Question about Kenmore Dishwashers
I have a Kenmore Ultra Wash dishwasher Mod # 665-1371. It recently started leaving the dishes dirty. I have checked all the items on the Trouble shooting page of the User Manual and all items listed are OK. What should I look for or do next?
markevans
  • 148 Answers
SOURCE: Kenmore Ultra Wash Dishwasher wiring diagram
if unavailable on line, contact mfg's parts and you should be able to order it.
also, they likely do not make the unit. the sears may be able to tell you who made it. that company would be able to get you a diagram. just make some phone calls.
Posted on Dec 21, 2007
SOURCE: Kenmore Ultra Wash Dishwasher; Model 665.17539
I have a Kenmore 665 about 3 years old
Over the last couple months the touch pads have stopped working and I am now down to one control the water miser!
Do I need a new control pad and is that easy to install ?
Thank you for any sudgetstions
KC
Posted on Feb 08, 2008
  • 14 Answers
SOURCE: Whirlpool Gold quiet partner III, leaves dirty, greasy dishes
Ifixall is correct. I also learned several things with the apartment buildings I maintain.
1. the screen or pump trap must also be cleaned regularly to make sure there is no debris, food etc stuck in there.
2. The spray arms must be free of debris or obstructions.
3. Jet dry solution must be filled or has some solution in it.
4. Water must be hot
5. Scraping dishes and prewash them before putting them into dishwasher.
6 install water softner sometimes helps. (I don't know how true this is, since I am unable to do this in our buildings)
7 drain line must be picked up, or secured to prevent backwash.
8. MAKE sure that the lower rack is not obstructing the sprayer arms. Sometimes overloading dishwashers will cause dishes not being cleaned properly.
9. if all else fails, a service technician can come out to determine if the dishwasher is operating properly.
Posted on May 24, 2008
  • 9 Answers
SOURCE: Where is the filter on a Kenmore Quiet Guard 2 dishwasher?
I have a Quiet Guard 4. Same problem so will describe my solution.
1. Remove bottom basket. Remove top basket.
2. Remove bottom washing arm. Unscrew (Gently but firmly) the centre post. Lift arm assembly up and out.
3. Remove overhead conduit. One screw at back, one at top (Philips #2 bit). Rotate whole assembly 45 deg right (Clockwise) and lift off of centre post.
4. Remove centre post (Pull straight up). Remove 4 screws (Star T-20 bit). Lift whole assembly out. Pop off screen and clean.
5. Remove cap over cutter/chopper. There is a single screw at front left (under assembly removed in 4). Remove screw (Star T-15 bit) and cap (Needs some wiggling to free it up). Remove cutter and filter. It is on a spring loaded pin. Pull the cutter blade foreward and then the filter disc straight up. Clean thoroughly as it may be the cause of your problems.
Reassimble. Good luck!
Posted on Jan 02, 2009
  • 228 Answers
SOURCE: SHU43C06UC dishwasher cleans dishes on bottom rack
your top spray arm is blocked and not rotating,remove it from top basket and thoroughly clean it paying particular attention to the holes right at the ends these are angled to drive the arms round if they block up the arms will not rotate.
Posted on Nov 10, 2009
Kenmore model 665
Power off, check for clogs and if water supply to arm ok. Remove any build ups and reconnect. Good Luck.
Jul 23, 2013 | Dishwashers
I have a kenmore ultra wash quietguard 3 . It fills but not enough to cover the heating coil. It washes poorly and leaves schmutz on the dishes. I have checked all the sprayers. They are not clogged. ...
I have an older dishwasher also and recently my wife also complained about it not cleaning right... so me being the man I am tried in vain to clean the things... Bought new spray arms online and installed them in minutes...now the thing works like new... However I have also found that if the heating element goes bad then that also can mess things up bad... So I would buy new spray arms, and also check out the heating element to make sure it is working... Here is a tip that will help you with the online buying...
Dishwasher
Spray Arms not Spinning
How to Buy
Appliance Parts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The
Heating Element not Working
Dishwasher Maintenance
Dishwasher Residue and Film on Dishes
heatman101
Asker
Apr 22, 2011 | Kenmore Dishwashers
Kenmore Ultra Wash dishwasher leaves spots on ALL dishes, top and bottom. Changed detergent, same problem.
The scum, film and white residue problems have started since the reduction of phosphates in dishwasher detergents.
Here is a tip that will help you to solve the problem of films, residue, and scum in your dishwasher.
heatman101
Feb 24, 2011 | Kenmore Dishwashers
The top rack on my kenmore ultra wash 3 dishwasher does not come clean and now even the bottom is starting to not clean
First perform a vinegar cycle wash in the dishwasher. Pour a cup of vinegar into the bottom of the dishwasher. Keep the temperature at the highest setting possible and perform a wash cycle.Then start using a dishwasher most probably that would solve the problem. If this does not solve the problem then there must be some parts worn out or faulty creating the problem.
There are many probable causes of failure .
To clean the dishes the water temperature is essential.It the water is not hot then the dishes will not be cleaned properly.So check the water temperature.
Also check the filter in your dishwasher.Clean the filter if there is accumulation of debris in the filter
If you are in an hard water zone , then try reducing the amount of detergent used and then try cleaning the dishes.
Dec 23, 2010 | Kenmore PRO 24 in BuiltIn Dishwasher with...
While washing dishes the dishwasher has a continuous knocking noise
This is usually due to worn spray-arms. These are replacable items.
Remove them and check for wear, and replace if required.
Jun 06, 2010 | Kenmore PRO 24 in BuiltIn Dishwasher with...
I have a kenmore elite ultra wash he (model 665.1315) dishwasher - one year old. No problems until recently. It just started leaving a substantial film on the dishes, cutlery and racks in the past 10...
there is calcium in water and it builds up around the pump and the flow you typically have to take it all apart to clean it or there is crud in your drain inside the dishwasher, basically you are swishing around the dirty old water and food particles, Ralph this is from not rinsing dishes first and using special dishwasher soaps to prevent the build up thus clogging pump and exit lines. pull the pump apart if you dont find clogged filters.
Nov 24, 2017 | Kenmore Dishwashers
Dishwasher not getting dishes clean
That is why it is seccond hand. If it was a good one the first owner would have kept it.Probably the impeller at the pump is shot, Change the impeller. Vitally
May 13, 2009 | Dishwashers
Dishwashers Logo
55 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
vince
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
