Question about Sony KV-27S42 27" TV
I turn the power on, but it keeps shutting off. The standby light is pulsing two times if that helps any. Thanks
    Top Expert:
  • Sony Master
  • 74,377 Answers
Hello
Two blinks of standby light in Sony sets denotes that there is some short circuit inside the circuit board. It could be with a shorted capacitor, shorted horizontal output transistor or defective Line Output Trnasformer otherwise known as [LOT]. To determine it you have to open the TV. You must have a concept of soldering and more confidence. LOT described above can be located on the mainboard itself. One wire from it goes to the top side of the picture tube's final anode, and seem to be sticked to it with a rubber ******. That is [LOT]. Very near to that LOT you can locate the horozontal output transistor stated above, screwed onto a metal heatsink. You just resolder it out from the board, and check it for collector to emitter leak. It is best to replace it with a new one of same type and number. Insist on same type and number, since it is a critical component. After replacing it, just switch on the TV for a few seconds, say four or five, and switch it off, unplug it from wall socket and feel the heat of that trasistor with bare fingers. If it overheats, it is a sure symptom of LOT fault. You have to replace the LOT also with same type and number. Before replacing the above said components, you just resolder the transistor said above, and just switch on the set without it. If the sytandby LED lights for the same number of time, there may be any shorted capacitor in the main secondary supply rail; usually 130VDC, LOT power supply. There is a EHT boosting capacitor fitted very near to the transistor said above, at about 470Pf; ceramic or so. There is a chance that this capacitor may get shorted. Anyway, your TVs secondary power supply rail has a short. Two blinks of standby light denotes Over Current Protection [OCP]. It is a self diaganosis process going inside the the TV, and every Sony set has the same fuction. Ok
Take every precaution before you open the TV. Mind that you are going to work with an electrical equipment, which has as high as 26,000VDC points are inside it. Keep chlidren away from you while you are working. Not even allow them to come nearby you, and let an adult beside you as a precautionary measure. Ok
Posted on Nov 12, 2010
  • Sony Master
  • 467 Answers
2 blinks of the standby LED - denotes B+ over current protection (OCP) mode. Usually due to a short-circuit on one of the main voltage rails between the power supply and horizontal output stages.
Check the horizontal output transistor(s), the flyback transformer for shorts, and check all the tuning capacitors in the collector circuit of each transistor as applicable. The working voltages of these caps should be uprated whenever they're replaced.
Posted on Feb 22, 2011
Power light blinking on nv53a gateway
Your Gateway laptop comes with a series of LED lights that alert you to the state of your computer. You'll notice there are blue, purple and red lights that either blink or display solidly. Each light, blinking or solid, has a different meaning. The blue blinking light on your laptop indicates that it is in Standby mode. Your laptop goes into Standby when you close its lid without shutting down the computer. To turn this light off, you'll need to take the computer out of Standby mode, and if you want to ensure that the blinking blue light does not return, shut down the computer after each use.
Open the lid of your Gateway laptop and press the power button. Once Windows loads, enter your password if required. The blue light will no longer be blinking because the computer is no longer in Standby mode. Shut the laptop off when you finish using it rather than simply closing the lid to stop the blue light from blinking again. Click "Start" from your Windows desktop and click "Shut down." Change your computer's power settings to keep if from going into Standby mode when you close the lid if you'd rather not shut down your computer every time you use it. Click "Start" and click "Control Panel." Click "System and Security" and then click "Power Options." Click "Choose what closing the lid does" from the list of options on the left side of the window. Select "Hibernate" from the drop-down lists under "On Battery" and "Plugged In." Click "Save Changes." Your laptop will now bypass Standby mode when you close the lid and it will enter Hibernate mode instead. Hope it helps.
Jan 23, 2013 | Gateway MT6730 Notebook PC
Sony tv won't turn on, light in standby blink three times
that is a master control board failiure, it is caused by having your TV on all the time, when the TV gets warm, you need to shut it off and let it cool down(that caused your problem) call sony and order a replacement part, it will take you about 20-40 minutes to install yourself.
Jul 19, 2012 | Televison & Video
Will not come on. red light flashes 4 times
Never a good sign when you have red flashing codes
4 times, Diagnosis: Vertical deflection stopped. Possible causes: +- 15V is not supplied. (D board), IC8003 is faulty. (A board) Symptoms of the problem: TV has entered standby state after horizontal raster, Vertical deflection pulse is stopped, Power line is shorted or power supply is stopped.
Please rate my help++++Thanks for using FIXYA
May 28, 2010 | Sony KDS-50A2000 50" HDTV
Sony kdf 50e standby light flashing 2 pulses
If your tv is Sony KDF-50E2000 model then 2 times standby light shows problem of over temperature in tv. Check temp sensor in tv.
If model number is different, let me know complete model number written on label at rear of tv to help you out.
Thanks.
May 14, 2010 | Sony KDS-R60XBR1 60" Projection HDTV
Will not turn on, red light blinks 4 times
In general when you have a blink of 4 times.
It indicates the Vertical deflection is stopped.
Symptoms of the problem: TV has entered the standby state after horizontal raster, Vertical deflection pulse is stopped, Power line is shorted or power supply is stopped.
To guide you in the right direction do provide details about your TV .
Hope this helps .
Jan 23, 2010 | Sony Televison & Video
My Sceptre LCD TV (X32GV-Komodo0 power turns on
1. check power supply
2. check flyback
Ether or you have a ppower fauilure in the unit. and its probably blowing fuses.
Aug 31, 2009 | Sceptre X32GV-Komodo 32 in. LCD Television
Sony WEGA Fails to Turn On Stand-by Timer Flashes 7 Times
IC/high power transister(s) and/or other componentshas gone bad gone bad - usually from a power surge. These will have to be replaced. A technician should check these out for you.
Jun 03, 2009 | Sony FD Trinitron WEGA KV-27FS100 27" TV
Sony kde37xs955 green light blinks 9 and red light blinks 6
hi..
It's in standby mode.
Do a reset and see what happens
While holding down the reset button on the remote
Press the power button on the tv
(The tv will turn itself off the back on)
Now release the reset button
It sounds like the lamp needs replaced....
thank u!!
rate me!!!
Apr 10, 2009 | Sony WEGA KDE-42XBR950 42 in. HDTV Plasma...
VCR automatically goes into standby mode
If this unit shuts down after you turn it on, it is going into stanby because the microprocessor is not seeing the proper pulses from the mode switch. this could be due to an out of time mechanism because of a broken gear, bad mode switch, the loading basket is out of time or broken, or the capstain motor or the cylinlinder motor is not sending the PG and FG pulses to the microprocessor. These can also be due to a power supply voltage missing. You can check the voltages with a service manual and make sure they are not low. You will also need to get the mechanism manual and check the timing of the mechanism. Then check the mode switch you can get a manual from here http://www.servicemanuals.net/results.aspx?brand=15&model=HRS&type=SM&pos=281 Good Luck
Mar 21, 2007 | JVC HR-S9900 S-VHS VCR
Sony KV-27S42 27" TV Logo
481 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
