Question about Williams 1403622 Gas Compact Heater
How do you light the pilot on this heater - Williams 1403622 Gas Compact Heater
  • 3,740 Answers
Hi and welcome to FixYa. I am Kelly. The instruction manual is here:
http://shopfnc.com/pdffiles/williams2man.pdf
Steps to light the pilot are on page 10. This unit as a pizo-electric igniter that is suposed to light the pilot. When you open up the cover to light the pilotfollowing the manual steps on page 10 check the contacts on the igniter. Sometimes they get stuck together. You can lightly sand them with 120 grit or higher sand paper if the contacts stick.
Thanks for choosing FixYa,
Kelly
Posted on Nov 12, 2010
Why can't I get the pilot lit for the water heater
Make sure your gas is not shut off.
Do you have any other gas appliances that are working?
Mar 02, 2016 | Water Water Heaters
Wher is pilot light
Why will my pilot light on the gas water heater not stay lit for ...
diy.stackexchange.com/questions/.../why-will-my-pilot-light-on-the-gas-...
Jul 28, 2011 - The pilot light went out on my gas water heater. I followed the ... This could be from a valve not being all the way open. It could also be from a ...
How To Relight Your Pilot Light On Your Water Heater ...
? 7:54
https://www.youtube.com/watch?v=gqM7kMkkFAI
Apr 15, 2013 - Uploaded by TipsNNTricks
How To Relight Your Pilot Light On Your Water Heater. TipsNNTricks .... I answer the following questions in this video. How can I relight my pilot ...
How to Light a Water Heater (with Pictures) - wikiHow
www.wikihow.com/Light-a-Water-Heater
wikiHowJump to Questions and Answers - If the pilot light doesn't relight or goes out immediately after ... if you are unable to light the water heater after several attempts.
Jan 13, 2016 | Water Heaters
Pilot light lights but goes out when I turn the main heater on / off switch
clean silver supply line to pilot generator sounds like cob webs not enough gas going to pilot make sure pilot generator is good also
Aug 24, 2013 | Jandy Lite 2 Natural Gas Pilot Light...
Do not know how to start pilot light
There should be instructions on the inside of the heater access door. Make sure you are comfortable working with gas heaters. Make sure the shutoff valve supplying gas to the heater is on. Turn the gas valve to "pilot", press and hold it while attempting to light the pilot. Once the pilot is lit, continue holding the gas valve knob down for about 30 seconds. The pilot should stay lit once you release the knob. If the pilot stay lit, turn the gas valve to "on". Replace the heater access door and make sure you have proper water flow and attempt to light the heater. If it will not light, or the pilot will not stay on, you will probably have to replace the pilot generator. It provides voltage to run the heater and after time it wears out and produces less and less voltage. A millivolt heater runs on less than one volt so any power loss can be a problem. If you are able, test the pilot generator with a multimeter to see if you are getting at least 500mv when the pilot is on. If not, you should replace the pilot generator or even the entire pilot assembly. Hope this helps...
Sep 27, 2009 | Pentair Minimax Ch 400,000 Btu Propane...
Can't re-light the pilot light
THIS HEATER DO NOT HAVE A PILOT YOU MUST HAVE A DIFFERENT MODEL. DO YOU GAS? TURN KNOB TO PILOT PRESS. LIGTH PILOT WAIT FOR 60 SEC AND RELEASE IF STAY ON TURN KNOB TO ON. IF TURN OFF PILOT MUST BE REPLACE
Jun 20, 2009 | Jandy Lite 2 Natural Gas Pilot Light...
Williams 3003622 Wall Mounted Panel Heater Draft Blows Pilot Out.
yes. open cover, set to pilot and push in then light with a long nosed butane lighter like the ones used for lighting stoves. Hold pilot in for a few minutes, then close pilot cover and turn pilot knob to on position. that should take care of it unless you need a new coupler. good luck as the couplers go out on these heaters prematurely.
Dec 25, 2008 | Williams 3003622 Ceramic Wall Mounted...
Vulcan freeloader hot water heater
Could be moisture in the gas supply line - get your gas fitter to purge the line at the meter.
Jul 08, 2008 | Heating & Cooling
Williams 1403622 Gas Compact Heater Logo
439 people viewed this question
Top Williams Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Mack Baxter
Are you a Williams Heating and Cooling Expert? Answer questions, earn points and help others
