Question about Gateway 704GE PC Desktop
Gateway 704GE push power button fans turn on and thats it...any ideas?
  • Gateway Master
  • 11,800 Answers
Simple test: disconnect and remove everything that is attached to the motherboard except the monitor and try to start it : if you don't get a warning from the BIOS then either the motherboard or the processor has failed. To find out which replace the processor and try again.
Posted on Nov 12, 2010
Testimonial: "Thankyou very much for your time"
Gateway laptop i push power button it wont boot up but leds in front flash 4 times
Try holding down the power button instead of just pushing it. I had this problem with my HP dv7 and holding the power button down for around 5 seconds worked for me. Also make sure that its plugged in to a power source.
Oct 23, 2012 | Gateway Computers & Internet
Gateway gt4016 wont turn on you can hear the fan and light flicks on for a second but then nothing changed the power supply nothing
try rebooting your coumpter is in sleep mode it takes a long time but you will get it back on .... keep pushing the power button aventally it will start up
Jun 30, 2012 | Gateway GT4016 Desktop PC
MY Gateway GT4016 Will not start anymore, i first replaced the power Suply and nothing happened. the fan runs and a light blinks then it shuts down again, i used to start it by just pressing the button and...
Make sure all fans are running power supply one to hehe Maybe a bad power button? I had a gateway that did some thing very close to that because the cpu fan was not turning and a hp that did that because the power supply fan was not turning. Thats where I would start then make sure the mem is seated good and not bad you know the drill ;) if you replaced the power supply with a factory replacment it should be a voltage or wattage problem. Might also try a hard boot the power plug take the cmos bat out hold the power button down for 20 or 30 secs some people say to leave the cmos bat out and try to fire it up. I know that works on some laptops but I always had better luck putting it back in for desktops cant hurt to try it. If you have two ram sticks in it pull the # 2 one and try to fire it up if nothing changes swap the # 2 one with # 1 leaveing slot 2 open and try it that will tell ya if it is a bad ram stick I dunno just my two cents hope it helps
Oct 08, 2010 | Gateway GT4016 Desktop PC
I have a Gateway 840 GM and I have just replaced
At first check the battery that's on you motherboard. The battery powers the bios on your motherboard. The bios detects you push the power button and turns on the pc. If the battery is dead the bios has no power, so it cannot detect you push the power button and will not turn on the pc. So replacing the battery will solve the problem. If the battery is not the problem, I think your motherboards bios is dead. Maybe it can be fixed but you'll have to send it back to the manufacturer I think.
Mar 29, 2010 | Gateway 840GM (RB840GM) PC Desktop
Gateway 5056 Media center doesn't boot everytime.
did you look on gateways website for a bios update. the firmware on your motherboard maybe corrupt. go here and check since I dont have your serial number... gateway has a java based scanner that might be able to repair it for you
http://support.gateway.com/support/drivers/dlcenter.asp
please rank me if you can
Jun 22, 2009 | Gateway GT5220 PC Desktop
Gateway 500xl pc will not turn on power button is lit up yellow
A LOT of Gateway computers will go into this catatonic state because of a dead battery. The battery is on the motherboard -- it looks like a metal disk about 1" in diamter. Check it or replace it. This applies to laptops too (not the actual laptop battery, the CMOS battery -- a laptop will have one on the motherboard too)
Hope this helps
Mar 13, 2009 | Gateway 500XL PC Desktop
Gateway GT1040 will not start
Try shorting the power pins on the Motherborad. (establish contact manual. use screw drivers such that they touch both the pins). The power pins are the one the Start button are connected to. Remove this connection alone. If this powers up the system, you would have to get the Button replaced. Else there's something wrong with the motherboard. Kindly get back for any clarifcation.
Jan 09, 2009 | Computers & Internet
Monitor does not come on when powered on, it says no input signal
Check your video card. It sounds like it has went bad. Hope this helps.
Jan 08, 2009 | Gateway 420GR PC Desktop
Gateway 505GR desktop...failure to start
when the power supply goes bad , that is the sign that it needs to be replaced . I would replace it first .
Aug 18, 2008 | Gateway 505GR PC Desktop
Gateway 704GE PC Desktop Logo
79 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Matthew Spark
Matthew Spark
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
