Question about Fisher and Paykel 23 in. DD-603SS Built-in Dishwasher
We have the double dish drawers....the lower dishwasher begins its cycle and then suddenly starts beeping with the red lights flashing....also the water is not draining. can you tell us what's going on?
  • Fisher and P... Master
  • 3,247 Answers
It is important to find out which light is flashing - if you have an LCD display then is there any character like Fxx or Uxx on it.
Which LEDs on the drawer door lid top are on. If water is not draining then it is linked to the rotor pump or drain sump being blocked.
Posted on Nov 13, 2010
My double drawer kitchenaid dishwasher sold red light and beeping during cycle wont turn off and runs even with door open, turned breaker off
If you using upper or lower drawer and this shows up it means the dishwasher has water under the filter board which located on the bottom under the lower drawer. You have to disconnected power,removed the lower drawer, clean the water, replaced filter board, check the dishwasher for leaking.
Nov 26, 2017 | KitchenAid Dishwashers
F1 error on Fisher and Paykel Dish Drawer
Sorry did not see your problem report earlier. If you have checked the sensor under the bottom drawer and it is dry, then F1 is caused by top drawer power filter fault. This means the bottom drawer controller is giving the F1 error but the top drawer controller has no power. Can you confirm this.
Apr 08, 2013 | Fisher and Paykel 23 in. DD-603SS Built-in...
My single Fisher & Paykel dishwasher drawer DS603I (Integrated Panel) turns on by itself even after turning off the light switch that controls both units that sit on opposite sides of the sink. The...
Yes ,you may be able to restore function by completely drying the area and PC board located under drawer.Use a hair dryer.
However , you will still have a leak and the problem will return.Usually the leak is drawer lid not closing properly. Suspect lid actuators have failed.Very common.Or some kind of obstruction.The drawer can be removed easily by removing 2 large plastic scews at drawer front.If lid actuators have never been replaced go ahead and do that.It is normal for other drawer to work fine.
Hope this helps you
Aug 16, 2011 | Fisher and Paykel 23 in. DD-603 Built-in...
Had the double drawers for 3 years now and all of a sudden, the top drawer is having problems. A few minutes after I start a load, the blue light on the front starts blinking red, it beeps, and when I...
First thing to do is to take a clean damp cloth and lightly wipe the grime off the drawer lid especially on top of the membrane keys.
Wonder how often it has gone into this blinking red state.
Jan 10, 2011 | Fisher and Paykel 24 in. DS603MFC Built-in...
I have a Danby DDW1899WP portable dishwasher. I just got it yesterday. I had a lot of dirty dishes so I did 1 cycle first and it worked perfectly, I was impressed. I then started a 2nd cycle for the rest...
I realize the above question is almost 4 years old, but I am sure others are still having this problem. My Danby was behaving the same way: drying cycle light would flash like it was having a myocardial infarction, and the cycle would stop. I could only get the light to stop flashing by turning the unit off. What you didn\'t say above is what happens then: everything most likely returns to normal-- or at least, so it seems. I have now had this happen to me two times in a row with my Danby 1899WP. Each time the machine has started up just fine, drains water out, loads in fresh water, and begins the wash cycle, only to freeze up with that damn flashing red light on the dry cycle and the dishes not clean. I have owned it for about two months, and so far this is my only complaint. I am running it again right now, for the third time, and we shall see what that light does now.... Will report back afterward!
Nov 14, 2010 | Danby DDW1899WP Portable Dishwasher
I have a dish drawer DD603 purchased in 2005. It
I presume you have a double drawer model.
Does this problem occur with both drawers?
Jan 18, 2010 | Fisher and Paykel 23 in. DD-603 Built-in...
My dishwasher is showing signs of a spanner
I am slightly unsure if your double drawer dishwasher is the prefinished model (self standing with LCD display) or the integrated model with no LCD display.
The spanner symbol on the top drawer is telling you that a fault code is actuated. But I am not sure where this symbol is on your unit if it is built -in (integrated model).
You will have to check which red light (from the left) is coming on.
I assume there are 5 lights on the inside of drawer.
With the bottom drawer - again you will have to check which light from the left comes on sometimes as you mentioned.
If you have a user manual you should be able to tell what Fault code it is - something like F1 or F2 etc. Is it continuously beeping when the red light is on? How do you turn the beeps off?
The scrubbing bush symbol on bottom drawer may not be a problem. It appears the drawer is programmed to a particular option. But I am not sure where this symbol is showing if you do not have an LCD display panel. You can reset the option - possibly auto lock or auto power or dish cleaned (depending on your model) if you follow the user manual.
happy to take you through a possible cause of the problem if you post answers to my questions above.
Jan 18, 2010 | Fisher and Paykel 23 in. DD-603SS Built-in...
Fisher Paykel F1 error / double dishwasher drawer
F1-water on bottom of dishwasher. Uselly it cost by broken drain hose. Need expert tech to fix the problem.
Dec 01, 2008 | Fisher and Paykel 23 in. DD-603SS Built-in...
Fisher Paykel double drawer dishwasher DS6031
you have an overflow leak problem....shut off circuit breaker or pull fuse....let it dry out for up to 4 days; hopefully overnight; peak under dryer and feel metal drip pan and if wet you might be able to dry with a hair dryer...WHY? the lid did not seal when you put cycle on...the lid lowers and you had something..typically too bid glasses on second shelf that was above the seal lip of the tub...stack correctly after this and no worries...
Sep 21, 2008 | Fisher and Paykel 23 in. DD-603 Built-in...
F&P dish drawers model DD6031
It may be that the DW thinks the drawer may have been pulled open. On the right side, near the top. there are two light pipes on the drawer. One sends an infrared beam of light to a reflective area on the cabinet, the other receives this light. This is how the drawer senses whether the drawer is open or closed. Wipe these areas with a clean dry cloth.
Apr 23, 2008 | Fisher and Paykel 24 in. DD603H W Built-in...
Fisher and Paykel 23 in. DD-603SS Built-in Dishwasher Logo
144 people viewed this question
Top Fisher and Paykel Dishwashers Experts
Brian Coughlan
Owen Barnes
Are you a Fisher and Paykel Dishwasher Expert? Answer questions, earn points and help others
