Question about Diamond Multimedia Diamond BVU195 HD USB Display Adapter (DVI and VGA with included DVI to VGA adapter) BVU195
Trying to install 2 Diamond usb display adapters (BVU195) and no matter what I try they are not being recognized. The power lights dont come on either. I downloaded the drivers several times but the adapters simply wont work. Can u help?
  • 1,472 Answers
Rjjm10
To better help me troubleshoot what is going on with your issue I need to clarify that you connecting 2 actual units to one computer.
Also let me know the make and model of computer you have and the version of Windows you are running.
Issken
http://www.fixya.com/users/issken
Posted on Nov 12, 2010
Wifi modem is not recognized
Try recycling the wireless router by unplugging the power to it and wait 20 seconds then plug the router back in. Sometimes that is all it takes.
After recycling the router if the adapter still does not show any wireless networks make sure you don't have the wireless radio turned off in the software that runs the adapter.
If all fails, try the adapter in another usb port if it is a usb adapter.
You could reinstall the adapter's software and driver.
May 06, 2012 | AcerPower 2000-UD431C - Core 2 Duo E4300...
Modem(moto sb5101) stays online. all lights are solid but i get no internet. does not matter if i am going through my router or directly from modem to computer. 4 different computers(2 windows/2 macs)...
You might try uninstalling & reinstalling your network adapter. Then disconnect the power supply to your modem, reboot your computer, then reconnect the modem power supply, reboot again. The system should then recognize the adapter and restore your ability to access the internet.
Nov 02, 2017 | Computers & Internet
I have a new macbook pro and want to use a diamond bvumd3 to have 3 independent displays. my external monitors are both Dell 2310 with 1920 x 1080 capability. I have the bvumd3 connected into my macbook...
You would have to purchase separate BVUMD3 devices in order to get multiple extended monitors. Since each BVUMD3 has one DVI port with a USB hub, the DVI port is the only port available that allows video. Using a VGA splitter will not work with our device since each DVI port is allowed to carry only one video signal through to the monitor. You could purchase separate BVU195 devices if you do not need to use the USB hub on the BVUMD3.
Dec 27, 2010 | Diamond Multimedia Diamond BVUMD3 USB...
Wireless adpater not working with xbox 360
i would find out if the 360 can use any adapter i am under the impresion that you can only connect a xbox 360 antena to the console.My solution is connect your modem ethernet cable to the 360 and the adapter to the PC/laptop you will have a wied 360 and wiless PC/Laptop
May 26, 2010 | Microsoft Xbox 360 Console
My daughters Toshiba satellite l505d will not boot up correctly. It starts but then nothing happens. What do I need to do. Have already taken battery out and restarted. Any help would be helpful.
Try the following.
1. Remove battery and plug in the AC Adapter and check if it works
If yes - Battery is defective
If no - Motherboard Problem/AC adapter
2. Check the AC adapter LED indicator if its lighted or not(double check by a multitester)
If lighted - it works properly
if not - replace
3. Try to reinstall WINDOWS operating system by the use of the installer CD
4. Reformat your computer and install necessary drivers and applications
Thanks. Cheers!
Apr 15, 2010 | Toshiba Satellite L505-S5966 Notebook
My adaptor is not recognized in my USB ports I installed the router and it completes all of its connection checks. I am trying to install the adaptor on a remote computer (in the basement) and that...
Here's what you can do since this is a USB wireless adapter, first connect the USB adapter on a different USB port on the computer better if you connect it on the back USB port of the computer tower and check if the computer will recognize it and if its recognize you can already continue with the software installation , but if not you can restart first the computer and check if the adapter will be recognized if still not the next thing to do here just to know if the adapter is good or bad is to connect it on a different computer and just to check if it will be recognized once its connected to a USB port , because a device should be automatically will be recognized by a computer once you connect it so if its still not recognized by a different computer adapter is bad...
Dec 15, 2009 | Computers & Internet
Printer prints garbage, no matter what I print
I suppose you may have an uncleared printer memory. Right your printer icon and select Open from the shortcut menu. click on document menu and highlighting all the pending files select Cancel to get rid of them. You may have power down the printer to fasten the process. It will take a couple of minutes and sometimes the pc will have to restarted to complete the process. Make sure the all the files are deleted before sending to the printer ok. Also check your printer very well, it could be it has a reset button. if it does, power it on and depress the reset button and that will settle the matter. If it doesn't, then you will have go for confirmed USB cable and adapter. Good luck
Jun 03, 2009 | Office Equipment & Supplies
When MN-510 adapter makes connection, video drops out.
Try to uninstall and reinstall the video driver. Make sure you note down the make / model first! The lastest driver may fix this issue.
GB Plus -
Mar 21, 2009 | Microsoft MN-510 802.11b (L21-00002)...
Hp laserjet 1020 ( usb device not recognized )!?
I'm not sure, but I think I understand that you're connecting using a USB hub? If so, try connecting it directly to a USB port. Many times an unpowered USB hub does not supply enough power to run a laser printer. Unhook the printer. Go to Printers and Faxes - delete the printer. Hook up directly to a USB port. Let the computer re-install the printer. Let me know Ed
May 05, 2007 | HP LaserJet 1020 Printer
Diamond Multimedia Diamond BVU195 HD USB Display Adapter (DVI and VGA with included DVI to VGA adapter) BVU195 Logo
291 people viewed this question
Top Diamond Multimedia Televison & Video Experts
Hipolito Jimenez
Hipolito Jimenez
Level 1 Expert
A Vlad Fuica
Level 1 Expert
Are you a Diamond Multimedia Televison and Video Expert? Answer questions, earn points and help others
