Question about Protron PLTV-32 Television
TV lost its power. will not turn on. Tested power cord and its fine.Plugged into another outlet and still will not turn on.
  • Protron Master
  • 8,457 Answers
The tv power supply board is dead.That the board,where the power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Posted on Nov 12, 2010
My set is plugged into a cable box. the tv will not turn on either manually or with the remote.
Plug the power cord directly into a wall power outlet, and make sure that the standby light is lit (turn it on/off manually to see if anything changes). If there isn't any light, then it's most likely broken.
If the TV works again, being plugged into the power outlet in the wall, then the problem is with the cable box (i bet you figured that out too).
Jul 06, 2014 | Envision L32W761 32 in. LCD TV
SANYO Model CLT2054 Television
sounds a lot like you lost the video driver or control board functionality. From the 'decay' of your image, with sound still working, and all else being good, you're primed for a new video controller. Are you inclined to do the repair yourself? The service manuals are hard to get online, but the local service center MIGHT sell you one.
Feb 16, 2008 | Sanyo CLT2054 20 in. EDTV-Ready LCD...
Tv come with no sound or pict.
Check whether the product is turned on.
Try another channel. The problem may be with the broadcast.
Is the power cord inserted into wall power outlet?
Check your antenna direction and/or location.
Test the wall power outlet, plug another product's power cord into the outlet where the product's power cord was plugged in.
If these tips don't work, you can also try to power cycle the TV. Turn the TV off and unplug it for about a minute. Plug it back in and power it back on to reset the settings back to factory default.
Oct 18, 2013 | LG 32LG30 32 in. LCD HDTV
Whirlpool refrigerator trips gfci outlet
Yes ,, if the fridge outlet is behind the fridge and therefore not accessible for use by counter top appliances .. then yes change it to a regular outlet.
The cause is probably the compressor, getting a bit noisy..electrical noise I mean.
Feb 23, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Had the digital cable box installed yesterday. The tv worked
The cable box has an AC outlet on the back of it and sometimes the installer plugs the TV power cord into it. This outlet has two modes--IE: on all the time or switched. If the outlet happens to be programmed to the switched mode, the cable box has to be on before you can turn on the TV. If the outlet is on all the time, then you can turn the TV on at will. So, you have to decide if the TV is plugged in there or it is plugged into the wall recptacle. If none of this explanation fits, then we need more information.
Jan 07, 2009 | Hitachi 46UX24B/25K 46" Rear Projection...
TV won't turn back on after power cord was disconnected from unit
If power cord was jerked out of the outlet or set, make sure it wasn't damaged. If it was unplugged violently, the circuit board inside the set could be damaged. Also make sure the outlet that it is plugged into is not damaged or a switched outlet.
Aug 03, 2008 | Fujitsu Plasmavision 42" TV
Lost power cord
Should be OK as long as it's capable of carrying the wattage the system is pulling. The TH-42PX60U is rated at 320 watts max - you should be OK as most computer cables are rated well above that. However if you're worried, us the power cord from a laser printer or copy machine - it will definately carry the load.
May 12, 2008 | Panasonic TH-42PX60U Television
Motor won't turn on
Hi , Try to check with multi tester the power cord ,test the two tips of male outlet switch on tested read the continuity /if not reading ,pulout if push type /if permanent open cover below test the test the cord inside to the male plug if does not response cord is problem,check also fuse test both end of fuse not reading fuse buste then replace thats all goodluck.
Nov 12, 2007 | KitchenAid KSB5 Professional Stainless...
Protron PLTV-32 Television Logo
78 people viewed this question
Top Protron Televison & Video Experts
Jaime Hernandez
Are you a Protron Televison and Video Expert? Answer questions, earn points and help others
