Question about Belkin Basic Wireless Router
When we plug in the Router to the internet, its still red
    Problem Solver:
  • 9 Answers
After reset, Check with 192.168.2.1.
Posted on Nov 30, 2010
Try to reset the router and check with the 192.168.1.1 in the IEXPLORER . try to scan ! if still problem contact the internet service provider....
Posted on Nov 12, 2010
Router dsl3780 red internet light keeps coming on
Usually indicates problem with the router's internet connection. Check the LAN cable between your internet modem and router and try a new cable. Reboot both devices. Direct connect to the internet modem to see if it is working correctly with interruption.
The final solution is a factory reset of your router. You can do a factory reset by logging into the router using you browser. Go to the settings and perform a factory reset
If you forgot the router password, you ill have to do a factory reset by locating a small hold on the back of the router and insert the tip of of paper clip for about 10 seconds while the power is on. The router will be reset to out of box status and then you can set-up form scratch.
Nov 21, 2013 | D-Link Computers & Internet
No internet connection through my router, wirelessly or plugged in. theres a red light rather than the green one
If the RED light is for POWER. Then the router is already busted. If the RED light is for the INTERNET light, then it's just a configuration. Best person to contact is your ISP (internet service provider)..
But if you can provide me details of what is your ISP and what authentication they are using, I can definitely assist you. :)
Regards.
Aug 23, 2011 | Belkin (F5D5231-4) Router
Was working ok then internet down and red light on router constant - have done the turn off turn on routine and reset router to no avail. have also plugged indirectly to computer - green light then comes...
Try rebooting both the modem and the router. It could be that the modem didn't pick up it's ip number when the internet went down. Then try pluggint you computer directly into the modem first to make sure it is setup and working properly. Then plug in the router (to the modem) and the PC plugged in directly to the router and check.
Once you have it connecting at that point then check the wireless settings on both the router and the pc. Then enable the wireless on the pc, unplug the LAN and switch to wireless network on the pc and see if it won't work.
If it works plugged in on the LAN but then not on the wireless then either your configuration isn't correct (ie wrong gateway ip number...gateway should be the same ip number as the router...ie 192.168.***.***) or perhaps the wireless part of the router died. It is possible for the wireless to die and the LAN (hard wired connection) to still work.
Aug 08, 2011 | Belkin N Wireless Router wireless router
Net gear N 150 adsl+modem router internet led always glowing red or of why plz fix this problem...............
If the light is out or red, then you are not getting any power or you might have a power supply problem. In most cases a red light on the modem or router indicates hardware problems. You can purchase a new power supply for it. It could be the modem is bad, the question is, do you still have an internet connection? If so, it is probably a faulty light or power sensor, and the cost of a new modem or power supply may not be worth the effort. If you do not have internet connectivity, then you have a totally seperate issue and then you should call your ISP and ask them about your internet connection. It could be your internet is down or they have line problems. It may also be that you are plugged in to a multi outlet strip and you should try plugging it in directly to the wall.
I hope this was useful and please comment if this was helpful to you.
Mar 16, 2011 | NetGear DG834 Router
Lost internet connection, router has a red light on it but i cant connect
Just for you to be aware, a red light on the router means it failed.
Depending on where the red light is, that is where the connection failed, if the red light is on DSL, it means that there is a problem with the server (internet service provider) but if the red light is on INTERNET (authentication failure = router needs to be reconfigure) etc.... to better assist you contact your service provider.
Oct 02, 2010 | D-Link (DI-711) Router
Ethernet to router connectivity issue
The correct way to do the connection is by plugging the Desktop to one of the Ethernet ports and any wireless device over the wireless network.
Dec 01, 2009 | Zyxel P660HW-D1 Router
The red led light on the internet connection on my d-link router is on. i cannot connect to the internet now. i have a green light above the dsl connection and their is one other green light on. i have...
1st: Have you paid your bill?
2nd: Have you power cycled?
Full Power Cycle is as follows:
Turn off all components plugged into the router(Computers, Printers, etc.) Unplug the power from the router. Unplug the data cable(DSL, Coax) going TO the router. Wait aprox. 1 minute. Plug data cable and power cable back into router. Wait about 1 minute. Turn computers back on. Problem Solved?
If not and you're using DSL make sure all DSL filters are in place and that none have come undone. Make sure the phone line is still plugged in. Problem Solved?
If not contact your ISP and ask if they are doing any maintenance in your area that may by effecting your service. Ask them to perform a line test on you. If all else fails ask them to have a technician come out and help solve the issue.
Oct 23, 2009 | D-Link DI-704P Router
There is a red workd globe lit up on the front of
So that means your computer works when connected directly to the imternet modem .
You will need to check the settings of the router.
or may be you will need to set up the router again.
Click Here for more info
Oct 22, 2009 | D-Link DIR-615 Wireless Router
Problems moving the router and getting the internet.
your bedroom cable phone plug has issue.
These is not dial tone or low voltage problem in line.
So just replaced that phone cable and jack .then check.
Aug 07, 2009 | Linksys WAG200G Router
Red internet light stays on
the following link provides some very streightforward advise;
http://www.qwest.com/internethelp/modems/gt701/pdf/13566_GT701_ServiceStatus_031906msl.pdf
check the following in order
1 check that all of the cables are securely plugged in, if you find any loose plug them back in, you may need to powercycle the router afterwards though if the router is subsquently plugged into another unit down the chain power off both units turn them back on turning on the actiontec last.
2 if your ISP requires logon details to be included in your router, double check by viewing your router settings renter them if you are unsure.
3 lastly, have you paid your ISP bill?
Nov 05, 2008 | Actiontec GT701WG Router (actiongt701wg)
Belkin Basic Wireless Router Logo
43 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
