Question about Amana 22.6 cu. ft. Side-By-Side Refrigerator with FrontFill Ice and Water
I HAVE THIS REFRIGERATOR AND I AM WONDERING SHOUD BUY A NEW ONE SINCE IT HAS STOPPED WORKING. THE MOTOR IS RUNNING BUT NOTHING GETS COLD. COULD IT BE THE FREON? IT IS ALSO LEAKING WATER FROM THE FREEZER SIDE BOTTOM DOOR.
  • 34 Answers
You should call a refrigerator mechanic to solve the problem. It needs to refill the gas.
Posted on Nov 12, 2010
Our Whirlpool refrigerator model ED5SHAXMB10 is keeping our freezer food cold, yet no cold air is being blown into the refrigerator. Refrigerator is getting very warm. What can be done to fix it?
The defrost is not taking place on time or the defrost ventilation door is stuck closed.Its controlled by motor,that motor is got faulty.
Replacement parts can be purchased at any of the following web sites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
partsselect.com
Before going to buy any parts directly.
Go through this troubleshooting help links.
This is list of refrigerator problems, which is normally faced in refrigerator.
You can go through the details, by clicking the link below:---
Refrigerator is not cooling properly?
http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html
Both refrigerator and freezer not cooling properly in refrigerator?
http://technoanswers.blogspot.com/2011/06/both-refrigerator-and-freezer-not.html
The ice maker not working: ---
http://technoanswers.blogspot.com/2011/06/ice-maker-stopped-working.html
Compressor not running on refrigerator?
http://technoanswers.blogspot.com/2011/10/compressor-not-running-on-refrigerator.html
Water dispenser not working on refrigerator?
http://technoanswers.blogspot.com/2011/10/water-dispenser-not-working-on_19.html
Ice maker stopped making ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-stopped-making-ice.html
Water Overflows in Ice maker and freezes inside?
http://alltypesofpartsreplacing.blogspot.com/2011/10/water-overflows-in-ice-maker-and.html
How to replace Ice maker assembly?
http://alltypesofpartsreplacing.blogspot.com/2011/10/how-to-replace-ice-maker-assembly.html
These will help.
Thanks,.
Dec 23, 2012 | Refrigerators
Heater fan quit working. What would cause this?
You need a new blower motor resistor. shoud be under the dashboard on the passenger side around or behind the glovebox and should plug directly into the blower motor. Go to the parts store and buy one. Nothing else will look anything like it. so when you see it you will know what to replace.
Jul 28, 2012 | 2002 Dodge Grand Caravan
MY FRIGE STOPPED WORKING
HI.THIS needs elaboration.on a general note i am assuming its running but not getting cold.1-check con/unit and should hotish.lack of refrigerant if it is cold and motor running.2-cond/uni cold and motor v/hot and not runnig.suspect motor.con/unit cold motor cold.suspect thermostat the motor.good luck hope it helps.Ali
Jun 18, 2012 | Haier Refrigerators
My uline refrigerator won't get cold at all. Was
If the refrigeration motor is running and it is not getting cold then it probably is low on freon the gas that is used for refrigeration. Also if the motor only runs for a few minutes then stops it is possible that the cold control is bad, This is a common problem in refrigerators and can be fixed by replacing the control. First you must determine that the motor is in fact running. If the motor is running the motor should feel warm to the touch after 10 to 20 minutes of operation, and you should feel some cooling in the refrigerator on the cooling or evaporator coil. If the motor is running and getting warm or hot and you feel no or very little cooling then it is in fact ether low on freon or a component in the refrigeration system is malfunctioning. Freon can only be replaced by a certified technician.
Oct 07, 2009 | U-Line ?chelon 2175RB-00
The freezer works but frig side isn't getting cold
sounds like fan motor between freezer and frig is bad,, you shoud hear it run when you open and close the door if this helps you in anyway be sure to rate me
thanks sawdust46
Jul 10, 2009 | GE Refrigerators
Freezer quit freezing
HI,
you can try this suggestion first.
if the compressor is running your ref. should be getting cold. Their is a defrost timer but when it is in defrost the compressor shuts off. I think you do have a leak.
any further question let me know.
thanks,
Mar 22, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Ice maker stopped working, plus fridge not cold, but freezer o.k.
I would check that fan motor in the freezer section is running. it distributes cold air from freezer into refrig section also if this motor is running the top portion of freezer will not get cold enough to allow ice production. the motor is easy to repl and is mod# specific you should be able to buy one online.
Jan 21, 2009 | Kenmore 64802 Top Freezer Refrigerator
Noise from top inside near temp control nob
There is a fan close to where the cold air comes in,Its running dry and thats the noise you here.
oiling the fan motor can help other wize you shoud replace the fan...
Good luck.
Sep 09, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Fridge not getting cold enough
listen for the compressor running in the back at the bottom. when you hear that running, open the freezer section. do you hear a fan blowing inside the freezer? if not, the evaporator fan motor is jammed with ice build-up or it's bad. hope this helps.
Nov 01, 2007 | KitchenAid Superba Architect KSCS25INSS...
Amana 22.6 cu. ft. Side-By-Side Refrigerator with FrontFill Ice and Water Logo
49 people viewed this question
Top Amana Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
