2008 | Kenmore 44832 Front Load Washer
My washer no longer produces cold water, only hot, except for the start of the cycle. The machine will tell me that it's not getting cold water. It doesn't matter whether I set the water temperature at...
It sounds like the fill hoses are inverted. Most of the Fisher washers only fill with cold water after the initial fill. So if the hose are inverted then it will only fill with hot. Beyond this I'm at a loss. Good luck
Apr 23, 2011 | Fisher and Paykel Fisher Paykel Intuitive...
My new estate washer with 4 water selections actually only has 2, hot and cold. The warm water setting fills with lukewarm water for a while then shoots in cold water for a while and back and forth. In the...
Yes, this is normal. All newer washer have auto temp control fills. This is to meet energy saving requirements. The less hot water used the more energy saved. Most hot settings on washers give out basically lukewarm water. The detergent made today is made to work well with cooler temperature water, so things will still come out clean.
Feb 01, 2010 | Whirlpool Estate TAWS750PQ 27-Inch Washer
Why did my LSE7806ACE WASHER STOP FILLING
Hi…
If I get you correct, the hot water is not coming into the machine or it is not working at all.
Let me know
Thanks
Smith
Aug 13, 2009 | Maytag LSE7806A Top Load Stacked...
Washer Fills HOT WATER ONLY
If you checked the screens at the water inlet valve and they were not clogged, then you probably have a defective water inlet valve and will have to replace it. Hope this helped.
Jul 19, 2009 | GE WJSR2070B Top Load Washer
Washer will not fill when you select cold water
Q - My washer will not fill with cold water
A - More often than not, this is a bad fill valve. Please see the filling section.
There's no cold water Some washing machines allow cold water to enter only during certain cycles. Others intermittently allow hot and cold to enter, to temper the temperature of the water. Consult your owner's manual if you are unsure about whether the machine is acting abnormally.
If you're sure the machine is not working the way it used to--or should--check the following.
  • Is the cold water turned on? If not, turn it on.
  • Is the washer getting hot water but no cold water? If so, check to see if the control panel settings are correct.
  • Is there cold water coming through the proper hose? If not, check to see if the screen inside the water-inlet valve is clean. (The water-inlet valve is the device on the washing machine that the fill hoses are attached to.) If it's clean, you probably have a defective water-inlet valve. If so, you need to replace the valve.
May 03, 2009 | Washing Machines
I have the washer on cold water, but it runs warm, stops, trickles, then comes out warm again, stops, trickles, then warm again ect.On the rinse cycle it will only trickle out.
The water fill valve - The water fill valve is a mechanical and electrical part, the coils on the valve need electricity to mechanically open the valve to allow the water to flow into the washer....myth....the washer pumps water into itself...no, it does not. The fill valve opens and the house water pressure pushes the water into the washing machine.
No cold water or no hot water - The fill valve has two coils, one for the hot water and one for the cold water. It is possible that one of the coils can fail and you loose that filling ability. If the cold water coil quits, the hot will still work and during warm fill you will get hot water only and during a cold fill you will get no water at all. If the hot coils quits, you will still have cold water fill, cold water only on a warm setting and no water on a hot fill setting. You can No cold water or no hot water - The fill valve has two coils, one for the hot water and one for the cold water. It is possible that one of the coils can fail and you loose that filling ability. If the cold water coil quits, the hot will still work and during warm fill you will get hot water only and during a cold fill you will get no water at all. If the hot coils quits, you will still have cold water fill, cold water only on a warm setting and no water on a hot fill setting. You can test a fill valve live for 120 volts, power to a fill valve coil and no fill = a bad fill valve. You can also test the coils for continuity, no continuity = a bad fill valve. Some Maytag washers have a fuse in the fill valve circuit, if this fuse let go the washer will not fill. Fill valves can also from time to time stick open and not stop filling. If you have to shut off the fill valves to stop the water from filling in the washer, you have a bad fill valve and you will have to replace it.
Mar 03, 2009 | Washing Machines
Water temperature control not working
the fill hoses are backwards,,,reverse fill hoses...on the job...also your under warranty ..call for service but you can do it your self..
Jan 17, 2009 | Whirlpool LTE6234D Top Load Stacked...
When temp is set on hot water--hot water shuts off & cold water comes out
In the machine, you have a solenoid that the water hoses come into. That piece is controlled by a timer. The hot water during the cycle, does it shut off completely during fill or intermittent?
Mar 16, 2008 | Washing Machines
Admiral AW22 Top Load Washer Logo
35 people viewed this question
Top Admiral Washing Machines Experts
Dan Webster
Dan Webster
Sal De
Are you an Admiral Washing Machine Expert? Answer questions, earn points and help others
