Question about Refrigerators
My side by side refrigerator is not making ice and the switch is on
  • Kelly
    Kelly Nov 12, 2010
    I need a make and model number to properly assist you. There are several things that can cause this:
    1. door switch
    2. automatic defroting problem
    3. water inlet valve
    4. Ice maker thermostat
    5. Ice maker module
    6. Optical emitter board (if equipped)
    With a correct make and model number I can provide you with steps for either repair or troubleshoot your refrigerator.
    Kelly
  • 3,740 Answers
I do not recommend changing the unit temp setting per the second solution that was provided to you. Having to change the temperature for the unit to make ice is an indication that there are other problems. Experts have to maintain a minimum of an 80% rating to be qualified. Notice that the "Master" that provided you a solution only has a 75% ratng with ZERO people helped.
As I said before with Make and Model number there is a lot of information I can pass to you to try and resolve the problem.
Kelly
Posted on Nov 12, 2010
  • 34 Answers
It will take much time to form ice. increase the cold lavel to 7-8 to form much quickly.
Don't forget to lower down the lavel to medium after your ice work.
57029 Side by Side Refrigerator: ice maker not making ice and red light inside the ...
Your ice maker may be turned off. The blinking light is the sensor. The switch is right beside it. Is it in the on position?
May 16, 2010 | Kenmore 57029 Side by Side Refrigerator
Model GLH66EESB4 refrigerator. Makes ice but
Remove the ice bucket and auger assembly and hold the door switch closed while pressing the ice dispenser button to check for a dead motor. If it turns, try holding it with your hand to see if it can take a bind. If it will then your auger is the problem, if not it's motor time.
Mar 14, 2010 | Frigidaire FRS3R5EMB Side by Side...
ICE MAKER WILL NOT AUTOMATICALLY SHUT OFF
On the ice makers on refridgerators unless the ice in the bucket is high enough to raise the arm on the icemaker it will not shut off. Most people lift the arm up when they see the bucket full. I have the side by side Whirlpool model and on mine if I don't raise the arm the ice will fall out the bucket before it will raise the arm high enough.
Jul 07, 2009 | Kenmore 55693 Side by Side Refrigerator
Kenmore Ice Maker Not Working
Probably need a new ice maker, whirlpoolpartssurplus.com
Jun 23, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Makes ice very slowly to none...
You need to turn the freezer side to a cole=der setting to allow ice to freeze faster.
Mar 12, 2009 | LG LSC26905TT Side by Side Refrigerator
Ice maker in door not making ice
make sure the switch is turned on on the icemaker if it is then see if there is water in the icemaker it could be either water valve or icemaker
Dec 24, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Ice maker keeps making ice
hi thanks for the question it looks like the water valve is not shutting the water valve completely i would replace the water valve thanks the appliance doc
Sep 17, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Ice maker won't stop making ice
souonds like that sensor has gone bad, doenst know its full and contionues to make ice. youll need to repalce the electronic board.(they come as a kit both emitter and reciever,)
Mar 08, 2008 | Kenmore 55693 Side by Side Refrigerator
Kenmore Refrigerator
check the mirco-switches behind the panel at the dispenser section. basically, when you depress the lever for water or ice, those levers make contact with a switch, and the switch turns on the ice dispenser motor. if the lever is pushed too hard, the switch can be knocked out of position. I had to re-position my ice switch with some duct tape.
Feb 16, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Ice dispenser only dispenses crushed ice
Check and make sure your switch is okay. Some have a switch that controls whether you want crushed or cubes. If it is defective replace it.
Oct 23, 2007 | Hotpoint HSS25GFP Side by Side...
Refrigerators Logo
41 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
