Question about Cobra 148 GTL 120-Channels Base CB Radio
I need to know where the regulator is on the circuit board i lost my tx and receive and the l e d stopped lighting up
  • Donni Wilcox
    Donni Wilcox Nov 15, 2010
    I can only find IC5 IC3 IC1 no IC6 do you have a picture of the board?
  • Donni Wilcox
    I cant find IC6 I am only able to locate IC1 IC3 IC5 Do you by any chance have a photo of the board?
    Genius:
  • 1,274 Answers
Hi, my name is John. Welcome to FixYa. Look for IC6 on the board. Good luck. John
Posted on Nov 13, 2010
  • JOHN BABA Nov 15, 2010
    Hi donn, IC6 is a 10 pin IC, black in color, it should be a KIA-7217 on it. If you need the voltage, let me know and I will post them here. Thanks for choosing FixYa....John
Panasonic troubleshoot manuals
Fault with the main power supply regulator board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and precious time.
Aug 29, 2014 | Panasonic VIERA TX-37LZD800 37 in....
Onkyo tx-nr515 no standby light,no power???
hi
check the primary circuit for faulty fuse or the circuit is damaged needs servicing.
good luck
Jul 08, 2014 | Onkyo Tx-sr507 A/V Receiver
Had a power surge and now my Onkyo TX-SR607 will not power on. Only get a constant click sound. Any repair advice?
although power surge can trigger activations of protection circuits,
there are at times, damage is done before it is activated.
• Check first for low power supply regulators,
then check for possible output stage failure.
let me know if you need further assistance!
Sep 09, 2012 | Onkyo Tx-sr607 7.2-channel A/v Surround...
I own a onkyo skw 980 subwoofer and it just quit. I have only had the system for a month or so. I was listening to music, not loud and the bass (sub) just stopped. No crack, pop, or blown speaker. The...
How are you sourcing the program material to the sub? This TX-V940 receiver doesn't have specific sub support.
=== Just the same...
You need to first determine which is at fault - the sub or the receiver.
Connect the Sub Input to Tape Rec on the receiver (but DO NOT select Tape) and see if the sub reacts to your playing FM, for instance. If it works you need to go back to the receiver and the unknown method you're feeding the sub.
You could also test the sub with a CD player output but use a recording that starts low because you won't have volume control.
Dec 24, 2010 | Onkyo TX-V940 Receiver
Onkyo TX-DS555 will not switch to Dolby Digital
regulated voltage to the processor circuit like drop in these onkyo after 8 years. This or a small capacitor fails in this voltage line.
Jul 16, 2009 | Onkyo TX-DS555 Receiver
"The blue light around my volume dial does not light
Try resetting the receiver (you will lose your setup). I recently reset my receiver and the blue light returned. It's possible that the Audacity setup turns off the blue light because the volume is now being "regulated" by the equalizer.
Mar 26, 2009 | Onkyo TX-SR705 Receiver
TX-SR504 receiver won't turn on
Had same on an ONKYO TX-505 given to me for repair - eventually found a broken track on top circuit board that came from a transistor that control the main power on relay - looked like it was burnt off for a section of about 1.2mm
Repaired the track and has worked ever since
good luck WTech/Townsville
Mar 18, 2009 | Onkyo TX-SR505 Receiver
Sanyo EM-710F display dead
Low voltage Tx actually OK. Restored vaporised circuit tracks on controller board, fuse and interior light globe. All working OK.
Jun 18, 2008 | Microwave Ovens
Unit no longer powers up after shorting the switched plug in back of unti
you most likely fried a circuit board trace on the power supply
Dec 25, 2007 | Onkyo TX-SR500 Receiver
Cobra 148 GTL 120-Channels Base CB Radio Logo
62 people viewed this question
Top Cobra Radio Communications Experts
AnyMHz.com
AnyMHz.com
Are you a Cobra Radio Communication Expert? Answer questions, earn points and help others
