Question about Fisher and Paykel Fisher Paykel Intuitive Eco Washer IWL15
Mw058u fisher and paykel the problem seems to be when it fills up it seems to time out and then it beeps until you press the Start?Pause button.. when this happens the Hot light and the Cold light flash along with the light of where the cycle is up too!! I have pulled it apart and the out of balance switch seems to be alright as when the last spin cycle happens it friken rocks around like mad!! Some times the water filling it up only comes through very slowly!!
  • 15,935 Answers
For low water volume - or "Trickling" effect...
1. Turn off the water supply to both hoses.
2. Remove hoses (one at a time so you don't get them confused)
3. On the washer side - look for a removeable screen inside wher you just removed the hose.
4. Using a small screwdriver - pop out the screen and reverse-flush it/clean it. It will likely be full of sediment and calcium deposits from your pipes.
5. Replace the inlet screens.
6. Re-fit the hose to the machine.
7. Turn on water supply valves.
8. re-try.
Thanks
Posted on Nov 19, 2010
My fisher n paykel draw dishwasher wont start it has three buttons a (on/off )(play/pause)(lock symbol) wat do i press to make it all start,
First press the ON/ OFF button to see if the display lights up. Once you select the program from the panel then press the PLay/ Pause button to start the cycle. Pressing the key button will prevent accidental pressing of the ON/ OFF or the Play./ pause button when the dishwasher is running. It is a child lock button. To turn it off (if you have selected it) press Keylock button again.
Dec 15, 2013 | Fisher and Paykel Dishwashers
Fisher Paykel washing machine Smartdrive 703 Advance, Power and Start buttons are non responsive when pushed. Is there a part that can fix this. Does the control panel have to be replaced?
Fisher & Paykel Smart Drive beeps and stops during rinse cycle. If I hit pause and wait and restart it eventually continues. It seems like it has problems detecting water level.
Apr 13, 2011 | Fisher and Paykel GWL11 Top Load Washer
I have a F & P w/m MW058U, & have just recentley replaced the cold water inlet valve & the w/m worked fine for a couple of loads.However now its not working at all, the lights all work on the...
Almost impossible for someone out here at the other side of the internet to say when we can't see or test anything. All I can suggest is before you press start the light on top row should be blinking. Now when you press start do you get a beep and the light stops blinking and stays steady? If it does then the most likely problem will be a faulty lid switch. Apart from that I suggest you get a service person out who can look & test for you.
Nov 10, 2017 | Fisher and Paykel Fisher Paykel Intuitive...
Fisher and paykel washing machine GW603 (14 years old) will not power up. When the power is turned on from the power point all the LEDs light up, the machine beeps and then all the LEDs turn off within 1...
What you describe is normal for the power on cycle. If if will not work after this, then you have a problem. If it will not turn on by pressing the power button, try one of the wash type buttons. If it responds to the power button or the wash type buttons and beeps with the start/pause button and the lid is closed, then the lid switch is faulty, if it does not beep and the lid is closed, then the button is faulty and can be replaced on it's own by anyone with some soldering ability.
Aug 19, 2010 | Fisher and Paykel Fisher & Paykel Washer
WATER PUMPING IN SPASMODICLLY AND THEN THE BEEPS COME AND MACHINE TURNS OFF. i HAVE A FISHER PAYKEL MW058U TOP LOADER. SAME THING HAPPENS ON SPIN CYCLE.
there r 3 reasons this happens. 1st the out of balance switch is faulty. 2nd the rotor senor near the motor is faulty. 3rd your control board is faulty. have u got an electrical test meter to test the components? please reply 4 more help. 95% of the time the faulty part is the the out of balance switch.
May 01, 2010 | Fisher and Paykel Washing Machines
Wont stop filling
If when you press pause while filling and it keeps filling then you have a faulty valve. If the filling stops then valve is ok.
If you filling keeps going until overfilling the machine which is what i understand is your problem, then most likely that you have a small pinhole in your pressure tube.
Apr 18, 2009 | Fisher and Paykel Fisher Paykel Intuitive...
Fisher and Paykel MW058U won't fill
Fault is out of balance switch stuck on i removed and cleaned mine with crc but if still stuck on may need replacing hope this solves your problem
Jun 18, 2008 | Fisher and Paykel Fisher Paykel Intuitive...
Fisher and Paykel 23 Top washer isn't coming on
is the lock symbol showing in the lcd badge when it's not back lit can be hard to see ,if it,s showing push lock button till it beeps release immediatly now try power button or start/pause button
Jun 05, 2008 | Fisher and Paykel 23 in. DD-603SS Built-in...
Washing Machines Logo
67 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Gerry Harvey
Gerry Harvey
michael_t919
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
