Question about HP P2035N LaserJet Monochrome Printer
How can I print checks face up with a hp 2035n printer
  • 2,427 Answers
Set the printer to envelope via the printer setup..
set the paper type to evelope
set the envelope size to custom and select or enter the dimensions of the cheque
load the checks face down as you would your envelopes
(load in tray, Close in latchs to hold in place) or use the rear feed tray.) if you have one
Be sure to check portrat and landcsape settings..
Use some test paper with lines drawn on in the same place as your check (cheques) to determine everything is set up propperly so we dont risk spoiling any checks..
Posted on Nov 12, 2010
What is the toner yield in HP Laserjet 2035 & 2035N???
Toner Cartridge for HP P2035/P2035N (CE505A) = 2300 pages to 5% coverage.
Aug 23, 2011 | HP P2035N LaserJet Monochrome Printer
Should print paper face up or down on hp office jet 7310?
Load the originals face-up in the ADF with the short edge of the page to the left.
Jun 17, 2011 | HP OfficeJet 7310 All-In-One InkJet...
My HP 2035n printer makes a horrible, long beep noise whenever someone prints. Other than the noise the printer works perfectly, no errors come up, and nothing lights up or flashes indicating something is...
I've searched and can't find anyone else with this problem either, I know it isn't an instant solution but your best bet would be contacting their customer support.
http://www.hp.com/cgi-bin/hpsupport/index.pl
May 05, 2011 | Office Equipment & Supplies
After moving to a new house/ new state, I can not get my HP 2035n to connect wirelessly to the router. It will print from any of our computers, but must stay connected to the router. I can find no...
The HP P2035N doesn't have a built-in wireless ethernet connection. It has a wired ethernet port. To connect to a wireless router, you need the HP Jetdirect ew2400 802.11g Wireless Print Server or the HP Wireless Printing Upgrade Kit or a similar device (note: not all third-party wireless print servers will work with the HP printer). Did you have something like this and misplace it during your move? If you did, try to find the print server to use the wireless option. Otherwise, continue wired ethernet option since it is working.
HP support for the printer (manuals, set up infomation, and drivers) is available here: http://h20000.www2.hp.com/bizsupport/TechSupport/Home.jsp?lang=en&cc=us&prodTypeId=18972&prodSeriesId=3662025&lang=en&cc=us .
I hope this helps.
(HP models with a W at the end of the model number have wireless capabilities without any additional hardware.)
Apr 30, 2011 | HP P2035N LaserJet Monochrome Printer
What does ! in a circle mean on an HP 2035n printer
The printer cartridge door is open. Attention
The print-cartridge door is open. Close the print-cartridge door Attention
Jan 28, 2011 | HP P2035N LaserJet Monochrome Printer
My new hp 2035n printer give an error when i try to print. the error says: load paper to tray 1
Instructions Things You'll Need:
  • Inkjet printer
  • Labels
  1. 1
    Prepare your printer. Make sure the power is on and the drivers are installed correctly on your computer.
  2. 2
    Wait for printer to stop. Make sure your printer is idle or ready or waiting for paper to be loaded. Don't load labels when your printer is already printing or running an operation.
  3. 3
    Prepare your labels. Make sure they are all facing the same way and are right side up. The label side should be face up. Many labels have an up and a down as well, look for a "this side up" or "load this way" indicator. Or take a look at the print preview before you print and make sure your labels will be fed correctly.
  4. 4
    Find the correct paper tray. Some printers have manual feeds and automatic feeds. Refer to your manual to find out which one you should use for labels. If you are going to use the manual feed, follow the manual's instructions. However, most printers will use the automatic feed, so read on.
  5. 5
    Align the paper guide. This is a moveable piece on the paper tray. There should be markers for the width of your paper. Standard pages are 8.5 inches. Move the marker so your labels will fit.
  6. 6
    Load your labels. Place your labels in the tray so it touches the immoveable side of the paper guide. Slide the paper guide over to touch the other side if it is not already close. Do not bend the labels by pushing in too far.
  7. 7
    Find the paper thickness lever. Try looking under the door that lets you change the cartridges. Or search around on the back or side. Check your manual, too.
  8. 8
    Set your paper thickness level. Usually you'll use the standard size. However, your printer may need to use a thicker setting. Check your manual.
  9. 9
    Change your media type. In your printer settings, find the media type option. You can access settings by clicking properties or settings on the print dialog right before you print. Select "labels."
Oct 02, 2010 | HP P2035N LaserJet Monochrome Printer
HP P2035N LaserJet Monochrome Printer Logo
352 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
