Question about Seagate Barracuda 7200.7 40 GB Hard Drive
I would like to know if 512 KB Ram is better than192.0 MB. I don't know what the Ram is for the 192.0 MB but for the new one is a 40 GB hard drive.
    President:
  • 1,812 Answers
Actually you want to know 512 mb either better than 192mb or not ob course better b
Posted on Nov 12, 2010
Install or download the NBA 2k11 to my loptop
Hi xselenegonza!
Check your system specs and look if you pass the minimum requirements to run the game.
Minimum System Requirements:
CPU: Pentium 4 2.4 Ghz Single Core processor or equivalent (2.8 Ghz for Vista)
RAM: 512 MB or more (1 GB for Vista)
Disc Drive: 8x or faster DVD drive
Hard Drive: 10.5 GB or more free space
Video: DirectX 9.0c compatible (see below)
Sound: DirectX 9.0c compatible
Input: Keyboard or dual-analog gamepad
Video card with 128 MB or more memory and one of the following chipsets is required:
ATI x1300 or greater;
NVIDIA 6600 or greater;
DirectX 9.0c compatible card with Shader Model 3.0 support.
Important Note: Game requires Internet connection for activation
Recommended System Requirements:
CPU: 3 GHz Dual Core processor or equivalent
RAM: 2 GB
Video: Shader Model 3.0 support with 512 Ram (Nvidia(R) Geforce(R) 7900 GT or better)
Sound: 100% DirectX 9.0c compatible sound card
Input: Dual-analog gamepad
DirectX 9.0c or DirectX 10
For more info (Click here)
Sep 19, 2011 | Computers & Internet
I have desktop computer with celeron processor CPU 240 GHz and 512 MB ram with 40 GB HArd disk.. I see my hard disk encountered some problem and planning to by new hard disk ..which is best for me and the...
Hi ,
I assume you are under Windows XP but this will also work under Windows 7 32 bit .
You can insert a 100GB HDD without any problem . A higher capacity is risky with your type of machine and could lead to a fatal read error , meaning you couldn't boot your unit anymore .
Under a 32 bit XP system , 2GB ram is the max.
I don't recommend changing the processor with the motherboard , you could encounter conflictual issues with the rest of the unit .
Buy yourself a new pc equiped with a I5 or better with a I7 processor running under W 7 64-bit is the solution but they still are expensive .
Best regards .
Jan 30, 2011 | eMachines Desktop / Intel Celeron...
I upgraded my RAM to 1 Gig but it's still showing only 256 meg. Why?
Hi this model sopport 2Gig Memory Ram.
RAM Technology DDR SDRAM Installed RAM 512 MB Max Supported RAM 2 GB Number of Memory Slots 2 x DIMMs Supported RAM Speeds 400 MHz • 333 MHz Installed Cache Memory 256 KB
Please check in to your Bios system maybe share memory Video or capacity is setting
Nov 03, 2010 | Dell Dimension B110 PC Desktop
Big city rigs
first check if your computer answers the following requirements:
Windows® XP/Vista
Minimum Requirements:
  • Pentium® 1.7 GHz or similar processor
  • 512 MB RAM
  • DirectX® Compatible Video Card
  • 128 MB Video RAM
  • DirectX® 9.0c
  • 2 GB Hard Drive Space
  • Mouse
Recommended Requirements:
  • Pentium® IV 2 GHz or similar processor
  • 512 MB RAM
  • 3D Video Card with at least 256 MB Video RAM
  • DirectX® 9.0c
  • Mouse
if you do, please tell me exactly what happens when you try to install the game
Jan 25, 2010 | ValuSoft 18 Wheels of Steel: American Long...
IS IT POSSIBLE TO INCREASE MEMEORY? BOTH RAM AND
Yes, it's possible to increase both RAM & HARD DRIVE Capacity.Your Pc comes with RAM: 512 MB in size and Storage (hard drive)Capacity: 80 GB.
You can put One more 512 MB of RAM or you can replacethe ealier RAm with 1GB RAM or Put two 1 GB RAM Instead.
For Hard Drive,use your 80 GB Hard drive as external storage device, and Put a 320 Gb new Hard drive.
Dec 26, 2009 | HP Pavilion dv1000 Notebook
Change ram from 512 to 1 gig bios cannot read added ram
The original 2 sticks of 256 Mb of RAM gives you a total of 512
Mb of RAM. Two 512 Mb of RAM gives you a total of 1 Gb of RAM.
With two sticks of 512 Mb of RAM are you sure you got a total of 192 Mb of RAM, this is a lot less than the original RAM total of 512 Mb?
Should this be 1920 Mb of RAM?
If this 192 Mb is correct then the RAM modules are either not compatible with the laptop or if the RAM modules are not from the same manufacturer then they may not work together.
Most laptops have video cards that use part of the main RAM for video RAM, that is why the available RAM is less than the installed RAM modules. The amount of RAM the video card grabs depends upon the type of video card and in some cases the amount of video RAM can controlled in the BIOS setting.
Nov 07, 2009 | Sony VAIO PCG-K25 Notebook
Ddr ram 1 stick or two
No it doesn't. Technically, kB is 1024 Bytes, a MB is 1024 kB, and a GB is 1024 MB. The boring techno-jargon can be found here. You're fine installing two 512 MB sticks - no worries.
Mar 21, 2009 | Western Digital 60GB U100 5400RPM 2MB...
Bigger hard drive
I'm not sure if the motherboard supports SATA drives, so your best bet is getting any IDE (ATA) hard drive. It's up to you which kind you want. I've always been partial to Western Digital and Seagate.
If you are running Windows XP then you shouldn't have a problem with having a larger hard drive, I know Windows 2000 had some issues with them that required registery editing.
Dec 11, 2008 | Sony VAIO Digital Studio PCV-RZ22G PC...
Need to now cpu in my laptop
This is just a rough guide, as it all depends on the the games your looking to play, but this is about normal to get games running without problems :
MINIMUM SYSTEM REQUIREMENTS:
Microsoft(r) Windows(r) XP Service Pack 2, Vista
• 1.8 GHz processor
• 512 MB RAM
• 8 GB available hard drive space
• 128 MB video RAM or greater, with DirectX 9 Vertex Shader / Pixel Shader 2.0 support
• Sound card, speakers or headphones
• 56.6 Kbps Internet connection required.
RECOMMENDED SYSTEM REQUIREMENTS:
3.0 GHz Intel or equivalent AMD processor or better
• 1 GB RAM or better
• 10 GB available hard drive space
• 256 MB video RAM,
with DirectX 9 Vertex Shader / Pixel Shader 2.0 support (Nvidia 6800 or better)
• Internet connection with Cable/DSL speeds
Note: recommended specifications provide optimal experience for single player and up to 4 player/medium size map multiplayer.
Dec 05, 2008 | Dell Inspiron B130 Notebook
Seagate Barracuda 7200.7 40 GB Hard Drive Logo
55 people viewed this question
Top Seagate Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Computer Links
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
