Question about LG LRTC19314ST Top Freezer Refrigerator
Freezer is working but freeze is warm .water leaking from the light . i noticed there is little filter next to the light. i raised the temperature but no luck
  • Anonymous Mar 12, 2014
    theres a red icon next to the freezer temperature i just noticed it wasnt there before what does that mean
  • 34 Answers
If freezer is warm though you've raised the temperature, it is a major problem. If you've valid warranty then call the dealer and they'll definitely fix every problem.
If warranty does not covers, then you should call some A/C and Refrigerator mechanic(you will definitely find some in your local area) to fix this.
Posted on Nov 12, 2010
We have got water coming out at the bottom of the freezer of our fridgidair FRC170FF how do i fix it?
1. Your freezer may be not cold enough so water does not freeze.
2. Your freezer may leak so warm air goes into the freezer and keep the temperature higher than freezing temperature.
Jul 03, 2014 | Miele KFN8762SDED Bottom Freezer...
Coils freeze up
Rick. the freezing of the coils can be caused by several things:
1. Air intake filter needs to removed and cleaned.
2. The coils may be dirty. Clean the coils with warm water, wiped dry and a light coating
of WD40 applied to the coils.
3. Restricted air flow. Maintain a minimum of 12 to 18" around the entire dehumidifier while
in operation.
4. The air temperature at floor level is 40 degrees F or lower, than the ambient air temperature
at shoulder level. This is particular true in basement applications. Raising the unit up off the floor
on to a sturdy table, cabinet top, etc, that's strong enough to hold the unit, plus a full bucket of
water generally resolves the situation.
Worse case scenario is that the defrost sensor has failed or there is a small leak in the cooling coils.
I hope this helps you troubleshoot and solve the problem. Thanks for choosing FixYa.
Jul 21, 2011 | LG LHD459EL Dehumidifier
The refrigerator is warm
could be your compressor going out. how old is the fridge.make sure that was water and not freon check your coils unde the fridge see if there really warm. and most people don't clean these out so the icebox has to work harder.
Apr 14, 2010 | Whirlpool ET8MHEXR Top-Mount Refrigerator...
Our subzero freezer has a new problem. The cubes
Ice cubes WILL BE slightly moist when they land in the ice bucket. they've just been slightly melted in order to eject from the ice maker. Stop playing with the settings, for starters. put them back to normal, i.e., middle setting, place thermometer in center of freezer, and if you can, one in center of fresh food. monitor after 24 hours, and for the next three days thereafter. freezer temps should be in the -5 - +5°F, sometimes up to 10°, fresh food should be 35-40, sometimes up to 44°at the normal settings. If you are not having temperature issues, see if you notice any frozen drips of water on the underside of icemaker, indicating a possible crack in the ice maker mold, or a faulty water valve. You didnt include your model and serial number, so not knowing the path of the ice shoot, some go out the freezer door, some slide over and get dispensed from the fresh food side. Its possible you may have a problem instead with the flapping door that opens to allow ice cubes to be dispensed, or similar type mechanism. If this door does not seat completely when its closed, it will leak warm air directly into the ice bucket, which would make them slightly moist, also too, this warm air can cause frost and ice to buildup near the warm air source...look for any unusual forms of ice and or frost leading up from the flapping door to the ice bucket. Also look for any gaps in the door gasket when closed, this warm air leak can also cause similar problems, but its most likely with the ice door. could be the door, the spring, the solenoid, or something else i wouldn't know without personal refrigerator inspection.
Mar 27, 2010 | Freezers
Frigidaire FP120V Fridge is too warm, yet freezes in crisper
There may be vents that need to be closed and or opened a little for proper adjustment.
Is your circulating fan working?
Sometimes they stick and need a shot of WD 40 and then work
it back and forth a little until it wants to take off again. Keep me informed
and PLEASE give a Thumbs Up for the effort. The Raz Shack
Jan 04, 2010 | Freezers
Water dipenser
The instruction book suggests this could be because the freezer temperature is set too low. Mine is set at -20C. It says the water line can freeze stopping water flow. Try reducing the temperature.
Sep 03, 2008 | Samsung RS2630SH Side by Side Refrigerator
GE Refrigerator Freezer warm
the frost on the back wall of the freezer is the clue to the problem. it is not defrosting as it should.
  • possible causes:
  1. bad defrost timer/control board
  2. bad defrost heater (in freezer)
  3. bad thermo switch in freezer
If you don’t know what these are then unplug the machine and let the ice melt in the freezer overnight with the door open. Then try it the next day, if is cooling fine then you need to have a service person replace one of the above items.
Jul 22, 2008 | Refrigerators
Kenmore Side by Side Refrigerator too cold
On a fridge freezer only the fridge temperature is monitored. In a cold location the fridge might not even need cooling and the freezer would get too warm but the thing won't care.
If the fridge sensor sees it as too warm then it will keep the motor running and the first thing to get really cold is the freezer.
Remember the freezing part is not temperature controlled ion a fridgefreezer.
Apr 28, 2017 | Refrigerators
Water freezing at bottom of refrigerator/Temperature not right
thats a water tank holding water dfor the dispensor, if everything in refrig is freezing quite possible that the water in tank froze as well, which would explain no water,
Feb 24, 2008 | GE PSS26NSWSS Profile 25.5 Cu. Ft....
Leak from icemaker shorts electricity in house
It sounds like the ice in the bin is warming up enough to melt for some reason then re-freeze. Check your door gasket seal and also the ice chute door flapper seal to make sure warm room air isn't being drawn into the ice bin area. Also make sure the freezer area is VERY cold like 0 degrees F or lower, that will keep the ice hard and help stop the ice from having a liquid surface film from opening and closing the freezer door too often (then freezing again). The water down the back is from the ice cubes melting a little then re-freezing. Also, is the frige working OK? Does the compressor turn on and off normally? I ask because sometimes the compress start device is failing and the refer can warm up quite a bit while the compressor is trying to start up... eventually the compressor will start but by then the ice has melted a little then the compressor runs for a long time to bring the temps down again. Monitoring with a thermometer every hour will show if the temps are lowering in the freezer section too much.
Dec 10, 2006 | Maytag MZD2669KE Side by Side Refrigerator
LG LRTC19314ST Top Freezer Refrigerator Logo
75 people viewed this question
Top LG Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
christian nielsen
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
