Question about Panasonic PT-AE700U Multimedia Projector
How to rotate Panasonic multimedia projector PT-LB2 screen at 180
    Top Expert:
  • Panasonic Master
  • 26,730 Answers
Adjustment can be performed in the main menu.
Posted on Apr 15, 2017
dhiman
  • 115 Answers
SOURCE: Panasonic PT-AX100
Hello
Check the process of Power supply and the outputs. powerup the projector the replace the faulty gear assy or repair the same.
viren
Rave Services India
Posted on Feb 07, 2008
SOURCE: PT-LC50E LCD Projector
With power available at the projector and the lamp off (projector off) - hold the input button on and press the power button on and hold for 5 secs. This will reset the lamp timer to zero.
I wish they could have stuck this in the operators manual.
Posted on May 27, 2008
SOURCE: Panasonic projector PT-L78 lamp reset
Press the MENU button. Use the < > arrows to get to the OPTION menu. Press the ENTER button. Select LAMP RUN TIME. Press and hold the ENTER button for about 3 seconds. The 'lamp time reset' will display. Press OK and press the ENTER button. This will reset the lamp hours as well as turn off the projector.
Posted on Feb 25, 2009
  • 36 Answers
SOURCE: PT-AX100U-EC DLP Projector: I replaced the bulb on the Panasonic PT-F1000NT pr...
1.Press the MENU button to display the menu screen, and
then press the F or G button to select the OPTION menu.
2. Press the ENTER button, and then press the F or G button
to select LAMP RUNTIME.
3. Press and hold the ENTER button for approximately
3 seconds. The confirmation screen, “LAMP RUNTIME
RESET.
” is displayed and select OK.
4. Turn off the power.
�� This will reset the cumulative usage time for the lamp
unit to zero.
***Here you go and best of luck!***
Posted on May 07, 2010
SOURCE: panasonic projector pt-lm2e
I have Panasonic Pt-LM2E projector and it have a pblm,when it goes standby mode after some time (5-7minutes).no other indications shown (eg: lamp,temperature ).pls give a solution for this
Regards
Siva
Posted on Jun 28, 2010
How to do lamp reset on panasonic pt-lb50u projector.
To reset the lamp hours, turn on the projector. Then press Menu and use the Up/Down arrows to highlight Options. Press Enter then highlight Lamp Runtime. Press and hold Enter for 3+ seconds until the Lamp Runtime screen is displays. Press the Power button (any other button cancels the reset). When the Power button LED turns red, unplug the power cord to the projector. You can either use the remote or the controls on the projector. Reconnect the power cord after a few minutes.
The reset instructions are on page 62 of the user manual. The manual is available from Panasonic here: https://support.panasonic.co.nz/docstore/PT-LB50U%20Operating%20Instructions.pdf .
I hope this helps.
Jun 18, 2016 | Panasonic PT-LB50U Multimedia Projector
I have a Panasonic PT-LM2U; when it is turned on, everything powers up fine but the image projected is upside down. I've looked through the menu but didn't see an option for flipping or rotating...
Every modern projector that I have seen has a setting that will allow you to flip the image for this.If you purchased it used it was probably configured as a ceiling mount in an upside down orientation or rear projection onto a translucent screen. (The projection method can be set from the "OPTION2" menu. in a Model LM1 so it should be similar. http://service.us.panasonic.com/OPERMANPDF/PTLM1U.PDF
If yours doesn't have this option, then you'll have to use mounts that require the projector to be upside down.
Jul 18, 2011 | Panasonic PT-LM2U Multimedia Projector
Just replaced bulb and Lamp red light still comes on when you plug in the Panasonic PT-LB1OU lcd projector. Screen display states: Replace Bulb
Replace power board: ETXMM519MBGB
Or replace transistor Q107 on this board with a typical pnp for switching power supllies,there's not a part number for it on the manual.
Dec 15, 2009 | Panasonic PT-LB10U Multimedia Projector
PT L711U + all my black colors are blue
Your projector needs to be aligned and serviced, normal occurrence
after 6 years since service.
Apr 18, 2009 | Panasonic PT L711U Multimedia Projector
Panasonic PT-AE700E HD Projector, Has A Colour Problem
the filter on your projector has gone bad the same needs to be replacerd
Nov 04, 2008 | Panasonic PT-AE700U Multimedia Projector
Cannot access menu screen on Panasonic PT-D3500U projector
If memory serves me correctly, there is an OSD button on the projector itself. Press that once. You may have turned off the OnScreen Display feature. If that fails to resolve the problem, please let me know and I'll look up your specific model.
Dan
May 28, 2008 | Panasonic PT-D3500U Multimedia Projector
Mustang projector mount required mounting projector upside down...
You may have figured it out by now... From the remote, you go into the menu and find the setting "Display Image" and the option is "Ceiling".
Dec 26, 2007 | Panasonic PT-AE700U Multimedia Projector
Panasonic PT-AE700U Multimedia Projector Logo
1,462 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
HEMANT GROVER
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
