Question about Baumatic 34 in. B17.5 Gas Cooktop
I have a baumatic gas cooktop BACG7002-C 70cm 5 Burner and it is set for natural gas and Im on bottle gas. How do I adjust the the jets so that they burn correctly?
You can adjust with small vessels keeper stand .
Posted on Nov 12, 2010
How do I adjust the flame on a MGC5430 gas cooktop? Flames are too yellow and cause black soot on bottom of pans. Doesn't seem to have an air shutter adjustment
Is this unit set up for natural gas or propane? New stoves usually come with ORIFACES for both gasses. They would install between the on/off knob and the burner tube under the stove top. They may be tapped to the under burner area of your stove. If you lift your top stove cover you may find them. If you don't find them, you may need to purchase the correct applications for your stove. GOOD LUCK FRIEND.
Nov 28, 2014 | Maytag MGC5430 Gas Cooktop
Just put in a new Caldera LPGas cooktop the flame is yellow and putting soot on pots how can I adjust air to correct this?
you stove may have jets for natural gas rather than bottled gas the calorific value of natural gas is different to propane and the jets are larger because of this. if using bottled gas then you will get yellow flame and soot because there is too much gas to burn properly check your installation manual for procedure to change the jets for each gas
Dec 19, 2010 | Stainless Caldera SSK-305 Steel Gas...
I have a bosch cooktop 5 burner and one burner lites its very dim and then goes out
Is this cooktop new? Was it converted to propane or do you use natural gas? If it was converted, I was just thinking they put in the wrong size orifice. If it has been working fine and is just now giving you problems, then check the burner holes and see if they are partially plugged from food spills.
May 18, 2010 | Bosch 30 in. NGP 732 / 736 Gas Cooktop
Soot deposits from my brand new downdraft jenn-air gas cooktop
Is this on LP or Natural gas? If LP was it converted to LP? In any event,The air shutter must be adjusted on the gas burner tube. You need more air. The valve orifice may also need adjusting.
Sep 28, 2009 | Jenn-Air JGD8345 Gas Cooktop
I want to switch my 5 burner kleenmaid CH80x8 natural gas cooking top over to LPG what size jets or injectors do I need. Regards James. Centre burner is for a wok current jets are 50. 78. 85. 62. 95
LPG to natural, natural is bigger than LPG injector exmaple LPG 50=natural 69-
LPG 78=natural 91
LPG 85=natural 115
LPG95=natural 130
PLG 62=natural 85
Sep 09, 2009 | Cooktops
Need to convert a Thermador cooktop from Natural to LP
http://www.repairclinic.com/SmartSearch/SSPartDetail.aspx?PartID=1048620&PPStack=1
try this link.
do not drill out the jets they will not work properly.
I would check all your documentation you may have the convention kit with your owners manual or it may be attached to the oven.
Nov 15, 2008 | Jenn-Air JED8430 Electric Cooktop
Gaggenau 5 burner gas cooktop, natural gas
make sure unit is set up for the fuel you are running (lp/nat)
make sure connections are correct and valve is 100% open no blockages anywhere if all good call for wty service you don't want to void wty on a new unit
May 15, 2008 | Cooktops
Kenmore 32099 Cooktop burners regulation
remove the burners and adjust the air ration with the slide at the bottom of the burner tube
Jul 25, 2007 | Kenmore 30 in.32099 / 32094 / 32092 Gas...
AEG 5 burner gas hob
there is a bypass screw on each gas valve. adjust so flame is reasonable when each burner is turned to low
Jun 15, 2007 | AEG 34942G-M Gas Cooktop
Baumatic 34 in. B17.5 Gas Cooktop Logo
263 people viewed this question
Top Baumatic Cooktops Experts
Paul Carew
Are you a Baumatic Cooktop Expert? Answer questions, earn points and help others
