Question about Samsung LN-S4692D 46 in. LCD HDTV
T-con board what does the t-con board look like and where is it located?
  • 6 more comments
  • jovi1 Jun 23, 2008
    The screen is blank but i can hear
  • Anonymous Aug 19, 2008
    I have the same problem. My TV went black in 5 months after the warranty expired. I dont think Samsung cares. Does anyone know if there is a class action suit?
  • gchristian Aug 22, 2008
    my set went out after 14 months & the Best Buy service tech came out;diagnosed it and said that the t-con board was out but that the only way to repair it would e to replace the entire lcd panel. He said you could not just get the t-con board by itself from Samsung. By the way, I have a 40" Samsung LCD
  • titanne Sep 04, 2008
    replaced T-Con board have a picture but it is not clear.
  • Anonymous Mar 03, 2009
    Samsung LN-R328W
    Two years old and told by service bad t-con board, can't buy alone must buy panel with t-con board [expensive].
    Now going in trash ! 1000 Dollar tv when new !
  • fddizon May 20, 2013
    see capacitors from power supply board that are swollen/bulged on top of them. remove and replace.
  • doom393 Apr 17, 2014
    sony lcd tv model kdl-52nx800 turns on the shuts off red light blinks 5 times pauses then 5 times
Can purchase just t-con board online for small fee and replace yourself. ShopJimmy.com
ours went out after 5 months and it was still under warranty. samsung wanted us to send it to them and it would have cost me $70. i just bought the part online for $20. way better deal
Posted on Oct 08, 2010
My Samsung TV (LN-S2651D) has sound, but no picture (black background). What part do I need?
Posted on Apr 01, 2011
About eight inches wide, five or six inches high. It is behind a a foil aluminum cover at top dead center in back. Some Framing (obvious) has to be loosed a lot to get it changed out. It is an easy but delicate changeout.
I got mine from a Califoria Samsung warehouse when the service person said they were backordered nationwide. I think the vender was Samsungparts.com.
Two months after I fixed it, the serviceman called and said the part was in. ha.
Posted on Jul 26, 2008
Hello! I have a Toshiba 42HL67US. I am looking to replace the T-Con board, but Don't see the board when the rear case is removed. I need a diagram showing the locations of the boards. Thanks
Follow the ribbon cable from the main board to the T-Con board. Most likely at the bottom of the TV and could be behind a metal bracket.
Oct 20, 2017 | Toshiba Televison & Video
I have a Sony KDL-43W755C LED TV with a T-CON board problem. Opening the back I can see the BMX board but not the T-CON. Can anybody indicate its location? It doesn't seem to be top dead-centre.
The T-con on this model should be located in the bottom center of the TV. When the back is off you should see it bottom middle under a metal shield.
Oct 05, 2017 | Sony Televison & Video
Where is the location of T CON board on NS LCD32
Cheryl, I will post links to what the T con board looks like so when you remove the rear panel from TV, you will be able to compare and find it easily.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
LCD TV Repair Tutorial Con Board Common Symptoms Solutions How to Replace...
INSIGNIA NS LCD32 Con Board LC320W01 SLA1 6870C 0142B 2L
Amazon com INSIGNIA NS LCD32 CON BOARD CPT 320WF01C SD Electronics
Mar 23, 2016 | Insignia NS-LCD32 LCD TV
Which board is the t-con board?
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience.
http://electro-medical.blogspot.com/
Search the site by type in "T Con board" in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Feb 06, 2016 | Philips 40pfl3705d/f7 40-inch 1080p 120 Hz...
On 47-inch Westinghouse monitor, where is the T-con board located?
hi,
There will be a strip wire from the Mother boad to the display section, it will ends in the T Con board. Normaly in lcd monitors the T Con board will be shielded with aluminum sticker foil, in the lower middile section of the monitor.
ok
Jun 21, 2011 | Westinghouse VM47F140S LCD TV
My Samsung LN52A550 has vertical lines in the middle and right side of the screen is black
This most likely a problem with the T-CON board.
If this set is under warranty you should return it to get it repaired/replaced by the seller.
IF YOU KNOW HOW TO WORK WITH ELECTRONICS REPAIR(board replacement ) or have a friend with knowledge/skill you can fix it.
Sometimes due to heating/cooling or contamination the connection pins on the T-CON board and cables do not make good contacts. The T-CON board is located in the center of the set.
After taking off the back cover and shield over the T-CON board carefully remove the flat cables connected to the T-CON board. I believe there are 4. The connectors have a lip on them to hold the cables so be careful.
Now reconnect the cables. Recheck the display now. If it has not corrected you can disconnect and reconnect again.
The very first solution I entered on fixya.com had essentially this same problem and solution.
If this does not solve the problem you can replace the T-CON board.
The T-CON board look something like;
Mar 02, 2011 | Samsung LN52A550 LCD TV
Tv swiches on ok,picture is o.k but then loses about a third of picture this happens intermitetly on right hand side of screen
This is probably the a problem with the T-CON board (LVDS) or connecting cables.
If the connecting cables are not making good contact with the connectors on the T-CON board it can cause the same problem.
IF YOU KNOW HOW TO WORK WITH ELECTRONICS REPAIR(board replacing ) or have a friend with knowledge/skill you can fix it.
Disconnect and reconnect the cable(s) to the T-CON board to make a better connection.
Be careful removing the cable(s) since the connectors have a lip to hold the cable on.
The T-CON board is usually located in the center on the set behind a metal shield.
If this does not work you can replace the T-CON board.
Since you did not give a make and model I can not give more details.
Mar 02, 2011 | Televison & Video
THERE IS SOUND AND NO PICTURES
If You are having sound but no picture in Your television, then it means there is a problem, the problem mainly is caused by a bad t-con board of the television. As soon as you take the back off the set, the t-con board is located at the top middle of the set under some shielding. To replace the t-con board of the television, please get a screwdriver, a glove, a cup and a replacement t-con board.
  1. Turn off the television,
  2. Unplug it from the power outlet and leave it to rest for about 6 hours so the high voltage will dissipate,
  3. I know You will be wondering what the cup is meant for, it is for You to keep all the loosened screws so it will not get missing,
  4. Then You put on the hand gloves,
  5. Then You Turn to the back of the television, take out all the screws around the back of the television to be able to access the main panel,
  6. As soon as you take the back off the set, the t-con board is located at the top middle of the set under some shielding.
  7. Take off the shielding remove the t-con board,
  8. Then You Replace it with the new one You got for it, I will advice You take out the old t-con board so You will be able to get the exact type of t-con board that best fits in with Your television,
  9. Then reverse the process to reassemble the television.
  10. Plug it back on and power it on.
Hope this helped. thank You for using FixYa!!!
Jan 27, 2011 | LG Televison & Video
Trying to replace t-con board on a 47lg50 lcd tv, what is the eaiest way to locate and remove?
Dec 08, 2009 | LG 47LG50 47 in. LCD HDTV
Samsung LN-S4692D 46 in. LCD HDTV Logo
9,422 people viewed this question
Henry  Thomas
Henry Thomas
