Question about VAX Appliances Vacuums
My pet vax 6140 does not pump the water from the reservoir to the end of the hose i have changed the pump but still no joy any ideas possible faulty pump?
4 Suggested Answers
  • 5 Answers
SOURCE: vax 2400 perfomance pet overheating??
take it in to get looked at! it could be a elec. short which might cause an accident(ie. fire, shocking, explode....)
Posted on Feb 19, 2009
ukvacfan
  • 328 Answers
SOURCE: VAX HOOVER PROBLEM?
The 121 should only have the main filter ring taken out before the reservoir tank is put in which easily just falls into the main dust tank area. Make sure though that the bin's square edge is at the front where it rests at the front of the Vax where the hose comes out. Then unhook the pump to lay it in the water tank and the motor should be able to jam ontop clipping both sides down to lock. Perhaps you are putting the reservoir bucket in the wrong way.
Posted on Mar 07, 2009
SOURCE: vax 2400 performance pet overheating
Unfortunately there is no permanent solution.It is a terrible vacuum cleaner and im getting rid of mine today. I have been maintaining it for 6 months cleaning filters , swapping filters, swapping carbon brushes all to no avail.Dump it. it would'nt **** the air out of a balloon.
Posted on May 02, 2011
My vax pet Hoover has lost its suction I've emptied it there's no blockages and Iv cleaned the filter
first, if it has a hose check for being plugged, you may have to take the vacuum apart further till you reach the fan on motor which may have hair,lint,etc wrapped around it which can cause low suction.
Checking for Blockages in Your Vax Upright Vacuum Cleaner
press helpful button
Jan 09, 2016 | Hoover Vacuums
Loss of suction on my Vax Air Pet 3. All filters and hose clear and belt spinning. Ideas/help appreciated - thanks!!
Sounds like a clog in the plastic that the hoses are connected to. Take bottom off so you can get in with a wire with a small hook and run all the way to the bag you might have to work from the bag opening down too. You should find a big wad hiding some ware in the housing this is an all to common problem with most brands of this type of vacuum.
Jul 21, 2014 | VAX Appliances Vacuums
Vax rapide
I brought a rapide ultra carpet washer today , cleaned half of my front room brilliant then stopped spraying water using the trigger on the handle, as the handle comes off for easy storage I took it off, and what\'s happing is when you pull the trigger to release water a piece of plastic pushes on another piece ov plastic to release water and it was not working only by me pushing my finger on the other piece of plastic in side the handle bit, so mines going back ,
Aug 14, 2013 | Vacuums
My VAX Vacuum has lost ALL suction power. I've
vax power pet 1 filter keeps getting clogged up so dirt not going into cylinder
Jul 05, 2009 | VAX Appliances Vax X5 Bagless Upright...
How do you use vax 2000 to shampoo carpets. do not have a manual
Set up is complicated unless you are patient.
Remove the paper dust bag from the bottom of the canister and then filter ring. Then put in the recovery bucket of which 4 litres of warm water should be added and a capful of floor cleaning solution.
Then remove the pump wire on top of the Vax motor where the blue filter circle is (keep the filter in, do not remove it!).
If the 2000 has a separate pump notch on the rim of the Vax motor head on the outside then you should plug the black cord in that has a washer screw type metal connector. Push, twist and lock in. Then the black cord which eventually leads to a clear pipe with the older clip on wash handle that has to be clipped to the main hose handle has to have the black and see through cord clipped to the main hose and eventually down the extension pipes until you get to the floor head. If you have the older style T shaped floor head the cord should slip into the floor head easily. Then either squeezing the trigger to release the cleaning solution in, switch the Vax on and hit the secondary pump button. This will pump the cleaning solution and water into the carpet. To stop the pump you can either lock the wash trigger to stop the liquid or squeeze the trigger to make sure no other liquid comes out. Generally you can see the foamy carpet solution flowing through the see through rubber hose and eventuallly through the floor head.
To **** up the rest of the carpet solution, stop the pump button and the Vax can be used to **** out all the dirty solution/water in the carpet. Its a big and tedious task generally!
See an alternative manual for the Vax 1000 which is an older model but similar to the 2000. It is free and in pdf downloadable form:
http://www.vax.co.uk/downloads/pdf/VaxGuideNo8a.pdf
Jun 15, 2009 | VAX Appliances 2000 Canister Vacuum
VAX HOOVER PROBLEM?
Jan 12, 2009 | Vacuums
Vacuums Logo
141 people viewed this question
Top VAX Appliances Vacuums Experts
seanwalters1
Level 1 Expert
Tom Chichester
Are you a VAX Appliances Vacuum Expert? Answer questions, earn points and help others
