Question about Anthology Solutions Yellow Machine P400 (250004001) 250 GB Hard Drive Array
Yellow Machine is not Mounting....
I have a yellow machine and I am using it with my mac network.  I have a linksys router and a new airport extreme wireless router.  I have everything on the network able to communicate but the yellow machine isn't showing up??And suggestions?? Thanks in advance-Tom cell 315-794-2212
    Problem Solver:
  • 9 Answers
The reason the drive won't mount is because the RAID is corrupted. It may require manual intervention. You would have to log in through root on the box. How long did you wait before trying to mount a partition. Trying waiting 2-3 hours (if you see lots of disk activity they are going through a repair). If you see none then you have to go the manual intervention route as root and run the "md" commands to identify the root cause and repair the volume.
The unofficial support website is: http://www.yellowmachinesupport.com/
You would need to use the RAID tools on the linux os loaded on the unit in order to repair.
Good luck,
David
Posted on Aug 06, 2010
Flashing yellow light
Do you have the "AirPort Utility" installed on your computer?
If not, you can download it from Apple here: (Click here for Windows) (Click here for Mac)
If you run that and connect to your AirPort Extreme, it will display the error message when you click the "Manual Setup"
Let us know what the error message is and we'll try to help.
Thanks for using FixYa and Happy New Year.
Dec 31, 2010 | Apple AirPort Extreme Router
I have a yellow machine p400t and i need to give it a static IP address and do this through a linksys router. how do i go about this? do i need to attach it to a computer?
Yes, it must be attached to the network 0. Install the yellow machine software on the PC 1.Log on to the Yellow Machine Manager. Go to “Logging On To Yellow Machine Manager” on page 8. 2.From the Yellow Machine Manager, click Network > Network Interfaces. The Network Interfaces window appears. 3.Click Edit. 4.Select Yes to Enable LAN Interface. Default: Yes (Enabled) • If you select No, all other LAN option fields are blocked. • If you disable the LAN Interface, the only access to the Yellow Machine appliance is through the WAN port. Anthology Solutions does not recommend this configuration. 5.Check Enable DHCP Service if the DHCP service is needed for the PCs attached to the Yellow Machine appliance’s LAN ports. This setting makes the Yellow Machine appliance the DHCP server for your LAN (or sub-network), providing IP addresses dynamically for the clients connected to the LAN ports. Default: Checked (Disabled) 6.Select either Obtain IP Address Automatically from DHCP Server, or Static IP Address. Default: Static IP Address • Choose Obtain IP Address Automatically from DHCP Server if your Yellow Machine appliance connects to either a router that has DHCP service enabled or to a cable modem. This setting makes the Yellow Machine appliance a DHCP client on your network. • Obtain IP Address from ADSL provider is greyed out. • Choose Static IP Address if your network is locally defined and controlled and does not use DHCP services. Type the IP address manually. 7.Specify IP address and Subnet mask if you selected a Static IP Address, and click Apply. 8.Click Yes to confirm, No to abort. The changes takes affect within five seconds after the network interface change notice appears.
Jan 26, 2010 | Anthology Solutions Yellow Machine P400T...
Printer not working from new router
First, I would suspect your PC has the printer installed using the IP address of the printer. I would uninstall the printer, then go to "add printer" then "add network printer" and see if this works. If not: HP has a neat setup available for their printers. Go to their website and look for network printer setup. This will install on your computer, and go through your network and find your printer.
Nov 30, 2017 | Apple AirPort Extreme Router
We want to supply wireless to our park in Florida, from one router. What router do we buy? Someone tried and they couldn't get any signal, whats best ?
get the Linksys wireless router with hot spot feature.
here is video of what you need.
http://www.youtube.com/watch?v=PwnhggrwfYg
moer info here
http://www.howtoforge.com/wireless_hotspot_howto
Sep 21, 2009 | Linksys Wireless-G WRT54G Router
Attempting to connect new Acer netbook to existing Mac network
Had the same problem. What i did was in the Airport Configuration program goto "Airport" then to "Wireless" and then to "Wirelesee options" In this menu deselect "Use wide channels". Also i decreased the power of the 5.0 Ghz transmission, because i don't use it yet. But i think the "Wide channels" is the reason of the problem. It is a bit weird thoug, on my Airports Guest acount with no password and incryption, the Acer One loged on perfectly, but on my private network with WPA2 it did not. Aparantly the Guest network does not use "Wide Channels" Hope this helps, but take care, maybe the menu's are called differendly because i had to translate them from Dutch. Good luck.
Aug 11, 2009 | Apple AirPort Extreme Base Station
Wont connect to each other
connect the airport extreme to the voyager using a network cable... factory reset the extreme and then connect to it using the airport utility... you should get a setup screen where you can switch the extreme to "bridge mode" .. everything else should happen automatically.. you will then have 2 wireless networks?
May 03, 2009 | Apple AirPort Extreme Base Station...
Airport extreme / Windows XP with VPN problem
have you reset the airport extreme? theres a tiny hole you can push in w a paperclip. Also, do you have the latest firmware?
Mar 10, 2009 | Apple AirPort Extreme Router
Imac AirPort Extreme (0x14E4, 0x8C) to wifi
On the iMac choose Create Network... from the Airport menu. Then the Gateway laptop will be able to join the iMac's created network.
macs2u
Dec 29, 2008 | Apple AirPort Extreme Base Station...
Lost Net Connection after iMac was disconnected from Network
Cable modems don't usually have this issue so I'll assume your on a DSL connection, 56K modem, or someother phone related variant. You were most likely setup for a connection through your Airport using local IP settings on each machine and when you moved the machine you reconfigured yourself with a DHCP address. There are two solutions. (1) Reconfigure every machine for DSL (2) Configure your airport for DSL and connect everything to it.
Unfortunately the process from one provider to another varies slightly. But for that reason I generally only recommend cable for multi-computer housholds sharing a web connection.
Dec 21, 2008 | Linksys Wireless-G WRT54G Router
Anthology Solutions Yellow Machine  P400 (250004001) 250 GB Hard Drive Array Logo
115 people viewed this question
Top Anthology Solutions Computers & Internet Experts
David Payne
David Payne
Are you an Anthology Solutions Computer and Internet Expert? Answer questions, earn points and help others
