Question about Canon CLC 1150 Color Copier
Canon CLC 1150 E020 01EO and E020 04EO that will not clear...all developer assemblies were cleaned and adjusted ...stirred and iniated
Tonerman
  • 62 Answers
SOURCE: clc 1150 error 350
Normally only the canon service center will tel you what the error codes means. Suggest you call them .
Posted on May 21, 2007
  • 4 Answers
SOURCE: E072 - 0002
most of the time if you replace the transport cleaning unit it fixes the fault. on one machine i had a break in the wire lume that caused the problem. also make sure you don't have a piece of paper jammed in the unit.
Posted on May 07, 2008
  • 47 Answers
SOURCE: Booting problems with Canon CLC 1150 Copier
The copier itself doesnt have a hard drive. Since you are talking about Fiery I assume you mean the colorpass RIP attached to the copier. A CD with the software on it actually came with the RIP but it was probably swiped by the dealer. In any case it needs a SCSI CDROM in order to load it. But all is not lost. The hard drive actually keeps a backup of the software on the hard drive itself. Kinda like a system restore partition on some computers. When you switch it on hold down the top right button until the diagnostics pass. then press "restore backup". this will take quite some time. Once it is done you will have to go back into setup mode and re-enter all the network settings. Dont forget the default paper size.
  • 1602 Answers
SOURCE: E020,0173 error for a clc 1150
call in a service technicail for that type of copier and you mayspend lots of time and money trying to fix every little thing i ell you
rod
Posted on Feb 03, 2009
  • 1602 Answers
SOURCE: canon clc 900 Error E020
go on line type in
canon printer error e020 and look at all the ideas to help you fix your problems
rod
Does the Canon CLC 1150 have an internal hard drive? If so, how do you clear it?
No. CLC 1150 Do not Have Any internal Hard drive, So there is no question arises to clear it
Sep 27, 2011 | Canon CLC 1150 Color Copier
IAM GETTING A CODE ON CANON CLC 1150 EO20 &E0181
This is an error for the Drum units. The E020 is for toner concentration, the " 01 " is for Magenta and the " 81 " is for the concentration in the developer unit for the window sampling is below 70. Best thing to do is replace the Magenta Starter and do an initialization procedure in Service Mode. Better left to a Tech.
Jun 20, 2011 | Canon CLC 1150 Color Copier
CODE EO20400 COMES UP WHEN TRYING TO MAKE COPIES
toner clogging between sub hopper and developing assembly
May 20, 2010 | Canon CLC 1150 Color Copier
CLC 1150 Color Coiper E020 0142 What does this
Toner feed error, possibly clogged up in a feed tube, or in between hopper and developer.
Will most likely need a service technician to fix.
Dec 04, 2009 | Canon CLC 1150 Color Copier
I have an older Canon clc 900 Error E020 Switch power on and off again"displays when trying to copy. When I turn the copyer off and on again the same message displays.What to do ?
Error :
Intermittent E020 / E061 codes.
Workaround :
It's possible that there is a poor drum ground from the static eliminator brush. You may need to replace the static brush with the drum grounding leaf spring from a CLC 350 (part numberFA5-9308-000). Follow the procedure in technical publication CTP.NO 700/800-69.
Error :
E020 sub code 0440 and light density on all colors
Workaround :
Check the developer assembly movement, i.e. up & down and that the magnetic roller is turning. Check the EPC readings, laser output, fold back mirror, and the connectors for the developer and the developer bias contacts. If all the above checks are good, then the problem can be with the AC voltage output of the developer bias HVT. The DC-voltage for the developer bias is split between two colors ( magenta & yellow ) or ( cyan & black ). The AC voltage is supplied for all four colors and it's loss will be seen in all the colors whereas the loss of the DC voltage would affect only two colors. To fix the problem replace the developer bias HVT part # FG5-3068-060.
Oct 18, 2009 | Canon CLC 1150 Color Copier
Error code e020 04e0 came up
Enter in service mode FUNCTION > INSTALL > INIT_K
Jul 02, 2009 | Canon CLC 1150 Color Copier
Solution for error code e020004
The toner concentration sensor is faulty.
The developer inside the developing assembly is not stirred properly.
The sensor is subjected to stray light (no cover, front cover open).
The photosensitive drum has deteriorated.
Apr 23, 2009 | Canon CLC 1150 Color Copier
E005 0100 Error
asfter clearing the error code turn the machine off then on again, if that dosen work remove the web then clear cut off turn on
Nov 25, 2008 | Canon CLC 1150 Color Copier
Canon 1150 E020 04E0 Code error
change all 4 developers plus blow clean both developer sensors you can find these sensors next to the black developer assy it has one screw
Jul 23, 2008 | Canon CLC 1150 Color Copier
Canon clc 1150 copier
i have an erro paper jam in copier jam the code 0360 what i can do
Nov 12, 2007 | Canon CLC 1150 Color Copier
Canon CLC 1150 Color Copier Logo
old marine
old marine
