I have not gone beyond alignment stage on my hp officejet 7110 printer. I get a message initializing, then "press enter to align printheads". This is followed by "starting task, preparing the device, please wait....now printing alignment page". At this point the following leds start blinking: auto answer on/off, hook phone, needs attention, 2 sided copy, all 3 quality leds, and the power on light, while the message turn power off and on is displayed. When I do that it goes into the initializing stage and a blank page comes out. The message press enter to align printheads is displayed again so I cant proceed. Can you help? John
Khalsa007
  • 79 Answers
SOURCE: can not print color on hp officejet 7110
it might be a hardware issue with the printer however we still can try the following stes to reset the printer.
Take out the cartridges from the unit .
Make sure the unit is connected to the wall jack directly without any surge protector.
Unplug the power cord from the back of the unit ( without turning off the unit ) .
Now press the # and 6 key together , while holding these keys down plug in the power cord back into the unit .
5
Do not release the keys after a few seconds u will find te hp logo or bars moving across the screen .wait while the unit turns off.
6
after one minute turn on the prnter . it will go into alligment phase > let it finish .
7
after its done > try to make a copy
Thanks
Posted on May 27, 2008
SOURCE: hp printer won't copy
1. turn off / on the printer
2. press setup hold down and press options
3. press start color copy
worked for me on psc 2175
Sue
Posted on Jun 01, 2008
  • 53 Answers
SOURCE: I keep getting an error (81:01)
The problem refers to basically a paper jam. I thing your problem could however be the carrage movment. There is a special oil required for the carrage, but failid this use a very thin oil such as sewing machine oil. The trick is to not use too much oil, only a drop or two over the entire length of the carrage. Also needs to be oiled is UNDER the rail towards the back. Look carefully at the back of the carrage where it has the back slider. This rail needs to be clean and lubricated. Probable easier to clean and lubricate if you remove the encoder strip.
Regards
Dave
Posted on Feb 18, 2009
POCBM
  • 121 Answers
SOURCE: hp officejet 6110
If machine does not print the colors it cannot align. Try changing the color and try again
Posted on Apr 03, 2009
Riztech
  • 731 Answers
SOURCE: My HP Officejet 5610 All
I would like to know below results
  • Please check if you are able to make photo copies in printer.
  • Does the print from computer works?
  • Please check if you are able scan from the computer (if copy works).
Regards
Riztech
Posted on Dec 05, 2010
"Press enter to align cartridges" keeps appearing
Perform the following steps to align the ink cartridges:
  1. Disconnect the power cord from the unit, wait five seconds, and then plug it back in. This will reinitialize the unit.
  2. Print another alignment test page. If the Press Enter to align message is not currently on the front panel display, complete the following steps to print an alignment page:
    1. Press Setup or Menu on the front panel (depending on the model).
    2. Press the right arrow button (>) until Maintenance or Tools is displayed, and then press Enter or OK (depending on the model).
    3. Press the right arrow button (>) until Align Print Cartridges is displayed, and then press Enter or OK (depending on the model).
  3. Read this HP link:
    http://h10025.www1.hp.com/ewfrf/wc/document?docname=buu00657&cc=us&lc=en&dlc=en&product=79477&tmp_track_link=ot_search
    Click on this link or copy and paste the complete link into your browser.
    If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response. Happy Holidays!
    Thanks, Joe
Dec 23, 2010 | HP OfficeJet 6110 All-In-One InkJet...
My printer is flashing "press Enter to align
Hi
your cartridges are empty or clogged
try cleaning cartridges from printers menu
if nothing happen try replacing them with new ones
or refill them by this succesfull and easy way
If i help you pls vote me
Oct 31, 2010 | HP OfficeJet 6110 All-In-One InkJet...
Hp 6110 Printer, add wider paper size. Also align cartridge keeps appearing even after I've pressed enter and the process keeps repeating.
Press the enter key and hold it while you press the menu button. That will make the align message go away, but if just one color is missing it will always fail the alignment. The paper size is chosen in control panel and printer properties, printing preferences.
Feb 22, 2010 | HP OfficeJet 6110 All-In-One InkJet...
HP 7140xi comes up with alignment failed after replacing black pr
you could try by passing the alignment
Press and hold Setup and then press OK simultaneously when align message is prompted on the All-in-One.
Jan 27, 2010 | HP OfficeJet 7410 All-In-One InkJet...
We have put new color cartridges but the color is not good... & we can see the lines of the printer head (?) It just started doing this recently. It printed beautiful pictures before! It is a hp...
Many printers need the heads aligned once you install them. Some printers will do a high level alignment however to properly allign them you should use the tools section for your printer and click the align cartridge/heads selection. If you don't see the maintenance/tools tab when you open your printer from control panel, you may be using the generic Microsoft driver and need to install the drivers from the manufacture.
Sep 02, 2009 | HP OfficeJet 7110 All-In-One Thermal...
Hp officejet 6110
Apr 03, 2009 | HP OfficeJet 6110 All-In-One InkJet...
CANNOT ALIGN CARTRIDGES
Press and hold the Enter button, and then press Menue.
Also visit
http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&cc=us&docname=bpu00657#Bypass_Alignment
Jun 12, 2008 | HP OfficeJet 6110 All-In-One InkJet...
Align page message
I have an OfficeJet 5780 and I have to do the alignment also. The allignment page it prints should have instructions on it. Just put it in the scanner and press "Enter". It needs to scan it to align the print heads.
This is from the manual on their website:
The HP Officejet prompts you to align cartridges every time you install or
replace a print cartridge. Aligning the cartridges ensures high-quality output.
To align the print cartridges when prompted:
1 Press Enter on the front panel.
An align cartridges (test pattern) page prints.
2 Load the align cartridges page face down in the ADF between the paperwidth
guides and press the Enter button again.
3 Recycle or discard the page.
Geno
Feb 21, 2008 | HP Officejet 4110 All-In-One InkJet...
HP OfficeJet K60 Printer
you can bypass when asked and use last good settings by..Press and hold the Enter button, and then press Menu
This problem is caused by incorrect alignment page print out caused by faulty cartridges, ideal fix is replacement of all ink carts
HP have a webpage dedicated to this...h10025.www1.hp.com
Also get on your gloves get out your vac and suck on the carts till a little ink comes out, make sure colour cart releases all 3 colours then reinstall, can get messy.
Oct 19, 2007 | Office Equipment & Supplies
56 people viewed this question
k24674
jasbo
jasbo
