Question about HP P2035N LaserJet Monochrome Printer
Printing face-up with hp2035n printer - HP P2035N LaserJet Monochrome Printer
I just reinstalled my HP 3050 drivers and now it is printing face down instead of face up
I think that this is a driver setting issue. my guess would be to disable duplex printing. If I am not mistaken the HP 3050 is an OfficeJet not a LaserJet. you might get a better response if you were in the correct printer catigory.
Oct 21, 2014 | HP LaserJet 3050 All-In-One Printer
Zebra 105se printer is printing out of the label on the wright side
re donload software for it maby firmware update cheak settings in software ok
Feb 02, 2008 | Zebra Z6M Plus Thermal Label Printer
How to enter an IP address on a hp2035n
To install a HP printer (with built-in Jetdirect printserver) as a network printer you need to do the following -
1. Open the printer's menu and enablethe Network Card - these print servers use a static IP address therefore,configure the IP address of the network card so it matches the IP range of yournetwork. Eg. If your IP's are 192.168.0.*** then set the network card to a highnumber say 100. (This is to prevent a conflict with the router issuing the sameIP address to a computer on your network). Then set the Subnet Mask IP address to 255.255.255.0
Jul 17, 2012 | HP P2035N LaserJet Monochrome Printer
Orange faces
Under printer driver properties clean the print head.
Use only genuine ink crg.
Use only genuine photo paper.
Jul 02, 2010 | Canon Pixma iP6000D InkJet Photo Printer
HP officejet 9130 printer: pages keep printing
Yopu can change the rprinting order from the Print Dialogue box or Printer driver.
Look for the following to change page grouping when printed
and the followintg to change printing from first to last and last to first pages
Nov 13, 2009 | HP OfficeJet 9130 All-In-One Thermal...
IP address to connect HP2035N on the network
Here's a good tutorial that may help...
See this MS article, though you don't mention whether xp or vista....(see here for vista)
See here. and here for HP info.
For more info on TCP/IP see here and here.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Jul 30, 2009 | Office Equipment & Supplies
Printer wont print
it might be printer head problem. plz check it with a printer professional
Oct 28, 2008 | Canon MultiPASS C755 All-In-One InkJet...
Duplex printer
Check the driver you have installed on your computer, that's where the duplexing would be generated from. You should be able to choose through print properties at this point. Here's the link to Sharp:
http://www.sharpusa.com/products/business/copiers/business_copiers_drivers/
Sep 10, 2008 | Sharp AR-507 Copier
Printing
Dear jamin4volks;
As per this excerpt from the Oki B4350 User manual:
"FACE UP AND FACE DOWN PRINTING
For face down printing, make sure the rear paper exit tray is closed (the paper exits from the top of the printer). The paper exit bin on the top of the printer stacks printed pages face down, capacity 150 sheets of 20 lb. paper. Pages printed in reading order (page 1 first) will be sorted in reading order (last page on top, facing down).
For face up printing, make sure the face up rear paper exit tray is open and the paper guide is extended if required. In this condition, paper will exit via this path, regardless of driver settings. Paper is stacked in reverse order, capacity 50 sheets of 20 lb. paper.
Always use this tray and the manual feed tray for heavyweight stocks to reduce the possibility of paper jams."
This manual is available at http://my.okidata.com/mandown.nsf/(MOC-B4350)/BE70FCAF93D577E285256E89005052F9?OpenDocument
Hope this helps;
Frank
Apr 18, 2008 | OKI B4350 Laser Printer
HP P2035N LaserJet Monochrome Printer Logo
85 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
