Question about Lexmark Z645 InkJet Photo Printer
Printer not working does not acknowledge printer
  • 1 more comment
  • Anonymous Jun 23, 2008
    Printer does not recognize requested task.
  • Anonymous Nov 16, 2008
    • printer will not print,lights on left light printer will operate once
  • Anonymous Nov 19, 2008
    printer will not communicate to computer so it cannot print
Just get theback the installation disc for the printer and install the software.
Turn on your printer and send a test page to the printer. It will definitely work.
Posted on Jun 17, 2008
Ran out of ink fitted new cartridge still showing no ink fitted another cartridge still same any clues
If you are using non-original or refilled cartridges, it is common for printers to not acknowledge the ink levels. On most, you have to acknowledge that you are using non-original or used cartridges and then override the ink level sensors. After that, most printers will work. You just won't see ink level monitoring.
Nov 17, 2015 | Office Equipment & Supplies
How do I get my printer to acknowledge the new "M" ink cartridges?
make sure you remove the yellow sticker from the cartridge. insert cartridge till it clicks and the lever goes into the up position. close door. if it doesn't detect it there is something wrong with the printer.
If that doesn't work there is a mant mode that your printer can go into for field techs to reset counters and other advanced features. Here is a link to the service manual for your printer. The Menu you want to get into is called maintenance mode and is accessible by unplugging the printer and holding a button and reapplying power. Here is the PDF with the instructions for working on your printer.
http://support.brother-usa.com/Virdata/Content/en-US/MFC/Technical/ServiceManual/SM_MFC_J280W_J425W_J430w_J435W_J625DW_J825DW_J835DW_EN_5063.PDF
Good luck. It will look intimidating but no worries it isn't like the printer is working now so you can't get much worse.
Dec 22, 2014 | Brother MFC-J425W
Cannon MP492 printer not acknowledging my doc to scan
But, you can print?! When you scan to PC the page is blank?
Jul 14, 2013 | Office Equipment & Supplies
The printer does not acknowledge a cartridge is
So the Printer is not recognizing the Cartridges. In this case, you need to clearly see 2 things:
  1. The Cartridges are compatible with the Printer of yours.
  2. The Contact or the Attaching socket of the printer is absolutely clean and dust-free.
Please see the above points and reply me so that we can proceed further. Thank you Sir, Have a nice day.
Oct 16, 2009 | Brady Office Equipment & Supplies
I cant print with my canon ip1300 printer? why?
1. Switch off the printer (the button Power ).
2. Holding button Resume , include the printer (press the button Power ).
3. Holding button Power , release button Resume (indicator of the feeding/readiness must glow green)
4. Not releasing button Power , two times press button Resume and release both buttons
- under each striking the button Resume indicator of the feeding/readiness changes the colour (one striking yellow, the second striking green). Beside printer, having more one indicator indication is switched (indicator of the feeding/readiness green, indicator mistake yellow)
- after buttons will be отпущены, indicator of the feeding/readiness certain time will twinkle green (time моргания depends on models of the printer), then green fires constantly
- if after these action instead of constantly burning green printer continues to show the mistake, that or you mistakenned in points 1 4 (switch off the printer and repeat with point 1), or beside printer additional mistake, which necessary to avoid, otherwise he will not fall into service mode (that means this mistake possible hear here).
5. Four times press the button Resume (under each striking the button Resume indicator of the feeding/readiness changes the colour, but beside printer, having more one indicator indication is switched: readiness/ mistake).
6. Once press the button Power for acknowledgement of the selected action (the unset of the counter абсорбера). For switching off the printer button Power press once again.
For some printer (for instance, iP2000) for switching off it is necessary to press Power once again i.e. three times contract.
Some printers have two counters абсорбера Main and Platen (Bordless), and if after unset Main waste ink counter ( as is described in this instructions ) after leaving from service mode printer continues to show indication an overflow абсорбера repeat all points to instructions before point 5 inclusive, then instead of point 6:
# For printer iP2000 and iP6220d
- once press the button Power for acknowledgement of the selected action (the unset of the counter абсорбера), then once press the button Resume (the choice counter Platen waste ink counter) and press the button Power for acknowledgement of the selected action; for switching off the printer button Power press once again.
# For printer iP3300, 6210d, pro9000, pro9500
or
- once press the button Power for acknowledgement of the selected action (the unset of the counter абсорбера), then two times press the button Resume (the unset simultaneously two counters) and press the button Power for acknowledgement of the selected action; for switching off the printer button Power press once again. (For printer pro9000 and pro9500 in documentation is specified only this variant of the unset)
Sep 28, 2009 | Office Equipment & Supplies
My Windows XP Won't Acknowledge My Lexmark 6570 Printer
Try re installing the drivers for the printer that should work
Jun 18, 2009 | Lexmark X6170 All-In-One InkJet Printer
My printer will not acknowledge the colored cartridge I have a Dell 948 All in one printer, It is acknowledging the black ink but not the colored ink
  1. Check to see both contacts on cartride is clean, and in the printer the pins that press against the cartridge.
  2. Check to see that Cartridge fits perfectly and that theres no clips broken of from the tray
Dec 14, 2008 | Dell 948 All-In-One InkJet Printer
Lexmark Z645 InkJet Photo Printer Logo
52 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
