Cannot playback some type of video - Computers & Internet
  • 34 Answers
Download final media from www.finalmediaplayer.com
Posted on Nov 12, 2010
How do i create a readable DVD so that it can be played in a dvd player or PC?
Yes and No... well it depends on what type of file you're likely to burn. A PC supports all type of files (MKV,MP3,MP4 etc..). Nowadays you easily convert the video file to support playback to your favourite videos.Moreover, a third party program is now created with an ease to their users by auto converting the file to suitable playback.....so the ANSWER IS YES.
Oct 11, 2014 | Computers & Internet
Can you give me technical specs for LCD TV TH-L32E3A. Thanks
The proof copy of the Owner's manual includes the specs for the TH-L32EA and is available from: http://www.panasonic.com.au/Support/Customer+support/Downloads+and+documentation . Enter the model number under keywords and then click search (do not use the drop down menus).
Specifications
Power
Power rating AC 220 - 240 V, 50 / 60 Hz 0.33 A
Normal (Home) mode 42 W
Standby condition 0.2 W
Display
panel
Aspect Ratio 16:9
Visible screen size 80 cm (diagonal)
698 mm (W) × 393 mm (H)
Number of pixels 2,073,600 (1,920 (W) × 1,080 (H))
Sound
Speaker 160 mm × 42 mm × 2, 8 Ohms
Audio Output 20 W (10 W + 10 W )
Headphones M3 (3.5 mm) stereo mini Jack × 1
PC signals
VGA, SVGA, WVGA, XGA
SXGA, WXGA ······ (compressed)
Horizontal scanning frequency 31 - 69 kHz
Vertical scanning frequency 59 - 86 Hz
Receiving Systems /
Band name
PAL B/G Reception of Off air broadcasts
Digital TV 7 MHz VHF / UHF (Australia) free-to-air TV broadcast reception
PAL 60 Hz
M.NTSC
NTSC
Playback of NTSC tape from some PAL Video recorders (VCR)
Playback from M. NTSC Video recorders (VCR)
Playback from NTSC Video recorders (VCR)
Aerial - Rear Standard Belling & Lee connector
Operating Conditions Temperature : 0 °C - 35 °C
Humidity : 20 % - 80 % RH (non-condensing)
Connection Terminals
AV1
Input
AUDIO L - R RCA PIN Type × 2 0.5 V[rms]
VIDEO RCA PIN Type × 1 1.0 V[p-p] (75 Ohms)
COMPONENT Y 1.0 V[p-p] (including synchronisation)
PB/CB, PR/CR ±0.35 V[p-p]
AV2
Input
AV3
Input
Audio
Output AUDIO L - R RCA PIN Type × 2 0.5 V[rms] (high impedance)
Others
HDMI1 - 3
Input TYPE A Connectors • This TV supports "HDAVI control 5" function.
PC Input HIGH-DENSITY D-SUB 15PIN R / G / B: 0.7 V[p-p] (75 Ohms)
HD / VD: TTL Level 2.0 - 5.0 V[p-p] (high impedance)
DIGITAL
AUDIO OUT PCM / Dolby Digital, Fiber optic
Card slot SD Card slot × 1
USB 1/2 USB 2.0 TYPE A Connectors DC 5 V, Max. 500 mA
ETHERNET 10BASE-T / 100BASE-TX
Dimensions (W × H × D) 769 mm × 514 mm × 207 mm (With Pedestal)
769 mm × 480 mm × 75 mm (TV only)
Mass 11.0 k Net (With Pedestal)
9.5 k Net (TV only)
(See page 73 of the manual for the specs as a table - I used Proof 2)
I hope this helps.
Apr 20, 2011 | Panasonic Kitchen Appliances - Others
I have a nokia E72 and im just wondering that it cannot play video sent through bluetooth. please help
Check the video file type. It supports below formats.
  • Video playback file formats: .mp4, AVC/H.264, .wmv, RV, Flash Video, H.263/3GPP
  • Video streaming: .mp4, AVC/H.264, .wmv, RV, Flash Video, H.263/3GPP
Mar 30, 2010 | Nokia E72 Smartphone
Video playback
The playback for the videos is the same as the photos. Once you are in playback mode, use the directional button to go left or right to find the video, once you found it press "up" on the directional button to start the video.
Aug 13, 2009 | Polaroid i733LP Digital Camera
Playback on camcorder
Have you tried to play the video files through your PC?
With the SD card inserted into a card reader, i woul dsuggest you right click on the '?' files and click 'properties' and look for the file type as it has obviously changed.
When you find the file type, you will need to download the appropriate software to view it.
I know that VLC media player (google it, free software) id an excellent media player and supports many formats.
I hope this helps a little.
Karlos
Jul 04, 2009 | Video Cameras
Lg e500 notebook smart cam double speed and no sound on playback
the problems is that it saves the video in a compressed codec....I do believe it will run normally if you install real player ..I know that real player used some kinda of file like this ...but to solve the problem be more aware in which file type you save the capture...I also sugest to find a capture program which will have more obtions...or a converter ..to convert the captures into avi...divx type ...
Nov 12, 2008 | LG X-Note LM50 Notebook
Tapes won't Playback in other deivice
Hello! If the recorded tapes playback ok on the camera and not ok on another devices, you need to readjust the playback on this camera using a tape which playbacks fine on the other devices. This means that is a small difference on the tape transport. So when the supply and takeup post rollers readjusted and the audio and video playback are good, then your camera is fine.
Sep 14, 2008 | Panasonic AG-DVX100A Mini DV Digital...
I dont know what type of video my RCA LYRA MC5104B and how can i change my video type?
Video Playback (MPEG-1,2,4/DivX® Certified/WMV-9)
Use the transcoding software that came with the player to convert the videos into proper format (if no install CD, then go to: http://support.rcaaudiovideo.com).
If RCA software fails to convert, you can download a product called Media Monkey, and it will convert your video file type as long as the video does not have DRM-encryption on it. If the videos are encrypted then you will have to buy DRM removal software to convert it.
-Tha Mp3 Doctor
Mar 19, 2008 | Audio Players & Recorders
Computers & Internet Logo
18 people viewed this question
David Payne
David Payne
